[PATCH 2/3] bsps/riscv: Handle ":" in chosen stdout-path
Kevin Eyssartier kevin.eyssartier at thalesgroup.com
Thu Aug 3 13:29:34 UTC 2023
The riscv_get_console_node function is searching the devices for the string specified in chosen in the fdt.
Unfortunately, this chosen string can contain parameters after the ":" character.
As specified in https://www.kernel.org/doc/Documentation/devicetree/bindings/chosen.txt :
    If the character ":" is present in the value, this terminates the path.
This was not handled in the function.
 bsps/riscv/riscv/console/console-config.c | 5 ++++-
 1 file changed, 4 insertions(+), 1 deletion(-)
diff --git a/bsps/riscv/riscv/console/console-config.c b/bsps/riscv/riscv/console/console-config.c
index 4916191e0b..a49aa82b46 100644
--- a/bsps/riscv/riscv/console/console-config.c
+++ b/bsps/riscv/riscv/console/console-config.c
@@ -91,6 +91,9 @@ static int riscv_get_console_node(const void *fdt)
     stdout_path = "";
+  const char *q = memchr(stdout_path, ':', strlen(stdout_path));
+  const int stdout_path_len = q == NULL ? strlen(stdout_path) : q-stdout_path;
 #if RISCV_ENABLE_FRDME310ARTY_SUPPORT != 0
   int root;
   int soc;
@@ -101,7 +104,7 @@ static int riscv_get_console_node(const void *fdt)
   return offset;
 #else
-  return fdt_path_offset(fdt, stdout_path);
+  return fdt_path_offset_namelen(fdt, stdout_path, stdout_path_len);
 #endif
2.25.1
