[PATCH] build: Add PROGRAM_PREFIX option
Wed Aug 2 08:50:09 UTC 2023
On 2/8/2023 6:39 pm, Sebastian Huber wrote:
> On 02.08.23 10:33, Chris Johns wrote:
>>> diff --git a/spec/build/bsps/makeinc.yml b/spec/build/bsps/makeinc.yml
>>> index ac395f2f02..08fc75a8b9 100644
>>> --- a/spec/build/bsps/makeinc.yml
>>> +++ b/spec/build/bsps/makeinc.yml
>>> @@ -16,14 +16,14 @@ content: |
>>>     prefix = ${PREFIX}
>>>     exec_prefix = $${prefix}/${ARCH}-rtems${__RTEMS_MAJOR__}
>>>   -  CC_FOR_TARGET = ${ARCH}-rtems${__RTEMS_MAJOR__}-gcc
>>> -  CXX_FOR_TARGET = ${ARCH}-rtems${__RTEMS_MAJOR__}-g++
>>> -  AS_FOR_TARGET = ${ARCH}-rtems${__RTEMS_MAJOR__}-as
>>> -  AR_FOR_TARGET = ${ARCH}-rtems${__RTEMS_MAJOR__}-ar
>>> -  NM_FOR_TARGET = ${ARCH}-rtems${__RTEMS_MAJOR__}-nm
>>> -  LD_FOR_TARGET = ${ARCH}-rtems${__RTEMS_MAJOR__}-ld
>>> -  SIZE_FOR_TARGET = ${ARCH}-rtems${__RTEMS_MAJOR__}-size
>>> -  OBJCOPY_FOR_TARGET = ${ARCH}-rtems${__RTEMS_MAJOR__}-objcopy
>>> +  CC_FOR_TARGET = ${PROGRAM_PREFIX}gcc
>>> +  CXX_FOR_TARGET = ${PROGRAM_PREFIX}g++
>> Is it worth doing the same to gcc and g++ as well so these can be replaced as
>> well?
> Yes, but this would be another patch and it is a bit more work since you have to
> test the clang support.
>>> +  AS_FOR_TARGET = ${PROGRAM_PREFIX}as
>>> +  AR_FOR_TARGET = ${PROGRAM_PREFIX}ar
>>> +  NM_FOR_TARGET = ${PROGRAM_PREFIX}nm
>>> +  LD_FOR_TARGET = ${PROGRAM_PREFIX}ld
>>> +  SIZE_FOR_TARGET = ${PROGRAM_PREFIX}size
>>> +  OBJCOPY_FOR_TARGET = ${PROGRAM_PREFIX}objcopy
>> Where is PROGRAM_PFREFIX set?
> It is a new configuration option:
> [sparc/gr740]
> PROGRAM_PREFIX = ${ARCH}-rtems7-
Yes, but if these files are installed does it need to be in defined in those files?
