[PATCH 1/3] Adding core-v cv32a6 support
Thu Aug 3 16:11:23 UTC 2023
On 03.08.23 15:29, Kevin Eyssartier wrote:
> This commit add support for the CV32A6 processor in the rv32imac configuration.
> The CORE-V CVA6 is an application class 6 stage RISC-V CPU capable of booting Linux.
> It support multiple configurations : ISA (IMACFDB), XLEN 32 and 64, configurable cache size, TLBs, PTW and branch prediction.
> It is maintained by the not-for-profit [OpenHW Group](https://www.openhwgroup.org/).
> Its code is under the Solderpad Hardware License which is based closely on the Apache Licese Version 2.0.
> It can be found at [https://github.com/openhardware/cva6](https://github.com/openhardware/cva6).
> This commit support the cv32a6_imac_sv[0|32] configurations.
> RTEMS has been tested on the [Genesys2 Digilent FPGA Board](https://digilent.com/reference/programmable-logic/genesys-2/start).
>   bsps/riscv/riscv/config/cv32a6.cfg        |  9 +++++++++
The *.cfg files are no longer used.
>   spec/build/bsps/riscv/riscv/bspcv32a6.yml | 19 +++++++++++++++++++
>   spec/build/cpukit/optarchbits.yml         |  1 +
>   3 files changed, 29 insertions(+)
>   create mode 100644 bsps/riscv/riscv/config/cv32a6.cfg
>   create mode 100644 spec/build/bsps/riscv/riscv/bspcv32a6.yml
Why do you need this BSP variant? Can't you use the rv32imac BSP?
embedded brains GmbH
Herr Sebastian HUBER
Dornierstr. 4
82178 Puchheim
Germany
phone: +49-89-18 94 741 - 16
fax:   +49-89-18 94 741 - 08
Registernummer: HRB 157899
