[PATCH v1 0/2] Change to QEMU 5
Ryan Long ryan.long at oarcorp.com
Mon Aug 22 20:29:13 UTC 2022
Hi,
For this patchset I changed the hash of the glib hash because it has changed
and it doesn't work on Debian 11, Ubuntu 22.04, and CentOS 8 Stream.
After fixing the glib hash, I continued to run into other errors. So I brought
in the config files for QEMU 5 since all the previously mentioned OSes had no
problem building it.
Thanks,
Ryan
Ryan Long (2):
  glib-2.48.2-1.cfg: Fix checksum of patch
  Add QEMU 5 configuration files
 bare/config/devel/glib-2.48.2-1.cfg     |   2 +-
 bare/config/devel/qemu-5.2.0-1.cfg      |  42 +++++++
 bare/config/devel/qemu-couverture.bset  |   2 +-
 bare/config/devel/qemu.bset             |   2 +-
 source-builder/config/qemu-5-1.cfg      |   9 ++
 source-builder/config/qemu-common-2.cfg | 145 ++++++++++++++++++++++++
 6 files changed, 199 insertions(+), 3 deletions(-)
 create mode 100644 bare/config/devel/qemu-5.2.0-1.cfg
 create mode 100644 source-builder/config/qemu-5-1.cfg
 create mode 100644 source-builder/config/qemu-common-2.cfg
2.30.2
