pc686 DEBUG mode has high number of test failures
Thu Dec 15 19:56:27 UTC 2022
Hi
As part of preparing for the branching of 6, we want test results from as
many BSPs as possible, for them to be "good", and for there to be no
unexpected failures. This is an area where community help is possible and
appreciated.
I have tinkered with the build sweep scripting and not build@ has a LOT
more results. One of note is that the pc686 has bad results with debug
enabled and a mix of odd results depending on the host. Look at .the past
few days for i386/pc686 results from myself and "OAR Tester"
Joel on CentOS 7:
    i386/pc686: RTEMS_POSIX_API:
        Passed:595 Failed:6 Timeout:2 Test-Too-long:0 Invalid:10 Wrong:0
    https://lists.rtems.org/pipermail/build/2022-December/038649.html
OAR Tester on CentOS 8
       Passed:274 Failed:329 Timeout:2 Test-Too-long:0 Invalid:10 Wrong:3
    https://lists.rtems.org/pipermail/build/2022-December/038648.html
Help is appreciated to investigate this.
Thanks.
--joel
URL: <http://lists.rtems.org/pipermail/devel/attachments/20221215/89ea4c7c/attachment.htm>
