[PATCH RTEMS] mvme3100: Add BSP fatal extension
Vijay Kumar Banerjee vijay at rtems.org
Tue Aug 1 19:52:19 UTC 2023
On Tue, Aug 1, 2023, 12:20 Joel Sherrill <joel at rtems.org> wrote:
> On Tue, Aug 1, 2023, 11:41 AM Vijay Kumar Banerjee <vijay at rtems.org>
> wrote:
>>  bsps/powerpc/mvme3100/start/bspclean.c        | 25 +++++++++++++++++++
>>  .../bsps/powerpc/mvme3100/bspmvme3100.yml     |  1 +
>>  2 files changed, 26 insertions(+)
>>  create mode 100644 bsps/powerpc/mvme3100/start/bspclean.c
>> diff --git a/bsps/powerpc/mvme3100/start/bspclean.c
>> b/bsps/powerpc/mvme3100/start/bspclean.c
>> new file mode 100644
>> index 0000000000..251d47a46d
>> --- /dev/null
>> +++ b/bsps/powerpc/mvme3100/start/bspclean.c
>> @@ -0,0 +1,25 @@
> There is no copyright, licence, or Doxygen file header block.
> +#include <bsp.h>
>> +#include <bsp/bootcard.h>
>> +#include <rtems/bspIo.h>
>> +void bsp_fatal_extension(
>> +  rtems_fatal_source source,
>> +  bool always_set_to_false,
>> +  rtems_fatal_code error
>> +  printk("fatal source: %s\n", rtems_fatal_source_text(source));
>> +  if (source == RTEMS_FATAL_SOURCE_EXCEPTION) {
>> +    rtems_exception_frame_print((const rtems_exception_frame *) error);
>> +  /* We can't go back to MotLoad since we blew it's memory area
>> +   * and vectors. Just pull the reset line...
>> +  printk(
>> +    "bsp_fatal_extension(): RTEMS terminated -- no way back to MotLoad "
>> +      "so I reset the card\n"
>> +  bsp_reset();
> What does Motorola PowerPC or the other similar bsps do?
> Can the behaviour be unified and shared?
Thanks for the suggestion!
Motorola powerpc uses bspfatal-default.c from bsps/shared. It was not
working with mvme3100 because it added the bspreset-empty in the build.
Just removing the empty reset makes it work. This patch is no longer
needed. I'll send a smaller patch with this much neater solution using the
shared defaults.
Thanks!
> diff --git a/spec/build/bsps/powerpc/mvme3100/bspmvme3100.yml
>> b/spec/build/bsps/powerpc/mvme3100/bspmvme3100.yml
>> index 1667c1617a..dc04e4dd36 100644
>> --- a/spec/build/bsps/powerpc/mvme3100/bspmvme3100.yml
>> +++ b/spec/build/bsps/powerpc/mvme3100/bspmvme3100.yml
>> @@ -64,6 +64,7 @@ source:
>>  - bsps/powerpc/mvme3100/pci/detect_host_bridge.c
>>  - bsps/powerpc/mvme3100/rtc/todcfg.c
>>  - bsps/powerpc/mvme3100/start/bspstart.c
>> +- bsps/powerpc/mvme3100/start/bspclean.c
>>  - bsps/powerpc/mvme3100/start/misc.c
>>  - bsps/powerpc/shared/btimer/btimer-ppc-dec.c
>>  - bsps/powerpc/shared/cache/cache.c
>> 2.39.3
>> devel mailing list
>> devel at rtems.org
URL: <http://lists.rtems.org/pipermail/devel/attachments/20230801/d54e010f/attachment.htm>
