NTP client recommendation for RTEMS?
Tue Feb 22 20:25:11 UTC 2022
On Tue, Feb 22, 2022, 1:45 PM Sebastian Huber <
> On 22/02/2022 20:30, Joel Sherrill wrote:
> > On Tue, Feb 22, 2022 at 1:21 PM Sebastian Huber
> > <sebastian.huber at embedded-brains.de>  wrote:
> >> On 22/02/2022 19:22, Joel Sherrill wrote:
> >>> Are you planning to get the NTP server side of the freebsd-org code
> working?
> >>> Or get it building but not testing it?
> >>> Or just focusing on building and testing JUST the client part.
> >> I ported the ntpd from FreeBSD to an older version of the libbsd. I only
> >> tested the client part and this seems to work fine after some basic
> tests.
> > OK. That matches what I expected. Is the libbsd version to old to merge
> > against? Any plans to merge this?
> > Alternatively, is your work available to be used as the basis for
> updating
> > to 6-freebsd-12?
> I have a very long TODO list. Actually, I started with the current
> 6-freebsd-12 branch, but it didn't work, so in principle generating
> patches for this branch should be easy.
Thanks. If we end up working on this, we will sync with you to help and
avoid duplicate work.
--joel
> embedded brains GmbH
> Herr Sebastian HUBER
> Dornierstr. 4
> 82178 Puchheim
> Germany
> email: sebastian.huber at embedded-brains.de
> phone: +49-89-18 94 741 - 16
> fax:   +49-89-18 94 741 - 08
> Registergericht: Amtsgericht München
> Registernummer: HRB 157899
> Vertretungsberechtigte Geschäftsführer: Peter Rasmussen, Thomas Dörfler
> Unsere Datenschutzerklärung finden Sie hier:
> https://embedded-brains.de/datenschutzerklaerung/
