linkcmds.yml problems
Alex White alex.white at oarcorp.com
Thu Jul 7 19:09:47 UTC 2022
On Thu, Jul 7, 2022 at 10:31 AM Sam Price <thesamprice at gmail.com> wrote:
> Is it possible i have a bad python instance ?
I was able to reproduce the linker problem using the latest RTEMS upstream code.
It looks like it was broken by commit a0aaa394b68727d204904b59514cb0f90840ba6f from 6 days ago.
I will submit a fix.
Alex
> Thank you,
> Sam Price
> devel mailing list
> devel at rtems.org
From: devel <devel-bounces at rtems.org> on behalf of Sam Price <thesamprice at gmail.com>
Sent: Thursday, July 7, 2022 10:30 AM
To: devel at rtems.org
Subject: linkcmds.yml problems
Was trying to build the latest source builder/rtems/libbsd but ran into a linker problem.
You ever see this the source linker has
spec/build/bsps/microblaze/microblaze_fpga/linkcmds.yml: RAM : ORIGIN = _TEXT_START_ADDR, LENGTH = ${BSP_MICROBLAZE_FPGA_RAM_LENGTH}
But the generated linker file is creating
when building rtems without populating the BSP_MICROBLAZE_FPGA_RAM_LENGTH.
My config.ini has this specified as
configs/config_kcu105_cpu0.ini:BSP_MICROBLAZE_FPGA_RAM_LENGTH=0x10000000
Thank you,
Sam Price
