[PATCH] psxkey07: Fix POSIX key value pair configuration
Joel Sherrill joel.sherrill at gmail.com
Fri Aug 4 13:21:57 UTC 2023
On Fri, Aug 4, 2023 at 2:59 AM Sebastian Huber <
> Make sure we have enough POSIX key value pairs available.  This fixes a
> test
> failure on some targets.
> Make objects and functions static.  Initialize variable to get rid of
> warnings.
>  testsuites/psxtests/psxkey07/init.c | 42 ++++++++++++++---------------
>  1 file changed, 20 insertions(+), 22 deletions(-)
> diff --git a/testsuites/psxtests/psxkey07/init.c
> b/testsuites/psxtests/psxkey07/init.c
> index 15387264ba..ff7b3a0bd0 100644
> --- a/testsuites/psxtests/psxkey07/init.c
> +++ b/testsuites/psxtests/psxkey07/init.c
> @@ -39,32 +39,27 @@
>  const char rtems_test_name[] = "PSXKEY 7";
> -/* forward declarations to avoid warnings */
> -rtems_task Init(rtems_task_argument argument);
> -rtems_task Test_Thread(rtems_task_argument argument);
> +#define INITIAL_TASK_COUNT 10
> -pthread_key_t Key;
> -int created_thread_count, setted_thread_count, got_thread_count;
> -int all_thread_created;
> -pthread_mutex_t mutex1, mutex2;
> -pthread_cond_t create_condition_var, set_condition_var;
> +#define ADDITIONAL_TASK_COUNT 13
> +static pthread_key_t Key;
> +static int created_thread_count, setted_thread_count, got_thread_count;
> +static int all_thread_created;
> +static pthread_mutex_t mutex1, mutex2;
> +static pthread_cond_t create_condition_var, set_condition_var;
> +static rtems_task Test_Thread(rtems_task_argument argument)
>    int sc;
>    int *value_p, *value_p2;
>    value_p = malloc( sizeof( int ) );
>    rtems_test_assert(value_p != NULL);
> - * This was added to address the following warning.
> - * warning: 'value_p' may be used uninitialized
> -#pragma GCC diagnostic push
> -#pragma GCC diagnostic ignored "-Wmaybe-uninitialized"
> - sc = pthread_setspecific( Key, value_p );
> -#pragma GCC diagnostic pop
> - rtems_test_assert( !sc );
> +  *value_p = 123;
> +  sc = pthread_setspecific( Key, value_p );
> +  rtems_test_assert( !sc );
>    pthread_mutex_lock( &mutex1 );
>    ++setted_thread_count;
> @@ -86,12 +81,13 @@ rtems_task Test_Thread(rtems_task_argument argument)
>    rtems_task_exit();
> +static rtems_task Init(rtems_task_argument argument)
>    rtems_status_code  rc;
>    int                sc;
>    struct timespec    delay_request;
> -  uintptr_t          max_free_size = 13 * RTEMS_MINIMUM_STACK_SIZE;
> +  uintptr_t          max_free_size =
> +                       ADDITIONAL_TASK_COUNT * RTEMS_MINIMUM_STACK_SIZE;
>    void              *greedy;
>    all_thread_created = 0;
> @@ -222,8 +218,10 @@ rtems_task Init(rtems_task_argument argument)
>  #define CONFIGURE_INITIAL_EXTENSIONS RTEMS_TEST_INITIAL_EXTENSION
> -#define CONFIGURE_MAXIMUM_TASKS          rtems_resource_unlimited(10)
> -#define CONFIGURE_MAXIMUM_POSIX_KEYS     1
> +#define CONFIGURE_MAXIMUM_TASKS
> rtems_resource_unlimited(INITIAL_TASK_COUNT)
> +#define CONFIGURE_MAXIMUM_POSIX_KEYS 1
> +#define CONFIGURE_MAXIMUM_POSIX_KEY_VALUE_PAIRS \
> +  (INITIAL_TASK_COUNT + ADDITIONAL_TASK_COUNT)
>  #define CONFIGURE_UNIFIED_WORK_AREAS
>  #define CONFIGURE_RTEMS_INIT_TASKS_TABLE
> 2.35.3
> devel mailing list
> devel at rtems.org
URL: <http://lists.rtems.org/pipermail/devel/attachments/20230804/07cf3404/attachment.htm>
