[PATCH 5/7] bsp/aarch64: Raspberry pi headers for the BCM2711 SoC
Mohd Noor Aman nooraman5718 at gmail.com
Thu Sep 22 06:20:41 UTC 2022
This file included many of the address required for the future development of the RPi 4B BSP. This includes peripherals, ARM Timer, VideoCore Timer, Watchdog, Mailbox, AUX, FIQs and IRQs.
 .../raspberrypi/include/bsp/raspberrypi.h     | 471 ++++++++++++++++++
 1 file changed, 471 insertions(+)
 create mode 100644 bsps/aarch64/raspberrypi/include/bsp/raspberrypi.h
diff --git a/bsps/aarch64/raspberrypi/include/bsp/raspberrypi.h b/bsps/aarch64/raspberrypi/include/bsp/raspberrypi.h
new file mode 100644
index 0000000000..2cd851b5a2
--- /dev/null
+++ b/bsps/aarch64/raspberrypi/include/bsp/raspberrypi.h
@@ -0,0 +1,471 @@
+ * @file
+ * @ingroup raspberrypi_4_regs
+ * @brief Register definitions.
+ *  Copyright (c) 2022 Mohd Noor Aman
+ *  The license and distribution terms for this file may be
+ *  found in the file LICENSE in this distribution or at
+ *  http://www.rtems.org/license/LICENSE
+#ifndef LIBBSP_AARCH64_RASPBERRYPI_RASPBERRYPI_4_H
+#define LIBBSP_AARCH64_RASPBERRYPI_RASPBERRYPI_4_H
+#include <bspopts.h>
+#include <stdint.h>
+#include <bsp/utility.h>
+ * @defgroup raspberrypi_reg Register Definitions
+ * @ingroup RTEMSBSPsARMRaspberryPi
+ * @brief Register Definitions
+ * @name Register Macros
+#define BCM2711_REG(x)           (*(volatile uint64_t *)(x))
+#define BCM2711_BIT(n)           (1 << (n))
+ * @name Peripheral Base Register Address
+#define RPI_PERIPHERAL_BASE         0xFE000000
+#define BASE_OFFSET                 0xFE000000
+#define RPI_PERIPHERAL_SIZE         0x01800000
+ * @name Bus to Physical address translation
+ *       Macro.
+#define BUS_TO_PHY(x)            ((x) - BASE_OFFSET)
+ * @name Internal ARM Timer Registers
+#define BCM2711_CLOCK_FREQ       250000000
+#define BCM2711_TIMER_BASE       (RPI_PERIPHERAL_BASE + 0xB400)
+#define BCM2711_TIMER_LOD        (BCM2711_TIMER_BASE + 0x00)
+#define BCM2711_TIMER_VAL        (BCM2711_TIMER_BASE + 0x04)
+#define BCM2711_TIMER_CTL        (BCM2711_TIMER_BASE + 0x08)
+#define BCM2711_TIMER_CLI        (BCM2711_TIMER_BASE + 0x0C)
+#define BCM2711_TIMER_RIS        (BCM2711_TIMER_BASE + 0x10)
+#define BCM2711_TIMER_MIS        (BCM2711_TIMER_BASE + 0x14)
+#define BCM2711_TIMER_RLD        (BCM2711_TIMER_BASE + 0x18)
+#define BCM2711_TIMER_DIV        (BCM2711_TIMER_BASE + 0x1C)
+#define BCM2711_TIMER_CNT        (BCM2711_TIMER_BASE + 0x20)
+#define BCM2711_TIMER_PRESCALE    0xF9
+ * @name Power Management and Watchdog  Registers
+#define BCM2711_PM_PASSWD_MAGIC  0x5a000000
+#define BCM2711_PM_BASE          (RPI_PERIPHERAL_BASE + 0x100000)
+#define BCM2711_PM_GNRIC         (BCM2711_PM_BASE + 0x00)
+#define BCM2711_PM_GNRIC_POWUP   0x00000001
+#define BCM2711_PM_GNRIC_POWOK   0x00000002
+#define BCM2711_PM_GNRIC_ISPOW   0x00000004
+#define BCM2711_PM_GNRIC_MEMREP  0x00000008
+#define BCM2711_PM_GNRIC_MRDONE  0x00000010
+#define BCM2711_PM_GNRIC_ISFUNC  0x00000020
+#define BCM2711_PM_GNRIC_RSTN    0x00000fc0
+#define BCM2711_PM_GNRIC_ENAB    0x00001000
+#define BCM2711_PM_GNRIC_CFG     0x007f0000
+#define BCM2711_PM_AUDIO         (BCM2711_PM_BASE + 0x04)
+#define BCM2711_PM_AUDIO_APSM    0x000fffff
+#define BCM2711_PM_AUDIO_CTRLEN  0x00100000
+#define BCM2711_PM_AUDIO_RSTN    0x00200000
+#define BCM2711_PM_STATUS        (BCM2711_PM_BASE + 0x18)
+#define BCM2711_PM_RSTC          (BCM2711_PM_BASE + 0x1c)
+#define BCM2711_PM_RSTC_DRCFG    0x00000003
+#define BCM2711_PM_RSTC_WRCFG    0x00000030
+#define BCM2711_PM_RSTC_WRCFG_FULL   0x00000020
+#define BCM2711_PM_RSTC_SRCFG    0x00000300
+#define BCM2711_PM_RSTC_QRCFG    0x00003000
+#define BCM2711_PM_RSTC_FRCFG    0x00030000
+#define BCM2711_PM_RSTC_HRCFG    0x00300000
+#define BCM2711_PM_RSTS          (BCM2711_PM_BASE + 0x20)
+#define BCM2711_PM_RSTS_HADDRQ   0x00000001
+#define BCM2711_PM_RSTS_HADDRF   0x00000002
+#define BCM2711_PM_RSTS_HADDRH   0x00000004
+#define BCM2711_PM_RSTS_HADWRQ   0x00000010
+#define BCM2711_PM_RSTS_HADWRF   0x0000002
+#define BCM2711_PM_RSTS_HADWRH   0x00000040
+#define BCM2711_PM_RSTS_HADSRQ   0x00000100
+#define BCM2711_PM_RSTS_HADSRF   0x00000200
+#define BCM2711_PM_RSTS_HADSRH   0x00000400
+#define BCM2711_PM_RSTS_HADPOR   0x00001000
+#define BCM2711_PM_WDOG          (BCM2711_PM_BASE + 0x24)
+ * @name AUX Registers
+#define BCM2711_AUX_BASE         (RPI_PERIPHERAL_BASE + 0x215000)
+#define AUX_ENABLES              (BCM2711_AUX_BASE + 0x04)
+#define AUX_MU_IO_REG            (BCM2711_AUX_BASE + 0x40)
+#define AUX_MU_IER_REG           (BCM2711_AUX_BASE + 0x44)
+#define AUX_MU_IIR_REG           (BCM2711_AUX_BASE + 0x48)
+#define AUX_MU_LCR_REG           (BCM2711_AUX_BASE + 0x4C)
+#define AUX_MU_MCR_REG           (BCM2711_AUX_BASE + 0x50)
+#define AUX_MU_LSR_REG           (BCM2711_AUX_BASE + 0x54)
+#define AUX_MU_MSR_REG           (BCM2711_AUX_BASE + 0x58)
+#define AUX_MU_SCRATCH           (BCM2711_AUX_BASE + 0x5C)
+#define AUX_MU_CNTL_REG          (BCM2711_AUX_BASE + 0x60)
+#define AUX_MU_STAT_REG          (BCM2711_AUX_BASE + 0x64)
+#define AUX_MU_BAUD_REG          (BCM2711_AUX_BASE + 0x68)
+ * @name GPU Timer Registers
+ * NOTE: The GPU uses Compare registers 0 and 2 for
+ *       it's own RTOS. 1 and 3 are available for use in
+ *       RTEMS.
+#define BCM2711_GPU_TIMER_BASE    (RPI_PERIPHERAL_BASE + 0x3000)
+#define BCM2711_GPU_TIMER_CS      (BCM2711_GPU_TIMER_BASE + 0x00)
+#define BCM2711_GPU_TIMER_CS_M0      0x00000001
+#define BCM2711_GPU_TIMER_CS_M1      0x00000002
+#define BCM2711_GPU_TIMER_CS_M2      0x00000004
+#define BCM2711_GPU_TIMER_CS_M3      0x00000008
+#define BCM2711_GPU_TIMER_CLO     (BCM2711_GPU_TIMER_BASE + 0x04)
+#define BCM2711_GPU_TIMER_CHI     (BCM2711_GPU_TIMER_BASE + 0x08)
+#define BCM2711_GPU_TIMER_C0      (BCM2711_GPU_TIMER_BASE + 0x0C)
+#define BCM2711_GPU_TIMER_C1      (BCM2711_GPU_TIMER_BASE + 0x10)
+#define BCM2711_GPU_TIMER_C2      (BCM2711_GPU_TIMER_BASE + 0x14)
+#define BCM2711_GPU_TIMER_C3      (BCM2711_GPU_TIMER_BASE + 0x18)
+ * @name EMMC Registers
+ * NOTE: Since the SD controller follows the SDHCI standard,
+ *       the rtems-libbsd tree already provides the remaining registers.
+#define BCM2711_EMMC_BASE              (RPI_PERIPHERAL_BASE + 0x300000)
+* @name Mailbox Registers
+#define BCM2711_MBOX_BASE   (RPI_PERIPHERAL_BASE+0xB880)
+#define BCM2711_MBOX_READ   (BCM2711_MBOX_BASE+0x00)
+#define BCM2711_MBOX_PEEK   (BCM2711_MBOX_BASE+0x10)
+#define BCM2711_MBOX_SENDER (BCM2711_MBOX_BASE+0x14)
+#define BCM2711_MBOX_STATUS (BCM2711_MBOX_BASE+0x18)
+#define BCM2711_MBOX_WRITE  (BCM2711_MBOX_BASE+0x20)
+#define BCM2711_MBOX_CONFIG (BCM2711_MBOX_BASE+0x1C)
+#define BCM2711_MBOX_RESPONSE   0x80000000
+#define BCM2711_MBOX_FULL       0x80000000
+#define BCM2711_MBOX_EMPTY      0x40000000
+* @name Mailbox Channels
+/* Power Manager channel */
+#define BCM2711_MBOX_CHANNEL_PM         0
+/* Framebuffer channel */
+#define BCM2711_MBOX_CHANNEL_FB         1
+ /* Virtual UART channel */
+#define BCM2711_MBOX_CHANNEL_VUART      2
+ /* VCHIQ channel */
+#define BCM2711_MBOX_CHANNEL_VCHIQ      3
+ /* LEDs channel */
+#define BCM2711_MBOX_CHANNEL_LED        4
+ /* Button channel */
+#define BCM2711_MBOX_CHANNEL_BUTTON     5
+ /* Touch screen channel */
+#define BCM2711_MBOX_CHANNEL_TOUCHS     6
+#define BCM2711_MBOX_CHANNEL_COUNT      7
+/* Property tags (ARM <-> VC) channel */
+#define BCM2711_MBOX_CHANNEL_PROP_AVC   8
+ /* Property tags (VC <-> ARM) channel */
+#define BCM2711_MBOX_CHANNEL_PROP_VCA   9
+ * @name Raspberry Pi 2 Interrupt Register Defines
+/* Timers interrupt control registers */
+#define BCM2711_CORE0_TIMER_IRQ_CTRL_BASE       0xFF800040
+#define BCM2711_CORE1_TIMER_IRQ_CTRL_BASE       0xFF800044
+#define BCM2711_CORE2_TIMER_IRQ_CTRL_BASE       0xFF800048
+#define BCM2711_CORE3_TIMER_IRQ_CTRL_BASE       0xFF80004C
+#define BCM2711_CORE_TIMER_IRQ_CTRL(cpuidx) \
+  (BCM2711_CORE0_TIMER_IRQ_CTRL_BASE + 0x4 * (cpuidx))
+ * @name Raspberry Pi 4 ARM_LOCAL registers
+#define BCM2711_LOCAL_REGS_BASE		  		     	0x4C0000000
+#define BCM2711_LOCAL_REGS_SIZE               0x100
+#define BCM2711_LOCAL_ARM_CONTROL             (BCM2711_LOCAL_REGS_BASE + 0x00)
+#define BCM2711_LOCAL_CORE_IRQ_CONTROL        (BCM2711_LOCAL_REGS_BASE + 0x0c)
+#define BCM2711_LOCAL_PMU_CONTROL_SET         (BCM2711_LOCAL_REGS_BASE + 0x10)
+#define BCM2711_LOCAL_PMU_CONTROL_CLR         (BCM2711_LOCAL_REGS_BASE + 0x14)
+#define BCM2711_LOCAL_PERI_IRQ_ROUTE0 			  (BCM2711_LOCAL_REGS_BASE + 0x24)
+#define BCM2711_LOCAL_AXI_QUIET_TIME	 		    (BCM2711_LOCAL_REGS_BASE + 0x30)
+#define BCM2711_LOCAL_LOCAL_TIMER_CONTROL 		(BCM2711_LOCAL_REGS_BASE + 0x34)
+#define BCM2711_LOCAL_LOCAL_TIMER_IRQ	      	(BCM2711_LOCAL_REGS_BASE + 0x38)
+#define BCM2711_LOCAL_TIMER_CNTRL0      	    (BCM2711_LOCAL_REGS_BASE + 0x40)
+#define BCM2711_LOCAL_TIMER_CNTRL1			    	(BCM2711_LOCAL_REGS_BASE + 0x44)
+#define BCM2711_LOCAL_TIMER_CNTRL2  			  	(BCM2711_LOCAL_REGS_BASE + 0x48)
+#define BCM2711_LOCAL_TIMER_CNTRL3	  	  		(BCM2711_LOCAL_REGS_BASE + 0x4c)
+#define BCM2711_LOCAL_MAILBOX_CNTRL0 	    		(BCM2711_LOCAL_REGS_BASE + 0x50)
+#define BCM2711_LOCAL_MAILBOX_CNTRL1 	      	(BCM2711_LOCAL_REGS_BASE + 0x54)
+#define BCM2711_LOCAL_MAILBOX_CNTRL2 		     	(BCM2711_LOCAL_REGS_BASE + 0x58)
+#define BCM2711_LOCAL_MAILBOX_CNTRL3 	  		  (BCM2711_LOCAL_REGS_BASE + 0x5c)
+#define BCM2711_LOCAL_IRQ_SOURCE0   			  	(BCM2711_LOCAL_REGS_BASE + 0x60)
+#define BCM2711_LOCAL_IRQ_SOURCE1   			  	(BCM2711_LOCAL_REGS_BASE + 0x64)
+#define BCM2711_LOCAL_IRQ_SOURCE2   			  	(BCM2711_LOCAL_REGS_BASE + 0x68)
+#define BCM2711_LOCAL_IRQ_SOURCE3     				(BCM2711_LOCAL_REGS_BASE + 0x6c)
+#define BCM2711_LOCAL_FIQ_SOURCE0				      (BCM2711_LOCAL_REGS_BASE + 0x70)
+#define BCM2711_LOCAL_FIQ_SOURCE1				      (BCM2711_LOCAL_REGS_BASE + 0x74)
+#define BCM2711_LOCAL_FIQ_SOURCE2			      	(BCM2711_LOCAL_REGS_BASE + 0x78)
+#define BCM2711_LOCAL_FIQ_SOURCE3				      (BCM2711_LOCAL_REGS_BASE + 0x7c)
+ * @name Raspberry Pi 4 Mailbox registers
+#define BCM2711_MAILBOX_00_WRITE_SET_BASE  					0x4C000080
+#define BCM2711_MAILBOX_01_WRITE_SET_BASE  					0x4C000084
+#define BCM2711_MAILBOX_02_WRITE_SET_BASE  					0x4C000088
+#define BCM2711_MAILBOX_03_WRITE_SET_BASE  					0x4C00008C
+#define BCM2711_MAILBOX_04_WRITE_SET_BASE  					0x4C000090
+#define BCM2711_MAILBOX_05_WRITE_SET_BASE  					0x4C000094
+#define BCM2711_MAILBOX_06_WRITE_SET_BASE  					0x4C000098
+#define BCM2711_MAILBOX_07_WRITE_SET_BASE  					0x4C00009C
+#define BCM2711_MAILBOX_08_WRITE_SET_BASE  					0x4C0000A0
+#define BCM2711_MAILBOX_09_WRITE_SET_BASE  					0x4C0000A4
+#define BCM2711_MAILBOX_10_WRITE_SET_BASE  					0x4C0000A8
+#define BCM2711_MAILBOX_11_WRITE_SET_BASE  					0x4C0000AC
+#define BCM2711_MAILBOX_12_WRITE_SET_BASE  					0x4C0000B0
+#define BCM2711_MAILBOX_13_WRITE_SET_BASE  					0x4C0000B4
+#define BCM2711_MAILBOX_14_WRITE_SET_BASE  					0x4C0000B8
+#define BCM2711_MAILBOX_15_WRITE_SET_BASE  					0x4C0000BC
+#define BCM2711_MAILBOX_00_READ_CLEAR_BASE  				0x4C0000C0
+#define BCM2711_MAILBOX_01_READ_CLEAR_BASE  				0x4C0000C4
+#define BCM2711_MAILBOX_02_READ_CLEAR_BASE  				0x4C0000C8
+#define BCM2711_MAILBOX_03_READ_CLEAR_BASE  				0x4C0000CC
+#define BCM2711_MAILBOX_04_READ_CLEAR_BASE  				0x4C0000D0
+#define BCM2711_MAILBOX_05_READ_CLEAR_BASE  				0x4C0000D4
+#define BCM2711_MAILBOX_06_READ_CLEAR_BASE  				0x4C0000D8
+#define BCM2711_MAILBOX_07_READ_CLEAR_BASE  				0x4C0000DC
+#define BCM2711_MAILBOX_08_READ_CLEAR_BASE  				0x4C0000E0
+#define BCM2711_MAILBOX_09_READ_CLEAR_BASE  				0x4C0000E4
+#define BCM2711_MAILBOX_10_READ_CLEAR_BASE  				0x4C0000E8
+#define BCM2711_MAILBOX_11_READ_CLEAR_BASE  				0x4C0000EC
+#define BCM2711_MAILBOX_12_READ_CLEAR_BASE  				0x4C0000F0
+#define BCM2711_MAILBOX_13_READ_CLEAR_BASE  				0x4C0000F4
+#define BCM2711_MAILBOX_14_READ_CLEAR_BASE  				0x4C0000F8
+#define BCM2711_MAILBOX_15_READ_CLEAR_BASE  				0x4C0000FC
+ * @name Raspberry Pi 4 ARM_C FIQ and IRQ registers
+#define BCM2711_ARMC_REGS_BASE							  (RPI_PERIPHERAL_BASE + 0xB200)
+#define BCM2711_ARMC_REGS_SIZE                0x200
+#define BCM2711_ARMC_IRQ0_PENDING0 						(BCM2711_ARMC_REGS_BASE + 0x00)
+#define BCM2711_ARMC_IRQ0_PENDING1 						(BCM2711_ARMC_REGS_BASE + 0x04)
+#define BCM2711_ARMC_IRQ0_PENDING2 						(BCM2711_ARMC_REGS_BASE + 0x08)
+#define BCM2711_ARMC_IRQ0_SET_EN_0  					(BCM2711_ARMC_REGS_BASE + 0x10)
+#define BCM2711_ARMC_IRQ0_SET_EN_1  					(BCM2711_ARMC_REGS_BASE + 0x14)
+#define BCM2711_ARMC_IRQ0_SET_EN_2  					(BCM2711_ARMC_REGS_BASE + 0x18)
+#define BCM2711_ARMC_IRQ0_CLR_EN_0 						(BCM2711_ARMC_REGS_BASE + 0x20)
+#define BCM2711_ARMC_IRQ0_CLR_EN_1 						(BCM2711_ARMC_REGS_BASE + 0x24)
+#define BCM2711_ARMC_IRQ0_CLR_EN_2 						(BCM2711_ARMC_REGS_BASE + 0x28)
+#define BCM2711_ARMC_IRQ_STATUS0 						  (BCM2711_ARMC_REGS_BASE + 0x30)
+#define BCM2711_ARMC_IRQ_STATUS1 					  	(BCM2711_ARMC_REGS_BASE + 0x34)
+#define BCM2711_ARMC_IRQ_STATUS2 					 	  (BCM2711_ARMC_REGS_BASE + 0x38)
+#define BCM2711_ARMC_IRQ1_PENDING0 						(BCM2711_ARMC_REGS_BASE + 0x40)
+#define BCM2711_ARMC_IRQ1_PENDING1 						(BCM2711_ARMC_REGS_BASE + 0x44)
+#define BCM2711_ARMC_IRQ1_PENDING2 						(BCM2711_ARMC_REGS_BASE + 0x48)
+#define BCM2711_ARMC_IRQ1_SET_EN_0 						(BCM2711_ARMC_REGS_BASE + 0x50)
+#define BCM2711_ARMC_IRQ1_SET_EN_1 						(BCM2711_ARMC_REGS_BASE + 0x54)
+#define BCM2711_ARMC_IRQ1_SET_EN_2 						(BCM2711_ARMC_REGS_BASE + 0x58)
+#define BCM2711_ARMC_IRQ1_CLR_EN_0 						(BCM2711_ARMC_REGS_BASE + 0x60)
+#define BCM2711_ARMC_IRQ1_CLR_EN_1 						(BCM2711_ARMC_REGS_BASE + 0x64)
+#define BCM2711_ARMC_IRQ1_CLR_EN_2 						(BCM2711_ARMC_REGS_BASE + 0x68)
+#define BCM2711_ARMC_IRQ2_PENDING0 						(BCM2711_ARMC_REGS_BASE + 0x80)
+#define BCM2711_ARMC_IRQ2_PENDING1 						(BCM2711_ARMC_REGS_BASE + 0x84)
+#define BCM2711_ARMC_IRQ2_PENDING2 						(BCM2711_ARMC_REGS_BASE + 0x88)
+#define BCM2711_ARMC_IRQ2_SET_EN_0 						(BCM2711_ARMC_REGS_BASE + 0x90)
+#define BCM2711_ARMC_IRQ2_SET_EN_1 						(BCM2711_ARMC_REGS_BASE + 0x94)
+#define BCM2711_ARMC_IRQ2_SET_EN_2 						(BCM2711_ARMC_REGS_BASE + 0x98)
+#define BCM2711_ARMC_IRQ2_CLR_EN_0 						(BCM2711_ARMC_REGS_BASE + 0xA0)
+#define BCM2711_ARMC_IRQ2_CLR_EN_1 						(BCM2711_ARMC_REGS_BASE + 0xA4)
+#define BCM2711_ARMC_IRQ2_CLR_EN_2 						(BCM2711_ARMC_REGS_BASE + 0xA8)
+#define BCM2711_ARMC_IRQ3_PENDING0 						(BCM2711_ARMC_REGS_BASE + 0xC0)
+#define BCM2711_ARMC_IRQ3_PENDING1 						(BCM2711_ARMC_REGS_BASE + 0xC4)
+#define BCM2711_ARMC_IRQ3_PENDING2 						(BCM2711_ARMC_REGS_BASE + 0xC8)
+#define BCM2711_ARMC_IRQ3_SET_EN_0 						(BCM2711_ARMC_REGS_BASE + 0xD0)
+#define BCM2711_ARMC_IRQ3_SET_EN_1 						(BCM2711_ARMC_REGS_BASE + 0xD4)
+#define BCM2711_ARMC_IRQ3_SET_EN_2 						(BCM2711_ARMC_REGS_BASE + 0xD8)
+#define BCM2711_ARMC_IRQ3_CLR_EN_0 						(BCM2711_ARMC_REGS_BASE + 0xE0)
+#define BCM2711_ARMC_IRQ3_CLR_EN_1 						(BCM2711_ARMC_REGS_BASE + 0xE4)
+#define BCM2711_ARMC_IRQ3_CLR_EN_2 						(BCM2711_ARMC_REGS_BASE + 0xE8)
+#define BCM2711_ARMC_FIQ0_PENDING0 						(BCM2711_ARMC_REGS_BASE + 0x100)
+#define BCM2711_ARMC_FIQ0_PENDING1 						(BCM2711_ARMC_REGS_BASE + 0x104)
+#define BCM2711_ARMC_FIQ0_PENDING2 						(BCM2711_ARMC_REGS_BASE + 0x108)
+#define BCM2711_ARMC_FIQ0_SET_EN_0  					(BCM2711_ARMC_REGS_BASE + 0x110)
+#define BCM2711_ARMC_FIQ0_SET_EN_1  					(BCM2711_ARMC_REGS_BASE + 0x114)
+#define BCM2711_ARMC_FIQ0_SET_EN_2  					(BCM2711_ARMC_REGS_BASE + 0x118)
+#define BCM2711_ARMC_FIQ0_CLR_EN_0 						(BCM2711_ARMC_REGS_BASE + 0x120)
+#define BCM2711_ARMC_FIQ0_CLR_EN_1 						(BCM2711_ARMC_REGS_BASE + 0x124)
+#define BCM2711_ARMC_FIQ0_CLR_EN_2 						(BCM2711_ARMC_REGS_BASE + 0x128)
+#define BCM2711_ARMC_FIQ1_PENDING0 						(BCM2711_ARMC_REGS_BASE + 0x140)
+#define BCM2711_ARMC_FIQ1_PENDING1 						(BCM2711_ARMC_REGS_BASE + 0x144)
+#define BCM2711_ARMC_FIQ1_PENDING2 						(BCM2711_ARMC_REGS_BASE + 0x148)
+#define BCM2711_ARMC_FIQ1_SET_EN_0  					(BCM2711_ARMC_REGS_BASE + 0x150)
+#define BCM2711_ARMC_FIQ1_SET_EN_1  					(BCM2711_ARMC_REGS_BASE + 0x154)
+#define BCM2711_ARMC_FIQ1_SET_EN_2  					(BCM2711_ARMC_REGS_BASE + 0x158)
+#define BCM2711_ARMC_FIQ1_CLR_EN_0 						(BCM2711_ARMC_REGS_BASE + 0x160)
+#define BCM2711_ARMC_FIQ1_CLR_EN_1 						(BCM2711_ARMC_REGS_BASE + 0x164)
+#define BCM2711_ARMC_FIQ1_CLR_EN_2 						(BCM2711_ARMC_REGS_BASE + 0x168)
+#define BCM2711_ARMC_FIQ2_PENDING0 						(BCM2711_ARMC_REGS_BASE + 0x180)
+#define BCM2711_ARMC_FIQ2_PENDING1 						(BCM2711_ARMC_REGS_BASE + 0x184)
+#define BCM2711_ARMC_FIQ2_PENDING2 						(BCM2711_ARMC_REGS_BASE + 0x188)
+#define BCM2711_ARMC_FIQ2_SET_EN_0  					(BCM2711_ARMC_REGS_BASE + 0x190)
+#define BCM2711_ARMC_FIQ2_SET_EN_1  					(BCM2711_ARMC_REGS_BASE + 0x194)
+#define BCM2711_ARMC_FIQ2_SET_EN_2  					(BCM2711_ARMC_REGS_BASE + 0x198)
+#define BCM2711_ARMC_FIQ2_CLR_EN_0 						(BCM2711_ARMC_REGS_BASE + 0x1A0)
+#define BCM2711_ARMC_FIQ2_CLR_EN_1 						(BCM2711_ARMC_REGS_BASE + 0x1A4)
+#define BCM2711_ARMC_FIQ2_CLR_EN_2 						(BCM2711_ARMC_REGS_BASE + 0x1A8)
+#define BCM2711_ARMC_FIQ3_PENDING0 						(BCM2711_ARMC_REGS_BASE + 0x1C0)
+#define BCM2711_ARMC_FIQ3_PENDING1 						(BCM2711_ARMC_REGS_BASE + 0x1C4)
+#define BCM2711_ARMC_FIQ3_PENDING2 						(BCM2711_ARMC_REGS_BASE + 0x1C8)
+#define BCM2711_ARMC_FIQ3_SET_EN_0  					(BCM2711_ARMC_REGS_BASE + 0x1D0)
+#define BCM2711_ARMC_FIQ3_SET_EN_1  					(BCM2711_ARMC_REGS_BASE + 0x1D4)
+#define BCM2711_ARMC_FIQ3_SET_EN_2  					(BCM2711_ARMC_REGS_BASE + 0x1D8)
+#define BCM2711_ARMC_FIQ3_CLR_EN_0 						(BCM2711_ARMC_REGS_BASE + 0x1E0)
+#define BCM2711_ARMC_FIQ3_CLR_EN_1 						(BCM2711_ARMC_REGS_BASE + 0x1E4)
+#define BCM2711_ARMC_FIQ3_CLR_EN_2 						(BCM2711_ARMC_REGS_BASE + 0x1E8)
+#define BCM2711_ARMC_SWIRQ_SET  						  (BCM2711_ARMC_REGS_BASE + 0x1F0)
+#define BCM2711_ARMC_SWIRQ_CLEAR  						(BCM2711_ARMC_REGS_BASE + 0x1F4)
+#endif /* LIBBSP_ARM_RASPBERRYPI_RASPBERRYPI_H */
2.34.1
