[RSB 1/3] 6/7: Update Newlib
Wed Jul 20 08:20:22 UTC 2022
On 20/07/2022 10:11, Chris Johns wrote:
>>> Are these TLS allocations in newlib based on a single use of a newlib call that
>>> brings in the reent stuff? How does that work?
>> No, each TLS object is defined in the translation unit which uses the object.
>> The goal is to get only those objects linked in which are needed. Currently, the
>> Newlib thread delete hook pulls in some objects, however, this dependency will
>> go away once the TLS destructors are implemented.
> If I have task A and it opens a file and writes something to a file system will
> it pull in the TLS support for files?
Yes.
> Given the TLS support is static does this mean all threads in the A app allocate
> the newlib file TLS variables even if they never use newlib?
Yes.
> My understanding of the existing reent support is tasks that do not use newlib
> it never allocate a reent struct?
No, the struct _reent is allocated for all tasks if you don't use
CONFIGURE_DISABLE_NEWLIB_REENTRANCY (which is not recommended). How
would you know if a task doesn't use Newlib?
embedded brains GmbH
Herr Sebastian HUBER
Dornierstr. 4
82178 Puchheim
Germany
phone: +49-89-18 94 741 - 16
fax:   +49-89-18 94 741 - 08
Registernummer: HRB 157899
