[PATCH rtems-libbsd v2 1/3] Add MicroBlaze support
Alex White alex.white at oarcorp.com
Thu Feb 10 22:12:23 UTC 2022
From: Jennifer Averett <jennifer.averett at oarcorp.com>
 .../sys/microblaze/include/machine/in_cksum.h | 83 +++++++++++++++++++
 libbsd.py                                     |  6 +-
 2 files changed, 86 insertions(+), 3 deletions(-)
 create mode 100644 freebsd/sys/microblaze/include/machine/in_cksum.h
diff --git a/freebsd/sys/microblaze/include/machine/in_cksum.h b/freebsd/sys/microblaze/include/machine/in_cksum.h
new file mode 100644
index 00000000..d55b838b
--- /dev/null
+++ b/freebsd/sys/microblaze/include/machine/in_cksum.h
@@ -0,0 +1,83 @@
+ * SPDX-License-Identifier: BSD-3-Clause
+ * Copyright (c) 1990 The Regents of the University of California.
+ * All rights reserved.
+ * are met:
+ * 3. Neither the name of the University nor the names of its contributors
+ *    may be used to endorse or promote products derived from this software
+ *    without specific prior written permission.
+ * THIS SOFTWARE IS PROVIDED BY THE REGENTS AND CONTRIBUTORS ``AS IS'' AND
+ * ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
+ * ARE DISCLAIMED.  IN NO EVENT SHALL THE REGENTS OR CONTRIBUTORS BE LIABLE
+ * FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL
+ * DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS
+ * OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION)
+ * HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT
+ * LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY
+ * OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF
+ * SUCH DAMAGE.
+ *	from tahoe:	in_cksum.c	1.2	86/01/05
+ *	from:		@(#)in_cksum.c	1.3 (Berkeley) 1/19/91
+ *	from: Id: in_cksum.c,v 1.8 1995/12/03 18:35:19 bde Exp
+ *	from: src/sys/alpha/include/in_cksum.h,v 1.7 2005/03/02 21:33:20 joerg
+ * $FreeBSD$
+#ifndef _MACHINE_IN_CKSUM_H_
+#define	_MACHINE_IN_CKSUM_H_	1
+#include <sys/cdefs.h>
+#define	in_cksum(m, len)	in_cksum_skip(m, len, 0)
+#if defined(IPVERSION) && (IPVERSION == 4)
+ * It it useful to have an Internet checksum routine which is inlineable
+ * and optimized specifically for the task of computing IP header checksums
+ * in the normal case (where there are no options and the header length is
+ * therefore always exactly five 32-bit words.
+#ifdef __CC_SUPPORTS___INLINE
+static __inline void
+in_cksum_update(struct ip *ip)
+	int __tmpsum;
+	__tmpsum = (int)ntohs(ip->ip_sum) + 256;
+	ip->ip_sum = htons(__tmpsum + (__tmpsum >> 16));
+#else
+#define	in_cksum_update(ip)						\
+	do {								\
+		int __tmpsum;						\
+		__tmpsum = (int)ntohs(ip->ip_sum) + 256;		\
+		ip->ip_sum = htons(__tmpsum + (__tmpsum >> 16));	\
+	} while(0)
+#endif
+#endif
+#ifdef _KERNEL
+u_int in_cksum_hdr(const struct ip *ip);
+#endif
+u_short in_addword(u_short sum, u_short b);
+u_short in_pseudo(u_int sum, u_int b, u_int c);
+u_short in_cksum_skip(struct mbuf *m, int len, int skip);
+#endif
+#endif /* _MACHINE_IN_CKSUM_H_ */
diff --git a/libbsd.py b/libbsd.py
index 7593e9ba..d57a15c5 100644
--- a/libbsd.py
+++ b/libbsd.py
@@ -5186,7 +5186,7 @@ class in_cksum(builder.Module):
         self.addTargetSourceCPUDependentHeaderFiles(
             [ 'arm', 'avr', 'bfin', 'h8300', 'lm32', 'm32c', 'm32r', 'm68k',
-              'nios2', 'sh', 'sparc', 'v850' ],
+              'microblaze', 'nios2', 'sh', 'sparc', 'v850' ],
             'mips',
                 'sys/mips/include/in_cksum.h',
@@ -5223,8 +5223,8 @@ class in_cksum(builder.Module):
         self.addCPUDependentFreeBSDSourceFiles(
-                'mips', 'moxie', 'nios2', 'or1k', 'riscv', 'sh', 'sparc',
-                'v850'
+                'microblaze', 'mips', 'moxie', 'nios2', 'or1k', 'riscv', 'sh',
+                'sparc', 'v850'
                 'sys/mips/mips/in_cksum.c',
2.30.2
