[PATCH rtems-docs] raspberrypi4.rst: Added Documentation for the new AArch64 Raspberry pi 4B BSP
Mon Sep 26 07:10:14 UTC 2022
Hi,
Thanks for this. Looks good. I few minor issues.
Should memory sizes be discussed given there are a few models with different
sized memory?
Can the subject please be:
 user/raspberrypi4.rst: Added the AArch64 Raspberry pi 4B BSP
Minor nit has the end of the email ...
On 26/9/2022 4:52 pm, Mohd Noor Aman wrote:
> This patch adds the relevant documentations required for booting the new BSP. JTAG support is added for debugging. I have built the HTML docs and verified them.
Please update the commit message to be max 80 characters in width.
>  user/bsps/aarch64/raspberrypi4.rst | 92 ++++++++++++++++++++++++++++++
>  user/bsps/bsps-aarch64.rst         |  1 +
>  2 files changed, 93 insertions(+)
>  create mode 100644 user/bsps/aarch64/raspberrypi4.rst
> diff --git a/user/bsps/aarch64/raspberrypi4.rst b/user/bsps/aarch64/raspberrypi4.rst
> new file mode 100644
> index 0000000..94daacf
> --- /dev/null
> +++ b/user/bsps/aarch64/raspberrypi4.rst
> @@ -0,0 +1,92 @@
> +.. SPDX-License-Identifier: CC-BY-SA-4.0
> +.. Copyright (C) 2022 Mohd Noor Aman
> +.. _BSP_aarch64_Raspberrypi_4:
> +Raspberry Pi 4B
> +The 'raspberrypi4b' BSP currently supports only the LP64 ABI. Raspberry pi 4B
> +and Raspberry Pi 400  are supported. The default bootloader which is used by the
> +Raspbian OS or other OS can be used to boot the RTEMS. Currently, QEMU is not
> +supported. This BSP supports the GICv2 interrupt controller.
> +Clock Driver
> +The clock driver uses the `ARM Generic Timer`.
> +Console Driver
> +The console driver supports the default Qemu emulated ARM PL011 PrimeCell UART
> +as well as the physical ARM PL011 PrimeCell UART in the raspberrypi hardware.
> +Only UART0 is supported as of now.
> +Preparing to boot
> +Raspberry Pi uses a different mechanism to boot. First the GPU initializes,
> +loads the bootloader and then looks for the kernel img. By default the arm64
> +mode looks for the ``kernel8.img``. Any other kernel can be loaded by adding
> +`kernel=<img_name>` to the ``config.txt``.
> +The Firmware files are required in order to boot RTEMS. The latest firmware can
> +be downloaded from the `Raspberry Pi Firmware Repository
> +<https://github.com/raspberrypi/firmware/>`_. USB boot is supported. All the
> +files (Firmwares and kernel) must be place in the FAT32 partition only. Add
> +``arm_64bit=1`` in the config.txt file in order to boot the BSP in 64bit kernel
> +mode.
> +UART Setup
> +Connect your serial device to the GPIO15 and GPIO14. Add the following to the
> +config.txt file in order to use the PL011 UART0.
> +.. code-block:: none
> +  dtoverlay = disable-bt
> +  enable_uart=1
> +Generating kernel image
> +The following steps show how to run ``hello.exe`` on the BSP. Other executables
> +can be processed in a similar way.
> +To create the kernel image:
> +.. code-block:: shell
> +  $ aarch64-rtems at rtems-ver-major@-objcopy -Obinary hello.exe kernel8.img
> +Copy the kernel image to the SD card.
> +JTAG Setup
> +The Raspberry Pi 4 doesn't have dedicated JTAG pins. Instead, you must configure
> +the GPIO pins (GPIO22-GPIO27) to activate the JTAG functionality. The RPi 4
> +documentation refers to this as Alt4 functions of those pins. Alt5 does exist
> +too, which goes from GPIO4, 5, 6, 12 and 13. you can check this out from
> +`pinout.xyz <https://pinout.xyz/pinout/jtag#>`_ or `eLinux
> +<https://elinux.org/RPi_BCM2835_GPIOs>`_
> +One more thing to note on JTAG with Raspberry pi 4B is that, by default, All the
> +GPIO pins are pulled down, according to the `BCM2711 documentation
> +<https://datasheets.raspberrypi.com/bcm2711/bcm2711-peripherals.pdf>`_. This
> +wasn't the case in the earlier models. So in order to let the data flow freely,
> +we will have to disable them.
> +  # Disable pull downs
> +  gpio=22-27=np
> +  # Enable jtag pins (i.e. GPIO22-GPIO27)
> +  enable_jtag_gpio=1
> diff --git a/user/bsps/bsps-aarch64.rst b/user/bsps/bsps-aarch64.rst
> index 933370f..f3aa15c 100644
> --- a/user/bsps/bsps-aarch64.rst
> +++ b/user/bsps/bsps-aarch64.rst
> @@ -9,3 +9,4 @@ aarch64 (AArch64)
>  .. include:: aarch64/a72.rst>  .. include:: aarch64/xilinx-versal.rst
>  .. include:: aarch64/xilinx-zynqmp.rst
> +.. include:: aarch64/raspberrypi4.rst
Can the order please be sorted?
Thanks
