[PATCH RTEMS] mvme3100: Add BSP fatal extension
Vijay Kumar Banerjee vijay at rtems.org
Tue Aug 1 16:41:08 UTC 2023
 bsps/powerpc/mvme3100/start/bspclean.c        | 25 +++++++++++++++++++
 .../bsps/powerpc/mvme3100/bspmvme3100.yml     |  1 +
 2 files changed, 26 insertions(+)
 create mode 100644 bsps/powerpc/mvme3100/start/bspclean.c
diff --git a/bsps/powerpc/mvme3100/start/bspclean.c b/bsps/powerpc/mvme3100/start/bspclean.c
new file mode 100644
index 0000000000..251d47a46d
--- /dev/null
+++ b/bsps/powerpc/mvme3100/start/bspclean.c
@@ -0,0 +1,25 @@
+#include <bsp.h>
+#include <bsp/bootcard.h>
+#include <rtems/bspIo.h>
+void bsp_fatal_extension(
+  rtems_fatal_source source,
+  bool always_set_to_false,
+  rtems_fatal_code error
+  printk("fatal source: %s\n", rtems_fatal_source_text(source));
+  if (source == RTEMS_FATAL_SOURCE_EXCEPTION) {
+    rtems_exception_frame_print((const rtems_exception_frame *) error);
+  /* We can't go back to MotLoad since we blew it's memory area
+   * and vectors. Just pull the reset line...
+  printk(
+    "bsp_fatal_extension(): RTEMS terminated -- no way back to MotLoad "
+      "so I reset the card\n"
+  bsp_reset();
diff --git a/spec/build/bsps/powerpc/mvme3100/bspmvme3100.yml b/spec/build/bsps/powerpc/mvme3100/bspmvme3100.yml
index 1667c1617a..dc04e4dd36 100644
--- a/spec/build/bsps/powerpc/mvme3100/bspmvme3100.yml
+++ b/spec/build/bsps/powerpc/mvme3100/bspmvme3100.yml
@@ -64,6 +64,7 @@ source:
 - bsps/powerpc/mvme3100/pci/detect_host_bridge.c
 - bsps/powerpc/mvme3100/rtc/todcfg.c
 - bsps/powerpc/mvme3100/start/bspstart.c
+- bsps/powerpc/mvme3100/start/bspclean.c
 - bsps/powerpc/mvme3100/start/misc.c
 - bsps/powerpc/shared/btimer/btimer-ppc-dec.c
 - bsps/powerpc/shared/cache/cache.c
2.39.3
