[PATCH RTEMS] spec: Remove empty reset from mvme3100
Tue Aug 1 21:51:34 UTC 2023
OK
Thanks
On 2/8/2023 6:16 am, Vijay Kumar Banerjee wrote:
>  spec/build/bsps/powerpc/mvme3100/bspmvme3100.yml | 1 -
>  1 file changed, 1 deletion(-)
> diff --git a/spec/build/bsps/powerpc/mvme3100/bspmvme3100.yml b/spec/build/bsps/powerpc/mvme3100/bspmvme3100.yml
> index 1667c1617a..fbb85123f0 100644
> --- a/spec/build/bsps/powerpc/mvme3100/bspmvme3100.yml
> +++ b/spec/build/bsps/powerpc/mvme3100/bspmvme3100.yml
> @@ -86,6 +86,5 @@ source:
>  - bsps/shared/dev/getentropy/getentropy-cpucounter.c
>  - bsps/shared/dev/rtc/rtc-support.c
>  - bsps/shared/start/bspfatal-default.c
> -- bsps/shared/start/bspreset-empty.c
>  - bsps/shared/start/gettargethash-default.c
>  type: build
