[PATCH] libdebugger: Restrict ARM architecture support
Thu Aug 3 12:17:59 UTC 2023
Build the arm libdebugger support only for supported ARM architectures.
This fixes assembler errors at -O0.
Close #4939.
 cpukit/libdebugger/rtems-debugger-arm.c | 24 +++++++++---------------
 1 file changed, 9 insertions(+), 15 deletions(-)
diff --git a/cpukit/libdebugger/rtems-debugger-arm.c b/cpukit/libdebugger/rtems-debugger-arm.c
index cdc615ce64..0d1ad6c63a 100644
--- a/cpukit/libdebugger/rtems-debugger-arm.c
+++ b/cpukit/libdebugger/rtems-debugger-arm.c
@@ -281,6 +281,7 @@ do { \
 RTEMS_INTERRUPT_LOCK_DEFINE(static, target_lock, "target_lock")
+#if ARM_CP15
  * An exception offset is added to the return address of the PC on an
  * exception's stack frame. The PC needs to be adjusted.
@@ -292,6 +293,7 @@ static const size_t exc_offsets[2][5] =
   /* TMB undef_ins sup call pref abt data abt */
   {  0,  2,        0,       4,       8 }
+#endif
  * Is a session active?
@@ -1156,6 +1158,7 @@ arm_debug_break_c14_write_value(int bp, uint32_t value)
+#if ARM_CP15
 static uint32_t
 arm_debug_dbgdscr_read(void)
@@ -1185,6 +1188,7 @@ arm_debug_method_of_entry(void)
   return (arm_debug_dbgdscr_read() >> 2) & 0xf;
+#endif
 static void
 arm_debug_disable_interrupts(void)
@@ -1192,11 +1196,13 @@ arm_debug_disable_interrupts(void)
   debug_disable_ints = 1;
+#if ARM_CP15
 static void
 arm_debug_enable_interrupts(void)
   arm_debug_dbgdscr_write(arm_debug_dbgdscr_read() & ~(1 << 11));
+#endif
 static void
 arm_debug_break_clear(int bp)
@@ -1290,6 +1296,7 @@ arm_debug_break_exec_enable(int bp, uintptr_t addr, bool thumb, bool step) {
     ARM_HW_BP_PRIV_PL0_SUP_SYS);
+#if ARM_CP15
 static void
 arm_debug_break_dump(void)
@@ -1303,6 +1310,7 @@ arm_debug_break_dump(void)
 #endif
+#endif
 #if NOT_USED_BUT_KEEPING
 static size_t
@@ -1331,6 +1339,7 @@ rtems_debugger_target_configure(rtems_debugger_target* target)
   return arm_debug_probe(target);
+#if ARM_CP15
 static void
 target_print_frame(CPU_Exception_frame* frame)
@@ -1348,13 +1357,9 @@ static void
 target_exception(CPU_Exception_frame* frame)
 #if TARGET_DEBUG
-#if ARM_CP15
   const uint32_t ifsr = arm_cp15_get_instruction_fault_status();
   const uint32_t dfsr = arm_cp15_get_data_fault_status();
   const void* far = arm_cp15_get_fault_address();
-#else
-  const uint32_t ifsr = 0;
-#endif
   const uint32_t mvector = frame->vector;
   const uint32_t dbgdscr = arm_debug_dbgdscr_read();
 #endif
@@ -1468,7 +1473,6 @@ target_exception(CPU_Exception_frame* frame)
  * Set all the break point registers to 0. Enable interrupts.
-#if ARM_CP15
 #define ARM_HW_BP_UNLOAD(_bp)                                           \
     "cmp r0, #" #_bp "\n"                                               \
     "ble 3f\n"                                                          \
@@ -1830,7 +1834,6 @@ arm_debug_unlock_abort(void)
   ARM_SWITCH_BACK;
   longjmp(unlock_abort_jmpbuf, -1);
-#endif
 static void __attribute__((naked))
 target_exception_undefined_instruction(void)
@@ -1882,7 +1885,6 @@ target_exception_data_abort(void)
   EXCEPTION_EXIT(frame);
-#if ARM_CP15
 #if __ARM_ARCH_PROFILE == 'A'
  * The init value for the text section.
@@ -1933,14 +1935,6 @@ rtems_debugger_target_set_vectors(void)
    * Dummy, please add support for your ARM variant.
-  void* ui = target_exception_undefined_instruction;
-  void* sc = target_exception_supervisor_call;
-  void* pa = target_exception_prefetch_abort;
-  void* da = target_exception_data_abort;
-  (void) ui;
-  (void) sc;
-  (void) pa;
-  (void) da;
 static void
2.35.3
