[PATCH] samples/cdtest: Test execeptions during system init
Fri Jul 1 10:02:29 UTC 2022
Update #4668.
Update #4672.
 testsuites/samples/cdtest/main.cc | 44 ++++++++++++++++++++++++-------
 1 file changed, 35 insertions(+), 9 deletions(-)
diff --git a/testsuites/samples/cdtest/main.cc b/testsuites/samples/cdtest/main.cc
index 894e404ba1..44cdaf84bb 100644
--- a/testsuites/samples/cdtest/main.cc
+++ b/testsuites/samples/cdtest/main.cc
@@ -25,9 +25,11 @@
 #include <rtems/bspIo.h>
 #include <rtems/test-info.h>
+#include <rtems/sysinit.h>
 #include <cstdio>
 #include <cstdlib>
+#include <cstring>
 #include <stdexcept>
 #ifdef RTEMS_TEST_IO_STREAM
@@ -44,13 +46,6 @@ extern rtems_task main_task(rtems_task_argument);
 static int num_inst = 0;
-static void check_begin_of_test(void)
-  if ( num_inst == 0 ) {
-    TEST_BEGIN();
 static void check_end_of_test(void)
@@ -62,7 +57,6 @@ class AClass {
 public:
   AClass(const char *p = "LOCAL" ) : ptr( p )
-        check_begin_of_test();
         num_inst++;
         printf(
           "%s: Hey I'm in base class constructor number %d for %p.\n",
@@ -104,7 +98,6 @@ class BClass : public AClass {
 public:
   BClass(const char *p = "LOCAL" ) : AClass( p )
         num_inst++;
         printf(
           "%s: Hey I'm in derived class constructor number %d for %p.\n",
@@ -244,3 +237,36 @@ rtems_task main_task(
     printf( "Global Dtors should be called after this line....\n" );
     exit(0);
+static void early_exception()
+    try
+      throw "early exception";
+    catch( const char *e )
+      rtems_test_assert(strcmp(e, "early exception") == 0);
+      throw "early exception 2";
+static void test_exceptions_during_system_init()
+    TEST_BEGIN();
+    try
+      early_exception();
+      rtems_test_assert(strcmp(e, "early exception 2") == 0);
+RTEMS_SYSINIT_ITEM(
+    test_exceptions_during_system_init,
+    RTEMS_SYSINIT_IDLE_THREADS,
+    RTEMS_SYSINIT_ORDER_LAST
2.35.3
