[PATCH 02/23] bsps/i386/shared/pci/pci_io.c:Change license to BSD-2
Mon Jul 11 22:36:14 UTC 2022
Updates #3053.
 bsps/i386/shared/pci/pci_io.c | 25 ++++++++++++++++++++++---
 1 file changed, 22 insertions(+), 3 deletions(-)
diff --git a/bsps/i386/shared/pci/pci_io.c b/bsps/i386/shared/pci/pci_io.c
index b6cd1005f0..60b855ed81 100644
--- a/bsps/i386/shared/pci/pci_io.c
+++ b/bsps/i386/shared/pci/pci_io.c
@@ -1,3 +1,5 @@
  * @file
@@ -8,9 +10,26 @@
  *  COPYRIGHT (c) 2016.
  *  On-Line Applications Research Corporation (OAR).
- *  The license and distribution terms for this file may be
- *  found in the file LICENSE in this distribution or at
- *  http://www.rtems.org/license/LICENSE.
+ * are met:
