[PATCH] Document CONFIGURE_RECORD_INTERRUPTS_ENABLED
Thu Dec 1 22:38:06 UTC 2022
Looks good.
Thanks
On 1/12/2022 11:11 pm, Sebastian Huber wrote:
> Close #4769.
>  c-user/config/event-record.rst  | 43 +++++++++++++++++++++-
>  user/tracing/eventrecording.rst | 65 +++------------------------------
>  2 files changed, 47 insertions(+), 61 deletions(-)
> diff --git a/c-user/config/event-record.rst b/c-user/config/event-record.rst
> index 31a4fa9..f1e7969 100644
> --- a/c-user/config/event-record.rst
> +++ b/c-user/config/event-record.rst
> @@ -1,6 +1,6 @@
>  .. SPDX-License-Identifier: CC-BY-SA-4.0
> -.. Copyright (C) 2019, 2021 embedded brains GmbH (http://www.embedded-brains.de)
> +.. Copyright (C) 2019, 2022 embedded brains GmbH (http://www.embedded-brains.de)
>  .. This file is part of the RTEMS quality process and was automatically
>  .. generated.  If you find something that needs to be fixed or
> @@ -150,6 +150,47 @@ in a fatal error extension (see :ref:`Terminate`).
>  The zlib compression needs about 512KiB of RAM.  This extension can be used
>  to produce crash dumps.
> +.. Generated from spec:/acfg/if/record-interrupts-enabled
> +.. raw:: latex
> +    \clearpage
> +.. index:: CONFIGURE_RECORD_INTERRUPTS_ENABLED
> +.. _CONFIGURE_RECORD_INTERRUPTS_ENABLED:
> +CONFIGURE_RECORD_INTERRUPTS_ENABLED
> +.. rubric:: CONSTANT:
> +``CONFIGURE_RECORD_INTERRUPTS_ENABLED``
> +.. rubric:: OPTION TYPE:
> +This configuration option is a boolean feature define.
> +.. rubric:: DEFAULT CONFIGURATION:
> +If this configuration option is undefined, then the described feature is not
> +enabled.
> +.. rubric:: DESCRIPTION:
> +In case
> +* this configuration option is defined
> +* and :ref:`CONFIGURE_RECORD_PER_PROCESSOR_ITEMS` is properly defined,
> +then the interrupt event recording is enabled.
> +.. rubric:: NOTES:
> +The interrupt event recording generates interrupt entry and exit events when
> +interrupt entries are dispatched.
>  .. Generated from spec:/acfg/if/record-per-processor-items
>  .. raw:: latex
> diff --git a/user/tracing/eventrecording.rst b/user/tracing/eventrecording.rst
> index 7130658..b5561cc 100644
> --- a/user/tracing/eventrecording.rst
> +++ b/user/tracing/eventrecording.rst
> @@ -48,8 +48,11 @@ The application enables the event recording support via the configuration
>  option :c:macro:`CONFIGURE_RECORD_PER_PROCESSOR_ITEMS`.  The configuration
>  option :c:macro:`CONFIGURE_RECORD_EXTENSIONS_ENABLED` enables the generation of
>  thread create, start, restart, delete, switch, begin, exitted and terminate
> -events.  Dumps of the event records in a fatal error handler can be enabled by
> -the mutually exclusive :c:macro:`CONFIGURE_RECORD_FATAL_DUMP_BASE64` and
> +events.  The configuration option
> +:c:macro:`CONFIGURE_RECORD_INTERRUPTS_ENABLED` enables the generation of
> +interrupt entry and exit events.  Dumps of the event records in a fatal error
> +handler can be enabled by the mutually exclusive
> +:c:macro:`CONFIGURE_RECORD_FATAL_DUMP_BASE64` and
>  :c:macro:`CONFIGURE_RECORD_FATAL_DUMP_BASE64_ZLIB` configuration options.
>  Custom events can be recorded for example with the
> @@ -98,64 +101,6 @@ instrumented functions:
> -To generate interrupt handler entry/exit events, the following patch can be
> -used:
> -.. code-block:: diff
> -    diff --git a/bsps/arm/shared/clock/clock-armv7m.c b/bsps/arm/shared/clock/clock-armv7m.c
> -    index 255de1ca42..0d37c63ac6 100644
> -    --- a/bsps/arm/shared/clock/clock-armv7m.c
> -    +++ b/bsps/arm/shared/clock/clock-armv7m.c
> -    @@ -29,6 +29,7 @@
> -     #include <bsp/clock-armv7m.h>
> -     #include <rtems.h>
> -    +#include <rtems/record.h>
> -     #include <rtems/sysinit.h>
> -     #ifdef ARM_MULTILIB_ARCH_V7M
> -    @@ -45,9 +46,11 @@ static uint32_t _ARMV7M_TC_get_timecount(struct timecounter *base)
> -     void _ARMV7M_Clock_handler(void)
> -    +  rtems_record_produce(RTEMS_RECORD_INTERRUPT_ENTRY, ARMV7M_VECTOR_SYSTICK);
> -       _ARMV7M_Interrupt_service_enter();
> -       Clock_isr(NULL);
> -       _ARMV7M_Interrupt_service_leave();
> -    +  rtems_record_produce(RTEMS_RECORD_INTERRUPT_EXIT, ARMV7M_VECTOR_SYSTICK);
> -     static void _ARMV7M_Clock_handler_install(void)
> -    diff --git a/bsps/include/bsp/irq-generic.h b/bsps/include/bsp/irq-generic.h
> -    index 31835d07ba..2ab2f78b65 100644
> -    --- a/bsps/include/bsp/irq-generic.h
> -    +++ b/bsps/include/bsp/irq-generic.h
> -    @@ -30,6 +30,7 @@
> -     #include <stdbool.h>
> -     #include <rtems/irq-extension.h>
> -     #include <rtems/score/assert.h>
> -     #ifdef RTEMS_SMP
> -    @@ -258,6 +259,7 @@ void bsp_interrupt_vector_disable(rtems_vector_number vector);
> -     static inline void bsp_interrupt_handler_dispatch(rtems_vector_number vector)
> -    +  rtems_record_produce(RTEMS_RECORD_INTERRUPT_ENTRY, vector);
> -       if (bsp_interrupt_is_valid_vector(vector)) {
> -         const bsp_interrupt_handler_entry *e =
> -           &bsp_interrupt_handler_table [bsp_interrupt_handler_index(vector)];
> -    @@ -276,6 +278,7 @@ static inline void bsp_interrupt_handler_dispatch(rtems_vector_number vector)
> -       } else {
> -         bsp_interrupt_handler_default(vector);
> -    +  rtems_record_produce(RTEMS_RECORD_INTERRUPT_EXIT, vector);
>  Transfer of Event Records to the Host Computer
