[rtems-central] Add POSIX Timer FACE Behavior Configuration
Mon Sep 5 14:45:40 UTC 2022
On 05/09/2022 15:12, Joel Sherrill wrote:
> On Mon, Sep 5, 2022, 2:04 AM Sebastian Huber
> <sebastian.huber at embedded-brains.de
> <mailto:sebastian.huber at embedded-brains.de>> wrote:
>     Hello Joel,
>     On 02/09/2022 18:25, Joel Sherrill wrote:
>      > Updates #4691.
>      >   config.yml                                 |  2 ++
>      >   spec/acfg/if/group-face.yml                | 30
>      >   spec/acfg/if/posix-timer-face-behavior.yml | 23
>      >   3 files changed, 55 insertions(+)
>      >   create mode 100644 spec/acfg/if/group-face.yml
>      >   create mode 100644 spec/acfg/if/posix-timer-face-behavior.yml
>     thanks for adding the items. I check it in and regenerated the files in
>     RTEMS and the documentation. Sorry for the bad state of
>     rtems-central, I
>     hope to clean this up in the next months.
> At least I figured out how to get it to generate. Needs to be and stay
> in sync and have some improvement in error messages. But it did work.
If you like, you could add an spec-glossary/glossary/face.yml file and
reference it in the configuration items using ${/glossary/face:/term}.
embedded brains GmbH
Herr Sebastian HUBER
Dornierstr. 4
82178 Puchheim
Germany
phone: +49-89-18 94 741 - 16
fax:   +49-89-18 94 741 - 08
Registernummer: HRB 157899
