[PATCH] c-user: Add application config info directives
Fri Sep 30 13:46:42 UTC 2022
On 17/09/2022 09:31, Chris Johns wrote:
>> +rtems_configuration_get_stack_allocate_init_hook()
>> +Gets the thread stack allocator initialization hook configured for this
>> +application.
>> +.. rubric:: CALLING SEQUENCE:
>> +.. code-block:: c
>> +    #define rtems_configuration_get_stack_allocate_init_hook()
>> +.. rubric:: RETURN VALUES:
>> +Returns the thread stack allocator initialization hook configured for this
>> +application.
> The hooks being documented should specify the hook interface and then what and
> when you would use this and under what constraints, ie what is locked, services
> you can use etc.
Yes, but this doesn't belong to this location.
>> +.. rubric:: NOTES:
>> +See :ref:`CONFIGURE_TASK_STACK_ALLOCATOR_INIT`.
It should be added to the configuration options.
embedded brains GmbH
Herr Sebastian HUBER
Dornierstr. 4
82178 Puchheim
Germany
phone: +49-89-18 94 741 - 16
fax:   +49-89-18 94 741 - 08
Registernummer: HRB 157899
