[PATCH 1/2] bsps/aarch64/raspberrypi: Refactor code base
Kinsey Moore kinsey.moore at oarcorp.com
Mon Aug 7 15:57:51 UTC 2023
That sounds fine to me.
Thanks,
Kinsey
On Mon, Aug 7, 2023 at 10:53 AM Utkarsh Verma <utkarsh at bitbanged.com> wrote:
> Hi Kinsey,
> Thanks for the suggestions. I'll break it up into several commits as
> you suggested. Shall I break it down as follows?
> - Build spec changes
> - Formatting changes
> - Macro renamings
> Regards,
> Utkarsh
> On Mon, Aug 7, 2023 at 8:49 PM Kinsey Moore <kinsey.moore at oarcorp.com>
> wrote:
>> I would say that the content here is easily worth several patches. You've
>> got header rearrangements and other formatting changes mixed in with macro
>> renamings, build system changes, and other things. One comment below on the
>> .gitignore. You've also got inconsistencies in usage of (C) vs (c).
>> On Sun, Aug 6, 2023 at 11:49 PM Utkarsh Verma <utkarsh at bitbanged.com>
>> wrote:
>>> From: Utkarsh Verma <utkarshverma at protonmail.com>
>>> Refactor the code base for better organization to facilitate future
>>> patches.
>>>  .gitignore                                    |   4 +
>>>  bsps/aarch64/raspberrypi/console/console.c    |  42 +-
>>>  bsps/aarch64/raspberrypi/include/bsp.h        |  33 +-
>>>  .../aarch64/raspberrypi/include/bsp/bcm2711.h |  98 ++++
>>>  bsps/aarch64/raspberrypi/include/bsp/irq.h    |  94 ++--
>>>  .../raspberrypi/include/bsp/raspberrypi.h     | 471 ------------------
>>>  .../include/bsp/start/bspstartmmu.h           |   8 +
>>>  bsps/aarch64/raspberrypi/start/bspstart.c     |  18 +-
>>>  .../aarch64/raspberrypi/start/bspstarthooks.c |  26 +-
>>>  bsps/aarch64/raspberrypi/start/bspstartmmu.c  |  66 +--
>>>  spec/build/bsps/aarch64/raspberrypi/abi.yml   |  37 +-
>>>  spec/build/bsps/aarch64/raspberrypi/bsp4b.yml |  23 +
>>>  .../aarch64/raspberrypi/bspraspberrypi4.yml   |  72 ---
>>>  spec/build/bsps/aarch64/raspberrypi/grp.yml   |  49 ++
>>>  spec/build/bsps/aarch64/raspberrypi/grp4b.yml |  26 +
>>>  .../{linkercmds.yml => linkcmds.yml}          |  25 +-
>>>  spec/build/bsps/aarch64/raspberrypi/obj.yml   |  50 ++
>>>  .../aarch64/raspberrypi/objconsolepl011.yml   |  24 +
>>>  .../aarch64/raspberrypi/optclockpl011freq.yml |  23 +
>>>  .../aarch64/raspberrypi/optconsolebaud.yml    |  23 +
>>>  20 files changed, 487 insertions(+), 725 deletions(-)
>>>  create mode 100644 bsps/aarch64/raspberrypi/include/bsp/bcm2711.h
>>>  delete mode 100644 bsps/aarch64/raspberrypi/include/bsp/raspberrypi.h
>>>  create mode 100644
>>> bsps/aarch64/raspberrypi/include/bsp/start/bspstartmmu.h
>>>  create mode 100644 spec/build/bsps/aarch64/raspberrypi/bsp4b.yml
>>>  delete mode 100644
>>> spec/build/bsps/aarch64/raspberrypi/bspraspberrypi4.yml
>>>  create mode 100644 spec/build/bsps/aarch64/raspberrypi/grp.yml
>>>  create mode 100644 spec/build/bsps/aarch64/raspberrypi/grp4b.yml
>>>  rename spec/build/bsps/aarch64/raspberrypi/{linkercmds.yml =>
>>> linkcmds.yml} (90%)
>>>  create mode 100644 spec/build/bsps/aarch64/raspberrypi/obj.yml
>>>  create mode 100644
>>> spec/build/bsps/aarch64/raspberrypi/objconsolepl011.yml
>>>  create mode 100644
>>> spec/build/bsps/aarch64/raspberrypi/optclockpl011freq.yml
>>>  create mode 100644
>>> spec/build/bsps/aarch64/raspberrypi/optconsolebaud.yml
>>> diff --git a/.gitignore b/.gitignore
>>> index 8b28b186e1..d0144f6737 100644
>>> --- a/.gitignore
>>> +++ b/.gitignore
>>> @@ -12,3 +12,7 @@ Makefile.in
>>>  /testsuites/build/build
>>>  /testsuites/build/wscript
>>>  .waf*
>>> +.clangd
>>> +.clang-format
>>> +compile_commands.json
>>> +.cache/
>> While the clang and cache entries here are probably reasonable to go
>> upstream, I don't think "compile_commands.json" is.
>>> diff --git a/bsps/aarch64/raspberrypi/console/console.c
>>> b/bsps/aarch64/raspberrypi/console/console.c
>>> index 73bb0036ff..4aba0ec73e 100644
>>> --- a/bsps/aarch64/raspberrypi/console/console.c
>>> +++ b/bsps/aarch64/raspberrypi/console/console.c
>>> @@ -3,13 +3,14 @@
>>>   * @file
>>> - * @ingroup RTEMSBSPsAArch64Raspberrypi4
>>> + * @ingroup RTEMSBSPsAArch64RaspberryPi
>>>   * @brief Console Configuration
>>> - * Copyright (C) 2022 Mohd Noor Aman
>>> + * Copyright (c) 2022 Mohd Noor Aman
>>> + * Copyright (c) 2023 Utkarsh Verma
>>>   * Redistribution and use in source and binary forms, with or without
>>> @@ -34,36 +35,33 @@
>>>   * POSSIBILITY OF SUCH DAMAGE.
>>> -#include <rtems/bspIo.h>
>>> -#include <bsp.h>
>>> -#include <dev/serial/arm-pl011.h>
>>>  #include <bsp/console-termios.h>
>>>  #include <bspopts.h>
>>> +#include <dev/serial/arm-pl011.h>
>>> +#include <rtems/bspIo.h>
>>> -arm_pl011_context raspberrypi_4_context = {
>>> -  .base = RTEMS_TERMIOS_DEVICE_CONTEXT_INITIALIZER("PL011"),
>>> -  .regs = (volatile pl011 *) BSP_RPI4_PL011_BASE,
>>> -  .initial_baud = 115200
>>> +#include "bsp.h"
>>> +arm_pl011_context uart0 = {
>>> +    .base         = RTEMS_TERMIOS_DEVICE_CONTEXT_INITIALIZER("PL011"),
>>> +    .regs         = (volatile pl011 *)BSP_UART0_BASE,
>>> +    .initial_baud = BSP_CONSOLE_BAUD,
>>>  const console_device console_device_table[] = {
>>> -    .device_file = "/dev/ttyS0",
>>> -    .probe = console_device_probe_default,
>>> -    .handler = &arm_pl011_fns,
>>> -    .context = &raspberrypi_4_context.base
>>> +        .device_file = "/dev/ttyAMA0",
>>> +        .probe       = console_device_probe_default,
>>> +        .handler     = &arm_pl011_fns,
>>> +        .context     = &uart0.base,
>>>  const size_t console_device_count =
>>> RTEMS_ARRAY_SIZE(console_device_table);
>>> -static void output_char( char c )
>>> -  arm_pl011_write_polled(&raspberrypi_4_context.base, c);
>>> +static void output_char(char c) {
>>> +    arm_pl011_write_polled(&uart0.base, c);
>>> -BSP_output_char_function_type BSP_output_char = output_char;
>>> +BSP_output_char_function_type BSP_output_char   = output_char;
>>>  BSP_polling_getchar_function_type BSP_poll_char = NULL;
>>> diff --git a/bsps/aarch64/raspberrypi/include/bsp.h
>>> b/bsps/aarch64/raspberrypi/include/bsp.h
>>> index 4fa81edd40..0c2b4c98eb 100644
>>> --- a/bsps/aarch64/raspberrypi/include/bsp.h
>>> +++ b/bsps/aarch64/raspberrypi/include/bsp.h
>>> @@ -3,13 +3,14 @@
>>>   * @file
>>>   * @brief Core BSP definitions
>>> + * Copyright (C) 2023 Utkarsh Verma
>>> @@ -34,8 +35,8 @@
>>> -#ifndef LIBBSP_AARCH64_RASPBERRYPI_4_BSP_H
>>> -#define LIBBSP_AARCH64_RASPBERRYPI_4_BSP_H
>>> +#ifndef LIBBSP_AARCH64_RASPBERRYPI_BSP_H
>>> +#define LIBBSP_AARCH64_RASPBERRYPI_BSP_H
>>>   * @addtogroup RTEMSBSPsAArch64
>>> @@ -48,26 +49,18 @@
>>>  #ifndef ASM
>>>  #include <bsp/default-initial-extension.h>
>>> -#include <bsp/start.h>
>>> -#include <rtems.h>
>>> +#if RTEMS_BSP == raspberrypi4b
>>> +#include "bsp/bcm2711.h"
>>> -/*Raspberry pi MMU initialization */
>>> -BSP_START_TEXT_SECTION void raspberrypi_4_setup_mmu_and_cache(void);
>>> +#define BSP_GIC_BASE           BCM2711_GIC_BASE
>>> +#define BSP_GIC_SIZE           BCM2711_GIC_SIZE
>>> +#define BSP_ARM_GIC_CPUIF_BASE BCM2711_GIC_CPUIF_BASE
>>> +#define BSP_ARM_GIC_DIST_BASE  BCM2711_GIC_DIST_BASE
>>> -#ifdef __cplusplus
>>> -extern "C" {
>>> -#endif /* __cplusplus */
>>> -#define BSP_ARM_GIC_CPUIF_BASE 0xFF842000
>>> -#define BSP_ARM_GIC_DIST_BASE 0xFF841000
>>> -#define BSP_RPI4_PL011_BASE 0xFE201000
>>> -#define BSP_RPI4_PL011_LENGTH 0x200
>>> -#ifdef __cplusplus
>>> +#define BSP_UART0_BASE BCM2711_UART0_BASE
>>> +#define BSP_UART0_SIZE BCM2711_UART0_SIZE
>>> +#endif /* raspberrypi4b */
>>>  #endif /* ASM */
>>> diff --git a/bsps/aarch64/raspberrypi/include/bsp/bcm2711.h
>>> b/bsps/aarch64/raspberrypi/include/bsp/bcm2711.h
>>> new file mode 100644
>>> index 0000000000..885dad8af9
>>> --- /dev/null
>>> +++ b/bsps/aarch64/raspberrypi/include/bsp/bcm2711.h
>>> @@ -0,0 +1,98 @@
>>> +/* SPDX-License-Identifier: BSD-2-Clause */
>>> + * @file
>>> + * @brief Register definitions
>>> + * Copyright (C) 2022 Mohd Noor Aman
>>> + * Redistribution and use in source and binary forms, with or without
>>> + * modification, are permitted provided that the following conditions
>>> + * are met:
>>> + * 1. Redistributions of source code must retain the above copyright
>>> + *    notice, this list of conditions and the following disclaimer.
>>> + * 2. Redistributions in binary form must reproduce the above copyright
>>> + *    notice, this list of conditions and the following disclaimer in
>>> the
>>> + *    documentation and/or other materials provided with the
>>> distribution.
>>> + * THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS
>>> "AS IS"
>>> + * AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED
>>> TO, THE
>>> + * IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR
>>> PURPOSE
>>> + * ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR
>>> CONTRIBUTORS BE
>>> + * LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR
>>> + * CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF
>>> + * SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR
>>> BUSINESS
>>> + * INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER
>>> IN
>>> + * CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR
>>> OTHERWISE)
>>> + * ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED
>>> OF THE
>>> + * POSSIBILITY OF SUCH DAMAGE.
>>> +#ifndef LIBBSP_AARCH64_RASPBERRYPI_BSP_BCM2711_H
>>> +#define LIBBSP_AARCH64_RASPBERRYPI_BSP_BCM2711_H
>>> +#include <stdint.h>
>>> +#define BCM2711_REG(addr) (*(uint32_t*)(addr))
>>> + * NOTE:
>>> + * Raspberry Pi 4B boots into low peripheral mode by default.
>>> + * The addresses are specified in the BCM2711 peripherals datashseet in
>>> Fig 1.
>>> +#define BCM2711_PERIPHERAL_BASE 0xfc000000LL
>>> +#define BCM2711_PERIPHERAL_SIZE 0x3800000
>>> +/* Mailbox */
>>> +#define BCM2711_MBOX_BASE (BCM2711_PERIPHERAL_BASE + 0x200B880)
>>> +/* GPIO */
>>> +#define BCM2711_GPIO_BASE (BCM2711_PERIPHERAL_BASE + 0x2200000)
>>> +#define BCM2711_GPIO_SIZE 0xf4
>>> +/* AUX */
>>> +#define BCM2711_AUX_BASE (BCM2711_PERIPHERAL_BASE + 0x2215000)
>>> +#define BCM2711_AUX_SIZE 0x100
>>> +/* AUX: Mini UART */
>>> +#define BCM2711_AUX_MU_BASE (BCM2711_AUX_BASE + 0x40)
>>> +#define BCM2711_AUX_MU_SIZE 0x40
>>> +#define BCM2711_UART1_BASE BCM2711_AUX_MU_BASE
>>> +#define BCM2711_UART1_SIZE BCM2711_AUX_MU_SIZE
>>> +/* PL011 UARTs */
>>> +#define BCM2711_PL011_BASE        (BCM2711_PERIPHERAL_BASE + 0x2201000)
>>> +#define BCM2711_PL011_SIZE        0xc00
>>> +#define BCM2711_PL011_DEVICE_SIZE 0x200
>>> +#define BCM2711_UART0_BASE (BCM2711_PL011_BASE + 0x000)
>>> +#define BCM2711_UART0_SIZE BCM2711_PL011_DEVICE_SIZE
>>> +#define BCM2711_UART2_BASE (BCM2711_PL011_BASE + 0x400)
>>> +#define BCM2711_UART2_SIZE BCM2711_PL011_DEVICE_SIZE
>>> +#define BCM2711_UART3_BASE (BCM2711_PL011_BASE + 0x600)
>>> +#define BCM2711_UART3_SIZE BCM2711_PL011_DEVICE_SIZE
>>> +#define BCM2711_UART4_BASE (BCM2711_PL011_BASE + 0x800)
>>> +#define BCM2711_UART4_SIZE BCM2711_PL011_DEVICE_SIZE
>>> +#define BCM2711_UART5_BASE (BCM2711_PL011_BASE + 0xa00)
>>> +#define BCM2711_UART5_SIZE BCM2711_PL011_DEVICE_SIZE
>>> +/* ARM Local */
>>> +#define BCM2711_ARM_LOCAL_BASE 0xff800000LL
>>> +#define BCM2711_ARM_LOCAL_SIZE 0x800000
>>> +/* Generic interrupt controller */
>>> +#define BCM2711_GIC_BASE (BCM2711_ARM_LOCAL_BASE + 0x40000)
>>> +#define BCM2711_GIC_SIZE 0x8000
>>> +#define BCM2711_GIC_DIST_BASE  (BCM2711_GIC_BASE + 0x1000)
>>> +#define BCM2711_GIC_CPUIF_BASE (BCM2711_GIC_BASE + 0x2000)
>>> +#endif /* LIBBSP_AARCH64_RASPBERRYPI_BCM2711_H */
>>> diff --git a/bsps/aarch64/raspberrypi/include/bsp/irq.h
>>> b/bsps/aarch64/raspberrypi/include/bsp/irq.h
>>> index effec1b040..1e84cd3ea2 100644
>>> --- a/bsps/aarch64/raspberrypi/include/bsp/irq.h
>>> +++ b/bsps/aarch64/raspberrypi/include/bsp/irq.h
>>> @@ -7,8 +7,8 @@
>>> - * Copyright (c) 2013 Alan Cudmore
>>> - * Copyright (c) 2022 Mohd Noor Aman
>>> + * Copyright (C) 2013 Alan Cudmore
>>>   *  The license and distribution terms for this file may be
>>>   *  found in the file LICENSE in this distribution or at
>>> @@ -17,15 +17,15 @@
>>> -#ifndef LIBBSP_ARM_RASPBERRYPI_IRQ_H
>>> -#define LIBBSP_ARM_RASPBERRYPI_IRQ_H
>>> +#ifndef LIBBSP_AARCH64_RASPBERRYPI_BSP_IRQ_H
>>> +#define LIBBSP_AARCH64_RASPBERRYPI_BSP_IRQ_H
>>>  #ifndef ASM
>>> +#include <dev/irq/arm-gic-irq.h>
>>>  #include <rtems.h>
>>> -#include <rtems/irq.h>
>>>  #include <rtems/irq-extension.h>
>>> -#include <dev/irq/arm-gic-irq.h>
>>> +#include <rtems/irq.h>
>>>  #if defined(RTEMS_SMP)
>>>  #include <rtems/score/processormask.h>
>>> @@ -39,31 +39,31 @@
>>>   * @brief Interrupt support.
>>> -#define BCM2835_INTC_TOTAL_IRQ       (64 + 8)
>>> -#define BCM2835_IRQ_SET1_MIN         0
>>> -#define BCM2835_IRQ_SET2_MIN         32
>>> -#define BCM2835_IRQ_ID_GPU_TIMER_M0  0
>>> -#define BCM2835_IRQ_ID_GPU_TIMER_M1  1
>>> -#define BCM2835_IRQ_ID_GPU_TIMER_M2  2
>>> -#define BCM2835_IRQ_ID_GPU_TIMER_M3  3
>>> -#define BCM2835_IRQ_ID_USB           9
>>> -#define BCM2835_IRQ_ID_AUX           29
>>> -#define BCM2835_IRQ_ID_SPI_SLAVE     43
>>> -#define BCM2835_IRQ_ID_PWA0          45
>>> -#define BCM2835_IRQ_ID_PWA1          46
>>> -#define BCM2835_IRQ_ID_SMI           48
>>> -#define BCM2835_IRQ_ID_GPIO_0        49
>>> -#define BCM2835_IRQ_ID_GPIO_1        50
>>> -#define BCM2835_IRQ_ID_GPIO_2        51
>>> -#define BCM2835_IRQ_ID_GPIO_3        52
>>> -#define BCM2835_IRQ_ID_I2C           53
>>> -#define BCM2835_IRQ_ID_SPI           54
>>> -#define BCM2835_IRQ_ID_PCM           55
>>> -#define BCM2835_IRQ_ID_UART          57
>>> -#define BCM2835_IRQ_ID_SD            62
>>> +#define BCM2835_INTC_TOTAL_IRQ (64 + 8)
>>> +#define BCM2835_IRQ_SET1_MIN 0
>>> +#define BCM2835_IRQ_SET2_MIN 32
>>> +#define BCM2835_IRQ_ID_GPU_TIMER_M0 0
>>> +#define BCM2835_IRQ_ID_GPU_TIMER_M1 1
>>> +#define BCM2835_IRQ_ID_GPU_TIMER_M2 2
>>> +#define BCM2835_IRQ_ID_GPU_TIMER_M3 3
>>> +#define BCM2835_IRQ_ID_USB       9
>>> +#define BCM2835_IRQ_ID_AUX       29
>>> +#define BCM2835_IRQ_ID_SPI_SLAVE 43
>>> +#define BCM2835_IRQ_ID_PWA0      45
>>> +#define BCM2835_IRQ_ID_PWA1      46
>>> +#define BCM2835_IRQ_ID_SMI       48
>>> +#define BCM2835_IRQ_ID_GPIO_0    49
>>> +#define BCM2835_IRQ_ID_GPIO_1    50
>>> +#define BCM2835_IRQ_ID_GPIO_2    51
>>> +#define BCM2835_IRQ_ID_GPIO_3    52
>>> +#define BCM2835_IRQ_ID_I2C       53
>>> +#define BCM2835_IRQ_ID_SPI       54
>>> +#define BCM2835_IRQ_ID_PCM       55
>>> +#define BCM2835_IRQ_ID_UART      57
>>> +#define BCM2835_IRQ_ID_SD        62
>>>  #define BCM2835_IRQ_ID_BASIC_BASE_ID 64
>>>  #define BCM2835_IRQ_ID_TIMER_0       64
>>> @@ -74,34 +74,28 @@
>>>  #define BCM2835_IRQ_ID_GPU1_HALTED   69
>>>  #define BCM2835_IRQ_ID_ILL_ACCESS_1  70
>>>  #define BCM2835_IRQ_ID_ILL_ACCESS_0  71
>>> -#define BSP_TIMER_VIRT_PPI 27
>>> -#define BSP_TIMER_PHYS_NS_PPI 30
>>> -#define BSP_VPL011_SPI 32
>>> +#define BSP_TIMER_VIRT_PPI           27
>>> +#define BSP_TIMER_PHYS_NS_PPI        30
>>> +#define BSP_VPL011_SPI               32
>>> -#define BSP_INTERRUPT_VECTOR_COUNT    BCM2835_INTC_TOTAL_IRQ
>>> +#define BSP_INTERRUPT_VECTOR_COUNT   BCM2835_INTC_TOTAL_IRQ
>>>  #define BSP_INTERRUPT_VECTOR_INVALID (UINT32_MAX)
>>> -#define BSP_IRQ_COUNT               (BCM2835_INTC_TOTAL_IRQ)
>>> +#define BSP_IRQ_COUNT (BCM2835_INTC_TOTAL_IRQ)
>>>  static inline rtems_status_code bsp_interrupt_set_affinity(
>>> -  rtems_vector_number   vector,
>>> -  const Processor_mask *affinity
>>> -  (void) vector;
>>> -  (void) affinity;
>>> -  return RTEMS_UNSATISFIED;
>>> +    rtems_vector_number vector, const Processor_mask *affinity) {
>>> +    (void)vector;
>>> +    (void)affinity;
>>> +    return RTEMS_UNSATISFIED;
>>>  static inline rtems_status_code bsp_interrupt_get_affinity(
>>> -  Processor_mask      *affinity
>>> -  (void) vector;
>>> -  _Processor_mask_From_index( affinity, 0 );
>>> +    rtems_vector_number vector, Processor_mask *affinity) {
>>> +    (void)vector;
>>> +    _Processor_mask_From_index(affinity, 0);
>>>  #endif
>>> diff --git a/bsps/aarch64/raspberrypi/include/bsp/raspberrypi.h
>>> b/bsps/aarch64/raspberrypi/include/bsp/raspberrypi.h
>>> deleted file mode 100644
>>> index 55dd9ed1e9..0000000000
>>> --- a/bsps/aarch64/raspberrypi/include/bsp/raspberrypi.h
>>> +++ /dev/null
>>> @@ -1,471 +0,0 @@
>>> - * @file
>>> - * @ingroup raspberrypi_4_regs
>>> - * @brief Register definitions.
>>> - *  The license and distribution terms for this file may be
>>> - *  found in the file LICENSE in this distribution or at
>>> - *  http://www.rtems.org/license/LICENSE
>>> -#ifndef LIBBSP_AARCH64_RASPBERRYPI_RASPBERRYPI_4_H
>>> -#define LIBBSP_AARCH64_RASPBERRYPI_RASPBERRYPI_4_H
>>> -#include <bspopts.h>
>>> -#include <stdint.h>
>>> -#include <bsp/utility.h>
>>> - * @defgroup raspberrypi_reg Register Definitions
>>> - * @ingroup RTEMSBSPsARMRaspberryPi
>>> - * @brief Register Definitions
>>> - * @name Register Macros
>>> -#define BCM2711_REG(x)           (*(volatile uint64_t *)(x))
>>> -#define BCM2711_BIT(n)           (1 << (n))
>>> - * @name Peripheral Base Register Address
>>> -#define RPI_PERIPHERAL_BASE         0xFE000000
>>> -#define BASE_OFFSET                 0xFE000000
>>> -#define RPI_PERIPHERAL_SIZE         0x01800000
>>> - * @name Bus to Physical address translation
>>> - *       Macro.
>>> -#define BUS_TO_PHY(x)            ((x) - BASE_OFFSET)
>>> - * @name Internal ARM Timer Registers
>>> -#define BCM2711_CLOCK_FREQ       250000000
>>> -#define BCM2711_TIMER_BASE       (RPI_PERIPHERAL_BASE + 0xB400)
>>> -#define BCM2711_TIMER_LOD        (BCM2711_TIMER_BASE + 0x00)
>>> -#define BCM2711_TIMER_VAL        (BCM2711_TIMER_BASE + 0x04)
>>> -#define BCM2711_TIMER_CTL        (BCM2711_TIMER_BASE + 0x08)
>>> -#define BCM2711_TIMER_CLI        (BCM2711_TIMER_BASE + 0x0C)
>>> -#define BCM2711_TIMER_RIS        (BCM2711_TIMER_BASE + 0x10)
>>> -#define BCM2711_TIMER_MIS        (BCM2711_TIMER_BASE + 0x14)
>>> -#define BCM2711_TIMER_RLD        (BCM2711_TIMER_BASE + 0x18)
>>> -#define BCM2711_TIMER_DIV        (BCM2711_TIMER_BASE + 0x1C)
>>> -#define BCM2711_TIMER_CNT        (BCM2711_TIMER_BASE + 0x20)
>>> -#define BCM2711_TIMER_PRESCALE    0xF9
>>> - * @name Power Management and Watchdog  Registers
>>> -#define BCM2711_PM_PASSWD_MAGIC  0x5a000000
>>> -#define BCM2711_PM_BASE          (RPI_PERIPHERAL_BASE + 0x100000)
>>> -#define BCM2711_PM_GNRIC         (BCM2711_PM_BASE + 0x00)
>>> -#define BCM2711_PM_GNRIC_POWUP   0x00000001
>>> -#define BCM2711_PM_GNRIC_POWOK   0x00000002
>>> -#define BCM2711_PM_GNRIC_ISPOW   0x00000004
>>> -#define BCM2711_PM_GNRIC_MEMREP  0x00000008
>>> -#define BCM2711_PM_GNRIC_MRDONE  0x00000010
>>> -#define BCM2711_PM_GNRIC_ISFUNC  0x00000020
>>> -#define BCM2711_PM_GNRIC_RSTN    0x00000fc0
>>> -#define BCM2711_PM_GNRIC_ENAB    0x00001000
>>> -#define BCM2711_PM_GNRIC_CFG     0x007f0000
>>> -#define BCM2711_PM_AUDIO         (BCM2711_PM_BASE + 0x04)
>>> -#define BCM2711_PM_AUDIO_APSM    0x000fffff
>>> -#define BCM2711_PM_AUDIO_CTRLEN  0x00100000
>>> -#define BCM2711_PM_AUDIO_RSTN    0x00200000
>>> -#define BCM2711_PM_STATUS        (BCM2711_PM_BASE + 0x18)
>>> -#define BCM2711_PM_RSTC          (BCM2711_PM_BASE + 0x1c)
>>> -#define BCM2711_PM_RSTC_DRCFG    0x00000003
>>> -#define BCM2711_PM_RSTC_WRCFG    0x00000030
>>> -#define BCM2711_PM_RSTC_WRCFG_FULL   0x00000020
>>> -#define BCM2711_PM_RSTC_SRCFG    0x00000300
>>> -#define BCM2711_PM_RSTC_QRCFG    0x00003000
>>> -#define BCM2711_PM_RSTC_FRCFG    0x00030000
>>> -#define BCM2711_PM_RSTC_HRCFG    0x00300000
>>> -#define BCM2711_PM_RSTS          (BCM2711_PM_BASE + 0x20)
>>> -#define BCM2711_PM_RSTS_HADDRQ   0x00000001
>>> -#define BCM2711_PM_RSTS_HADDRF   0x00000002
>>> -#define BCM2711_PM_RSTS_HADDRH   0x00000004
>>> -#define BCM2711_PM_RSTS_HADWRQ   0x00000010
>>> -#define BCM2711_PM_RSTS_HADWRF   0x0000002
>>> -#define BCM2711_PM_RSTS_HADWRH   0x00000040
>>> -#define BCM2711_PM_RSTS_HADSRQ   0x00000100
>>> -#define BCM2711_PM_RSTS_HADSRF   0x00000200
>>> -#define BCM2711_PM_RSTS_HADSRH   0x00000400
>>> -#define BCM2711_PM_RSTS_HADPOR   0x00001000
>>> -#define BCM2711_PM_WDOG          (BCM2711_PM_BASE + 0x24)
>>> - * @name AUX Registers
>>> -#define BCM2711_AUX_BASE         (RPI_PERIPHERAL_BASE + 0x215000)
>>> -#define AUX_ENABLES              (BCM2711_AUX_BASE + 0x04)
>>> -#define AUX_MU_IO_REG            (BCM2711_AUX_BASE + 0x40)
>>> -#define AUX_MU_IER_REG           (BCM2711_AUX_BASE + 0x44)
>>> -#define AUX_MU_IIR_REG           (BCM2711_AUX_BASE + 0x48)
>>> -#define AUX_MU_LCR_REG           (BCM2711_AUX_BASE + 0x4C)
>>> -#define AUX_MU_MCR_REG           (BCM2711_AUX_BASE + 0x50)
>>> -#define AUX_MU_LSR_REG           (BCM2711_AUX_BASE + 0x54)
>>> -#define AUX_MU_MSR_REG           (BCM2711_AUX_BASE + 0x58)
>>> -#define AUX_MU_SCRATCH           (BCM2711_AUX_BASE + 0x5C)
>>> -#define AUX_MU_CNTL_REG          (BCM2711_AUX_BASE + 0x60)
>>> -#define AUX_MU_STAT_REG          (BCM2711_AUX_BASE + 0x64)
>>> -#define AUX_MU_BAUD_REG          (BCM2711_AUX_BASE + 0x68)
>>> - * @name GPU Timer Registers
>>> - * NOTE: The GPU uses Compare registers 0 and 2 for
>>> - *       it's own RTOS. 1 and 3 are available for use in
>>> - *       RTEMS.
>>> -#define BCM2711_GPU_TIMER_BASE       (RPI_PERIPHERAL_BASE + 0x3000)
>>> -#define BCM2711_GPU_TIMER_CS         (BCM2711_GPU_TIMER_BASE + 0x00)
>>> -#define BCM2711_GPU_TIMER_CS_M0      0x00000001
>>> -#define BCM2711_GPU_TIMER_CS_M1      0x00000002
>>> -#define BCM2711_GPU_TIMER_CS_M2      0x00000004
>>> -#define BCM2711_GPU_TIMER_CS_M3      0x00000008
>>> -#define BCM2711_GPU_TIMER_CLO        (BCM2711_GPU_TIMER_BASE + 0x04)
>>> -#define BCM2711_GPU_TIMER_CHI        (BCM2711_GPU_TIMER_BASE + 0x08)
>>> -#define BCM2711_GPU_TIMER_C0         (BCM2711_GPU_TIMER_BASE + 0x0C)
>>> -#define BCM2711_GPU_TIMER_C1         (BCM2711_GPU_TIMER_BASE + 0x10)
>>> -#define BCM2711_GPU_TIMER_C2         (BCM2711_GPU_TIMER_BASE + 0x14)
>>> -#define BCM2711_GPU_TIMER_C3         (BCM2711_GPU_TIMER_BASE + 0x18)
>>> - * @name EMMC Registers
>>> - * NOTE: Since the SD controller follows the SDHCI standard,
>>> - *       the rtems-libbsd tree already provides the remaining registers.
>>> -#define BCM2711_EMMC_BASE           (RPI_PERIPHERAL_BASE + 0x300000)
>>> -* @name Mailbox Registers
>>> -#define BCM2711_MBOX_BASE          (RPI_PERIPHERAL_BASE+0xB880)
>>> -#define BCM2711_MBOX_READ          (BCM2711_MBOX_BASE+0x00)
>>> -#define BCM2711_MBOX_PEEK          (BCM2711_MBOX_BASE+0x10)
>>> -#define BCM2711_MBOX_SENDER        (BCM2711_MBOX_BASE+0x14)
>>> -#define BCM2711_MBOX_STATUS        (BCM2711_MBOX_BASE+0x18)
>>> -#define BCM2711_MBOX_WRITE         (BCM2711_MBOX_BASE+0x20)
>>> -#define BCM2711_MBOX_CONFIG        (BCM2711_MBOX_BASE+0x1C)
>>> -#define BCM2711_MBOX_RESPONSE      0x80000000
>>> -#define BCM2711_MBOX_FULL          0x80000000
>>> -#define BCM2711_MBOX_EMPTY         0x40000000
>>> -* @name Mailbox Channels
>>> -/* Power Manager channel */
>>> -#define BCM2711_MBOX_CHANNEL_PM         0
>>> -/* Framebuffer channel */
>>> -#define BCM2711_MBOX_CHANNEL_FB         1
>>> - /* Virtual UART channel */
>>> -#define BCM2711_MBOX_CHANNEL_VUART      2
>>> - /* VCHIQ channel */
>>> -#define BCM2711_MBOX_CHANNEL_VCHIQ      3
>>> - /* LEDs channel */
>>> -#define BCM2711_MBOX_CHANNEL_LED        4
>>> - /* Button channel */
>>> -#define BCM2711_MBOX_CHANNEL_BUTTON     5
>>> - /* Touch screen channel */
>>> -#define BCM2711_MBOX_CHANNEL_TOUCHS     6
>>> -#define BCM2711_MBOX_CHANNEL_COUNT      7
>>> -/* Property tags (ARM <-> VC) channel */
>>> -#define BCM2711_MBOX_CHANNEL_PROP_AVC   8
>>> - /* Property tags (VC <-> ARM) channel */
>>> -#define BCM2711_MBOX_CHANNEL_PROP_VCA   9
>>> - * @name Raspberry Pi 2 Interrupt Register Defines
>>> -/* Timers interrupt control registers */
>>> -#define BCM2711_CORE0_TIMER_IRQ_CTRL_BASE       0xFF800040
>>> -#define BCM2711_CORE1_TIMER_IRQ_CTRL_BASE       0xFF800044
>>> -#define BCM2711_CORE2_TIMER_IRQ_CTRL_BASE       0xFF800048
>>> -#define BCM2711_CORE3_TIMER_IRQ_CTRL_BASE       0xFF80004C
>>> -#define BCM2711_CORE_TIMER_IRQ_CTRL(cpuidx) \
>>> -  (BCM2711_CORE0_TIMER_IRQ_CTRL_BASE + 0x4 * (cpuidx))
>>> - * @name Raspberry Pi 4 ARM_LOCAL registers
>>> -#define BCM2711_LOCAL_REGS_BASE               0x4C0000000
>>> -#define BCM2711_LOCAL_REGS_SIZE               0x100
>>> -#define BCM2711_LOCAL_ARM_CONTROL             (BCM2711_LOCAL_REGS_BASE
>>> + 0x00)
>>> -#define BCM2711_LOCAL_CORE_IRQ_CONTROL        (BCM2711_LOCAL_REGS_BASE
>>> + 0x0c)
>>> -#define BCM2711_LOCAL_PMU_CONTROL_SET         (BCM2711_LOCAL_REGS_BASE
>>> + 0x10)
>>> -#define BCM2711_LOCAL_PMU_CONTROL_CLR         (BCM2711_LOCAL_REGS_BASE
>>> + 0x14)
>>> -#define BCM2711_LOCAL_PERI_IRQ_ROUTE0         (BCM2711_LOCAL_REGS_BASE
>>> + 0x24)
>>> -#define BCM2711_LOCAL_AXI_QUIET_TIME          (BCM2711_LOCAL_REGS_BASE
>>> + 0x30)
>>> -#define BCM2711_LOCAL_LOCAL_TIMER_CONTROL     (BCM2711_LOCAL_REGS_BASE
>>> + 0x34)
>>> -#define BCM2711_LOCAL_LOCAL_TIMER_IRQ         (BCM2711_LOCAL_REGS_BASE
>>> + 0x38)
>>> -#define BCM2711_LOCAL_TIMER_CNTRL0            (BCM2711_LOCAL_REGS_BASE
>>> + 0x40)
>>> -#define BCM2711_LOCAL_TIMER_CNTRL1            (BCM2711_LOCAL_REGS_BASE
>>> + 0x44)
>>> -#define BCM2711_LOCAL_TIMER_CNTRL2            (BCM2711_LOCAL_REGS_BASE
>>> + 0x48)
>>> -#define BCM2711_LOCAL_TIMER_CNTRL3            (BCM2711_LOCAL_REGS_BASE
>>> + 0x4c)
>>> -#define BCM2711_LOCAL_MAILBOX_CNTRL0          (BCM2711_LOCAL_REGS_BASE
>>> + 0x50)
>>> -#define BCM2711_LOCAL_MAILBOX_CNTRL1          (BCM2711_LOCAL_REGS_BASE
>>> + 0x54)
>>> -#define BCM2711_LOCAL_MAILBOX_CNTRL2          (BCM2711_LOCAL_REGS_BASE
>>> + 0x58)
>>> -#define BCM2711_LOCAL_MAILBOX_CNTRL3          (BCM2711_LOCAL_REGS_BASE
>>> + 0x5c)
>>> -#define BCM2711_LOCAL_IRQ_SOURCE0             (BCM2711_LOCAL_REGS_BASE
>>> + 0x60)
>>> -#define BCM2711_LOCAL_IRQ_SOURCE1             (BCM2711_LOCAL_REGS_BASE
>>> + 0x64)
>>> -#define BCM2711_LOCAL_IRQ_SOURCE2             (BCM2711_LOCAL_REGS_BASE
>>> + 0x68)
>>> -#define BCM2711_LOCAL_IRQ_SOURCE3             (BCM2711_LOCAL_REGS_BASE
>>> + 0x6c)
>>> -#define BCM2711_LOCAL_FIQ_SOURCE0             (BCM2711_LOCAL_REGS_BASE
>>> + 0x70)
>>> -#define BCM2711_LOCAL_FIQ_SOURCE1             (BCM2711_LOCAL_REGS_BASE
>>> + 0x74)
>>> -#define BCM2711_LOCAL_FIQ_SOURCE2             (BCM2711_LOCAL_REGS_BASE
>>> + 0x78)
>>> -#define BCM2711_LOCAL_FIQ_SOURCE3             (BCM2711_LOCAL_REGS_BASE
>>> + 0x7c)
>>> - * @name Raspberry Pi 4 Mailbox registers
>>> -#define BCM2711_MAILBOX_00_WRITE_SET_BASE               0x4C000080
>>> -#define BCM2711_MAILBOX_01_WRITE_SET_BASE               0x4C000084
>>> -#define BCM2711_MAILBOX_02_WRITE_SET_BASE               0x4C000088
>>> -#define BCM2711_MAILBOX_03_WRITE_SET_BASE               0x4C00008C
>>> -#define BCM2711_MAILBOX_04_WRITE_SET_BASE               0x4C000090
>>> -#define BCM2711_MAILBOX_05_WRITE_SET_BASE               0x4C000094
>>> -#define BCM2711_MAILBOX_06_WRITE_SET_BASE               0x4C000098
>>> -#define BCM2711_MAILBOX_07_WRITE_SET_BASE               0x4C00009C
>>> -#define BCM2711_MAILBOX_08_WRITE_SET_BASE               0x4C0000A0
>>> -#define BCM2711_MAILBOX_09_WRITE_SET_BASE               0x4C0000A4
>>> -#define BCM2711_MAILBOX_10_WRITE_SET_BASE               0x4C0000A8
>>> -#define BCM2711_MAILBOX_11_WRITE_SET_BASE               0x4C0000AC
>>> -#define BCM2711_MAILBOX_12_WRITE_SET_BASE               0x4C0000B0
>>> -#define BCM2711_MAILBOX_13_WRITE_SET_BASE               0x4C0000B4
>>> -#define BCM2711_MAILBOX_14_WRITE_SET_BASE               0x4C0000B8
>>> -#define BCM2711_MAILBOX_15_WRITE_SET_BASE               0x4C0000BC
>>> -#define BCM2711_MAILBOX_00_READ_CLEAR_BASE              0x4C0000C0
>>> -#define BCM2711_MAILBOX_01_READ_CLEAR_BASE              0x4C0000C4
>>> -#define BCM2711_MAILBOX_02_READ_CLEAR_BASE              0x4C0000C8
>>> -#define BCM2711_MAILBOX_03_READ_CLEAR_BASE              0x4C0000CC
>>> -#define BCM2711_MAILBOX_04_READ_CLEAR_BASE              0x4C0000D0
>>> -#define BCM2711_MAILBOX_05_READ_CLEAR_BASE              0x4C0000D4
>>> -#define BCM2711_MAILBOX_06_READ_CLEAR_BASE              0x4C0000D8
>>> -#define BCM2711_MAILBOX_07_READ_CLEAR_BASE              0x4C0000DC
>>> -#define BCM2711_MAILBOX_08_READ_CLEAR_BASE              0x4C0000E0
>>> -#define BCM2711_MAILBOX_09_READ_CLEAR_BASE              0x4C0000E4
>>> -#define BCM2711_MAILBOX_10_READ_CLEAR_BASE              0x4C0000E8
>>> -#define BCM2711_MAILBOX_11_READ_CLEAR_BASE              0x4C0000EC
>>> -#define BCM2711_MAILBOX_12_READ_CLEAR_BASE              0x4C0000F0
>>> -#define BCM2711_MAILBOX_13_READ_CLEAR_BASE              0x4C0000F4
>>> -#define BCM2711_MAILBOX_14_READ_CLEAR_BASE              0x4C0000F8
>>> -#define BCM2711_MAILBOX_15_READ_CLEAR_BASE              0x4C0000FC
>>> - * @name Raspberry Pi 4 ARM_C FIQ and IRQ registers
>>> -#define BCM2711_ARMC_REGS_BASE                 (RPI_PERIPHERAL_BASE +
>>> 0xB200)
>>> -#define BCM2711_ARMC_REGS_SIZE                 0x200
>>> -#define BCM2711_ARMC_IRQ0_PENDING0             (BCM2711_ARMC_REGS_BASE
>>> + 0x00)
>>> -#define BCM2711_ARMC_IRQ0_PENDING1             (BCM2711_ARMC_REGS_BASE
>>> + 0x04)
>>> -#define BCM2711_ARMC_IRQ0_PENDING2             (BCM2711_ARMC_REGS_BASE
>>> + 0x08)
>>> -#define BCM2711_ARMC_IRQ0_SET_EN_0             (BCM2711_ARMC_REGS_BASE
>>> + 0x10)
>>> -#define BCM2711_ARMC_IRQ0_SET_EN_1             (BCM2711_ARMC_REGS_BASE
>>> + 0x14)
>>> -#define BCM2711_ARMC_IRQ0_SET_EN_2             (BCM2711_ARMC_REGS_BASE
>>> + 0x18)
>>> -#define BCM2711_ARMC_IRQ0_CLR_EN_0             (BCM2711_ARMC_REGS_BASE
>>> + 0x20)
>>> -#define BCM2711_ARMC_IRQ0_CLR_EN_1             (BCM2711_ARMC_REGS_BASE
>>> + 0x24)
>>> -#define BCM2711_ARMC_IRQ0_CLR_EN_2             (BCM2711_ARMC_REGS_BASE
>>> + 0x28)
>>> -#define BCM2711_ARMC_IRQ_STATUS0               (BCM2711_ARMC_REGS_BASE
>>> + 0x30)
>>> -#define BCM2711_ARMC_IRQ_STATUS1               (BCM2711_ARMC_REGS_BASE
>>> + 0x34)
>>> -#define BCM2711_ARMC_IRQ_STATUS2               (BCM2711_ARMC_REGS_BASE
>>> + 0x38)
>>> -#define BCM2711_ARMC_IRQ1_PENDING0             (BCM2711_ARMC_REGS_BASE
>>> + 0x40)
>>> -#define BCM2711_ARMC_IRQ1_PENDING1             (BCM2711_ARMC_REGS_BASE
>>> + 0x44)
>>> -#define BCM2711_ARMC_IRQ1_PENDING2             (BCM2711_ARMC_REGS_BASE
>>> + 0x48)
>>> -#define BCM2711_ARMC_IRQ1_SET_EN_0             (BCM2711_ARMC_REGS_BASE
>>> + 0x50)
>>> -#define BCM2711_ARMC_IRQ1_SET_EN_1             (BCM2711_ARMC_REGS_BASE
>>> + 0x54)
>>> -#define BCM2711_ARMC_IRQ1_SET_EN_2             (BCM2711_ARMC_REGS_BASE
>>> + 0x58)
>>> -#define BCM2711_ARMC_IRQ1_CLR_EN_0             (BCM2711_ARMC_REGS_BASE
>>> + 0x60)
>>> -#define BCM2711_ARMC_IRQ1_CLR_EN_1             (BCM2711_ARMC_REGS_BASE
>>> + 0x64)
>>> -#define BCM2711_ARMC_IRQ1_CLR_EN_2             (BCM2711_ARMC_REGS_BASE
>>> + 0x68)
>>> -#define BCM2711_ARMC_IRQ2_PENDING0             (BCM2711_ARMC_REGS_BASE
>>> + 0x80)
>>> -#define BCM2711_ARMC_IRQ2_PENDING1             (BCM2711_ARMC_REGS_BASE
>>> + 0x84)
>>> -#define BCM2711_ARMC_IRQ2_PENDING2             (BCM2711_ARMC_REGS_BASE
>>> + 0x88)
>>> -#define BCM2711_ARMC_IRQ2_SET_EN_0             (BCM2711_ARMC_REGS_BASE
>>> + 0x90)
>>> -#define BCM2711_ARMC_IRQ2_SET_EN_1             (BCM2711_ARMC_REGS_BASE
>>> + 0x94)
>>> -#define BCM2711_ARMC_IRQ2_SET_EN_2             (BCM2711_ARMC_REGS_BASE
>>> + 0x98)
>>> -#define BCM2711_ARMC_IRQ2_CLR_EN_0             (BCM2711_ARMC_REGS_BASE
>>> + 0xA0)
>>> -#define BCM2711_ARMC_IRQ2_CLR_EN_1             (BCM2711_ARMC_REGS_BASE
>>> + 0xA4)
>>> -#define BCM2711_ARMC_IRQ2_CLR_EN_2             (BCM2711_ARMC_REGS_BASE
>>> + 0xA8)
>>> -#define BCM2711_ARMC_IRQ3_PENDING0             (BCM2711_ARMC_REGS_BASE
>>> + 0xC0)
>>> -#define BCM2711_ARMC_IRQ3_PENDING1             (BCM2711_ARMC_REGS_BASE
>>> + 0xC4)
>>> -#define BCM2711_ARMC_IRQ3_PENDING2             (BCM2711_ARMC_REGS_BASE
>>> + 0xC8)
>>> -#define BCM2711_ARMC_IRQ3_SET_EN_0             (BCM2711_ARMC_REGS_BASE
>>> + 0xD0)
>>> -#define BCM2711_ARMC_IRQ3_SET_EN_1             (BCM2711_ARMC_REGS_BASE
>>> + 0xD4)
>>> -#define BCM2711_ARMC_IRQ3_SET_EN_2             (BCM2711_ARMC_REGS_BASE
>>> + 0xD8)
>>> -#define BCM2711_ARMC_IRQ3_CLR_EN_0             (BCM2711_ARMC_REGS_BASE
>>> + 0xE0)
>>> -#define BCM2711_ARMC_IRQ3_CLR_EN_1             (BCM2711_ARMC_REGS_BASE
>>> + 0xE4)
>>> -#define BCM2711_ARMC_IRQ3_CLR_EN_2             (BCM2711_ARMC_REGS_BASE
>>> + 0xE8)
>>> -#define BCM2711_ARMC_FIQ0_PENDING0             (BCM2711_ARMC_REGS_BASE
>>> + 0x100)
>>> -#define BCM2711_ARMC_FIQ0_PENDING1             (BCM2711_ARMC_REGS_BASE
>>> + 0x104)
>>> -#define BCM2711_ARMC_FIQ0_PENDING2             (BCM2711_ARMC_REGS_BASE
>>> + 0x108)
>>> -#define BCM2711_ARMC_FIQ0_SET_EN_0             (BCM2711_ARMC_REGS_BASE
>>> + 0x110)
>>> -#define BCM2711_ARMC_FIQ0_SET_EN_1             (BCM2711_ARMC_REGS_BASE
>>> + 0x114)
>>> -#define BCM2711_ARMC_FIQ0_SET_EN_2             (BCM2711_ARMC_REGS_BASE
>>> + 0x118)
>>> -#define BCM2711_ARMC_FIQ0_CLR_EN_0             (BCM2711_ARMC_REGS_BASE
>>> + 0x120)
>>> -#define BCM2711_ARMC_FIQ0_CLR_EN_1             (BCM2711_ARMC_REGS_BASE
>>> + 0x124)
>>> -#define BCM2711_ARMC_FIQ0_CLR_EN_2             (BCM2711_ARMC_REGS_BASE
>>> + 0x128)
>>> -#define BCM2711_ARMC_FIQ1_PENDING0             (BCM2711_ARMC_REGS_BASE
>>> + 0x140)
>>> -#define BCM2711_ARMC_FIQ1_PENDING1             (BCM2711_ARMC_REGS_BASE
>>> + 0x144)
>>> -#define BCM2711_ARMC_FIQ1_PENDING2             (BCM2711_ARMC_REGS_BASE
>>> + 0x148)
>>> -#define BCM2711_ARMC_FIQ1_SET_EN_0             (BCM2711_ARMC_REGS_BASE
>>> + 0x150)
>>> -#define BCM2711_ARMC_FIQ1_SET_EN_1             (BCM2711_ARMC_REGS_BASE
>>> + 0x154)
>>> -#define BCM2711_ARMC_FIQ1_SET_EN_2             (BCM2711_ARMC_REGS_BASE
>>> + 0x158)
>>> -#define BCM2711_ARMC_FIQ1_CLR_EN_0             (BCM2711_ARMC_REGS_BASE
>>> + 0x160)
>>> -#define BCM2711_ARMC_FIQ1_CLR_EN_1             (BCM2711_ARMC_REGS_BASE
>>> + 0x164)
>>> -#define BCM2711_ARMC_FIQ1_CLR_EN_2             (BCM2711_ARMC_REGS_BASE
>>> + 0x168)
>>> -#define BCM2711_ARMC_FIQ2_PENDING0             (BCM2711_ARMC_REGS_BASE
>>> + 0x180)
>>> -#define BCM2711_ARMC_FIQ2_PENDING1             (BCM2711_ARMC_REGS_BASE
>>> + 0x184)
>>> -#define BCM2711_ARMC_FIQ2_PENDING2             (BCM2711_ARMC_REGS_BASE
>>> + 0x188)
>>> -#define BCM2711_ARMC_FIQ2_SET_EN_0             (BCM2711_ARMC_REGS_BASE
>>> + 0x190)
>>> -#define BCM2711_ARMC_FIQ2_SET_EN_1             (BCM2711_ARMC_REGS_BASE
>>> + 0x194)
>>> -#define BCM2711_ARMC_FIQ2_SET_EN_2             (BCM2711_ARMC_REGS_BASE
>>> + 0x198)
>>> -#define BCM2711_ARMC_FIQ2_CLR_EN_0             (BCM2711_ARMC_REGS_BASE
>>> + 0x1A0)
>>> -#define BCM2711_ARMC_FIQ2_CLR_EN_1             (BCM2711_ARMC_REGS_BASE
>>> + 0x1A4)
>>> -#define BCM2711_ARMC_FIQ2_CLR_EN_2             (BCM2711_ARMC_REGS_BASE
>>> + 0x1A8)
>>> -#define BCM2711_ARMC_FIQ3_PENDING0             (BCM2711_ARMC_REGS_BASE
>>> + 0x1C0)
>>> -#define BCM2711_ARMC_FIQ3_PENDING1             (BCM2711_ARMC_REGS_BASE
>>> + 0x1C4)
>>> -#define BCM2711_ARMC_FIQ3_PENDING2             (BCM2711_ARMC_REGS_BASE
>>> + 0x1C8)
>>> -#define BCM2711_ARMC_FIQ3_SET_EN_0             (BCM2711_ARMC_REGS_BASE
>>> + 0x1D0)
>>> -#define BCM2711_ARMC_FIQ3_SET_EN_1             (BCM2711_ARMC_REGS_BASE
>>> + 0x1D4)
>>> -#define BCM2711_ARMC_FIQ3_SET_EN_2             (BCM2711_ARMC_REGS_BASE
>>> + 0x1D8)
>>> -#define BCM2711_ARMC_FIQ3_CLR_EN_0             (BCM2711_ARMC_REGS_BASE
>>> + 0x1E0)
>>> -#define BCM2711_ARMC_FIQ3_CLR_EN_1             (BCM2711_ARMC_REGS_BASE
>>> + 0x1E4)
>>> -#define BCM2711_ARMC_FIQ3_CLR_EN_2             (BCM2711_ARMC_REGS_BASE
>>> + 0x1E8)
>>> -#define BCM2711_ARMC_SWIRQ_SET                 (BCM2711_ARMC_REGS_BASE
>>> + 0x1F0)
>>> -#define BCM2711_ARMC_SWIRQ_CLEAR               (BCM2711_ARMC_REGS_BASE
>>> + 0x1F4)
>>> -#endif /* LIBBSP_ARM_RASPBERRYPI_RASPBERRYPI_H */
>>> diff --git a/bsps/aarch64/raspberrypi/include/bsp/start/bspstartmmu.h
>>> b/bsps/aarch64/raspberrypi/include/bsp/start/bspstartmmu.h
>>> index 0000000000..cb1b24ac72
>>> --- /dev/null
>>> +++ b/bsps/aarch64/raspberrypi/include/bsp/start/bspstartmmu.h
>>> @@ -0,0 +1,8 @@
>>> +#ifndef LIBBSP_AARCH64_RASPBERRYPI_BSP_START_BSPSTARTMMU_H
>>> +#define LIBBSP_AARCH64_RASPBERRYPI_BSP_START_BSPSTARTMMU_H
>>> +#include <bsp/start.h>
>>> +BSP_START_TEXT_SECTION void bsp_start_mmu_setup(void);
>>> +#endif
>>> diff --git a/bsps/aarch64/raspberrypi/start/bspstart.c
>>> b/bsps/aarch64/raspberrypi/start/bspstart.c
>>> index 368c5d0d08..03d5ae4c77 100644
>>> --- a/bsps/aarch64/raspberrypi/start/bspstart.c
>>> +++ b/bsps/aarch64/raspberrypi/start/bspstart.c
>>> @@ -3,13 +3,14 @@
>>>   * @file
>>> - * @brief BSP Startup
>>> + * @brief BSP startup routines
>>> @@ -34,16 +35,13 @@
>>> -#include <bsp.h>
>>>  #include <bsp/bootcard.h>
>>>  #include <bsp/irq-generic.h>
>>>  #include <bsp/linker-symbols.h>
>>> -void bsp_start( void )
>>> -  bsp_interrupt_initialize();
>>> -  rtems_cache_coherent_add_area(
>>> -    bsp_section_nocacheheap_begin,
>>> -    (uintptr_t) bsp_section_nocacheheap_size
>>> +void bsp_start(void) {
>>> +    bsp_interrupt_initialize();
>>> +    rtems_cache_coherent_add_area(bsp_section_nocacheheap_begin,
>>> (uintptr_t)bsp_section_nocacheheap_size);
>>> diff --git a/bsps/aarch64/raspberrypi/start/bspstarthooks.c
>>> b/bsps/aarch64/raspberrypi/start/bspstarthooks.c
>>> index fe0fe77c09..2444767874 100644
>>> --- a/bsps/aarch64/raspberrypi/start/bspstarthooks.c
>>> +++ b/bsps/aarch64/raspberrypi/start/bspstarthooks.c
>>> @@ -3,13 +3,14 @@
>>>   * @file
>>>   * @brief BSP Startup Hooks
>>> @@ -34,20 +35,15 @@
>>> -#include <bsp.h>
>>> -#include <bsp/irq-generic.h>
>>> -#include <rtems/score/cpu.h>
>>> +#include "bsp/start/bspstartmmu.h"
>>> -BSP_START_TEXT_SECTION void bsp_start_hook_0(void)
>>> -  /* Do nothing */
>>> +BSP_START_TEXT_SECTION void bsp_start_hook_0(void) {
>>> +    /* Do nothing */
>>> -BSP_START_TEXT_SECTION void bsp_start_hook_1(void)
>>> -  AArch64_start_set_vector_base();
>>> -  bsp_start_copy_sections();
>>> -  raspberrypi_4_setup_mmu_and_cache();
>>> -  bsp_start_clear_bss();
>>> \ No newline at end of file
>>> +BSP_START_TEXT_SECTION void bsp_start_hook_1(void) {
>>> +    AArch64_start_set_vector_base();
>>> +    bsp_start_copy_sections();
>>> +    bsp_start_mmu_setup();
>>> +    bsp_start_clear_bss();
>>> diff --git a/bsps/aarch64/raspberrypi/start/bspstartmmu.c
>>> b/bsps/aarch64/raspberrypi/start/bspstartmmu.c
>>> index 18a9a112b0..9a5824e29a 100644
>>> --- a/bsps/aarch64/raspberrypi/start/bspstartmmu.c
>>> +++ b/bsps/aarch64/raspberrypi/start/bspstartmmu.c
>>> @@ -3,13 +3,14 @@
>>>   * @file
>>>   * @brief This source file contains the default MMU tables and setup.
>>> @@ -34,51 +35,34 @@
>>> -#include <bsp.h>
>>>  #include <bsp/aarch64-mmu.h>
>>> -#include <bsp/raspberrypi.h>
>>> -#include <libcpu/mmu-vmsav8-64.h>
>>> +#include "bsp.h"
>>>  BSP_START_DATA_SECTION static const aarch64_mmu_config_entry
>>> -raspberrypi_4_mmu_config_table[] = {
>>> -  AARCH64_MMU_DEFAULT_SECTIONS,
>>> -  { /* RPI peripheral address */
>>> -    .begin = (unsigned)RPI_PERIPHERAL_BASE,
>>> -    .end = (unsigned)RPI_PERIPHERAL_BASE +
>>> (unsigned)RPI_PERIPHERAL_SIZE,
>>> -    .flags = AARCH64_MMU_DEVICE
>>> -  { /* RPI ARM local registers */
>>> -    .begin = (unsigned)BCM2711_LOCAL_REGS_BASE,
>>> -    .end = (unsigned)BCM2711_LOCAL_REGS_BASE +
>>> (unsigned)BCM2711_LOCAL_REGS_SIZE,
>>> -  { /* RPI GIC Interface address */
>>> -    .begin = 0xFF800000U,
>>> -    .end = 0xFFA00000U,
>>> +    bsp_mmu_config_table[] = {
>>> +        AARCH64_MMU_DEFAULT_SECTIONS,
>>> +            // UART0
>>> +            .begin = BSP_UART0_BASE,
>>> +            .end   = BSP_UART0_BASE + BSP_UART0_SIZE,
>>> +            .flags = AARCH64_MMU_DEVICE,
>>> +            /* Interrupts */
>>> +            .begin = BSP_GIC_BASE,
>>> +            .end   = BSP_GIC_BASE + BSP_GIC_SIZE,
>>> - * Make weak and let the user override.
>>> -raspberrypi_4_setup_mmu_and_cache( void ) __attribute__ ((weak));
>>> -  aarch64_mmu_setup();
>>> +BSP_START_TEXT_SECTION void bsp_start_mmu_setup(void) {
>>> +    aarch64_mmu_setup();
>>> -  aarch64_mmu_setup_translation_table(
>>> -    &raspberrypi_4_mmu_config_table[ 0 ],
>>> -    RTEMS_ARRAY_SIZE( raspberrypi_4_mmu_config_table )
>>> +    aarch64_mmu_setup_translation_table(
>>> +        &bsp_mmu_config_table[0],
>>> RTEMS_ARRAY_SIZE(bsp_mmu_config_table));
>>> -  aarch64_mmu_enable();
>>> +    aarch64_mmu_enable();
>>> diff --git a/spec/build/bsps/aarch64/raspberrypi/abi.yml
>>> b/spec/build/bsps/aarch64/raspberrypi/abi.yml
>>> index 38a8d8bc8f..63c2afbea6 100644
>>> --- a/spec/build/bsps/aarch64/raspberrypi/abi.yml
>>> +++ b/spec/build/bsps/aarch64/raspberrypi/abi.yml
>>> @@ -1,19 +1,26 @@
>>>  SPDX-License-Identifier: CC-BY-SA-4.0 OR BSD-2-Clause
>>> -actions:
>>> -- get-string: null
>>> -- split: null
>>> -- env-append: null
>>> -build-type: option
>>>  copyrights:
>>> -- Copyright (C) 2022 Mohd Noor Aman
>>> -default:
>>> -- enabled-by: true
>>> -  value:
>>> -  - -mcpu=cortex-a72
>>> -  - -march=armv8-a
>>> -description: |
>>> -  ABI flags
>>> +  - Copyright (C) 2022 Mohd Noor Aman
>>> +  - Copyright (C) 2023 Utkarsh Verma
>>> +type: build
>>>  enabled-by: true
>>> -links: []
>>> +build-type: option
>>> -type: build
>>> +description: ABI flags
>>> +actions:
>>> +  - get-string: null
>>> +  - split: null
>>> +  - env-append: null
>>> +default:
>>> +  - enabled-by:
>>> +      - aarch64/raspberrypi4b
>>> +    value:
>>> +      - -mcpu=cortex-a72
>>> +      - -march=armv8-a
>>> +      - -mstrict-align
>>> +links: []
>>> diff --git a/spec/build/bsps/aarch64/raspberrypi/bsp4b.yml
>>> b/spec/build/bsps/aarch64/raspberrypi/bsp4b.yml
>>> index 0000000000..058f97d1eb
>>> --- /dev/null
>>> +++ b/spec/build/bsps/aarch64/raspberrypi/bsp4b.yml
>>> @@ -0,0 +1,23 @@
>>> +SPDX-License-Identifier: CC-BY-SA-4.0 OR BSD-2-Clause
>>> +copyrights:
>>> +type: build
>>> +enabled-by: true
>>> +build-type: bsp
>>> +arch: aarch64
>>> +bsp: raspberrypi4b
>>> +family: raspberrypi
>>> +cflags: []
>>> +cppflags: []
>>> +includes: []
>>> +install: []
>>> +source: []
>>> +links:
>>> +  - role: build-dependency
>>> +    uid: grp4b
>>> +    uid: linkcmds
>>> diff --git a/spec/build/bsps/aarch64/raspberrypi/bspraspberrypi4.yml
>>> b/spec/build/bsps/aarch64/raspberrypi/bspraspberrypi4.yml
>>> index a579c094ba..0000000000
>>> --- a/spec/build/bsps/aarch64/raspberrypi/bspraspberrypi4.yml
>>> +++ /dev/null
>>> @@ -1,72 +0,0 @@
>>> -SPDX-License-Identifier: CC-BY-SA-4.0 OR BSD-2-Clause
>>> -arch: aarch64
>>> -bsp: raspberrypi4b
>>> -build-type: bsp
>>> -cflags: []
>>> -copyrights:
>>> -cppflags: []
>>> -enabled-by: true
>>> -family: raspberrypi
>>> -includes: []
>>> -install:
>>> -- destination: ${BSP_INCLUDEDIR}
>>> -  source:
>>> -  - bsps/aarch64/raspberrypi/include/bsp.h
>>> -  - bsps/aarch64/raspberrypi/include/tm27.h
>>> -- destination: ${BSP_INCLUDEDIR}/bsp
>>> -  source:
>>> -  - bsps/aarch64/raspberrypi/include/bsp/irq.h
>>> -  - bsps/aarch64/raspberrypi/include/bsp/raspberrypi.h
>>> -links:
>>> -- role: build-dependency
>>> -  uid: ../grp
>>> -  uid: ../start
>>> -  uid: ../optmmupages
>>> -  uid: ../optgtusevirt
>>> -  uid: ../optgtuseps
>>> -  uid: abi
>>> -  uid: ../../optcachedata
>>> -  uid: ../../optcacheinst
>>> -  uid: ../../opto2
>>> -  uid: ../../bspopts
>>> -  uid: linkercmds
>>> -  uid: ../../obj
>>> -  uid: ../../objirq
>>> -source:
>>> -- bsps/aarch64/raspberrypi/console/console.c
>>> -- bsps/aarch64/raspberrypi/start/bspstart.c
>>> -- bsps/aarch64/raspberrypi/start/bspstarthooks.c
>>> -- bsps/aarch64/raspberrypi/start/bspstartmmu.c
>>> -- bsps/aarch64/shared/clock/arm-generic-timer-aarch64.c
>>> -- bsps/aarch64/shared/cache/cache.c
>>> -- bsps/aarch64/shared/mmu/vmsav8-64.c
>>> -- bsps/shared/dev/clock/arm-generic-timer.c
>>> -- bsps/shared/dev/irq/arm-gicv2.c
>>> -- bsps/shared/dev/irq/arm-gicv2-get-attributes.c
>>> -- bsps/shared/dev/serial/console-termios-init.c
>>> -- bsps/shared/dev/serial/console-termios.c
>>> -- bsps/shared/dev/serial/arm-pl011.c
>>> -- bsps/shared/dev/getentropy/getentropy-cpucounter.c
>>> -- bsps/shared/dev/btimer/btimer-cpucounter.c
>>> -- bsps/shared/irq/irq-default-handler.c
>>> -- bsps/shared/start/bspfatal-default.c
>>> -- bsps/shared/start/bspreset-arm-psci.c
>>> -- bsps/shared/start/gettargethash-default.c
>>> -- bsps/shared/start/sbrk.c
>>> -- bsps/shared/start/wkspaceinitone.c
>>> -- bsps/shared/start/mallocinitmulti.c
>>> -- bsps/shared/start/bspgetworkarea-default.c
>>> -type: build
>>> diff --git a/spec/build/bsps/aarch64/raspberrypi/grp.yml
>>> b/spec/build/bsps/aarch64/raspberrypi/grp.yml
>>> index 0000000000..4e6b022e3c
>>> --- /dev/null
>>> +++ b/spec/build/bsps/aarch64/raspberrypi/grp.yml
>>> @@ -0,0 +1,49 @@
>>> +copyrights:
>>> +type: build
>>> +enabled-by: true
>>> +build-type: group
>>> +cflags: []
>>> +cppflags: []
>>> +cxxflags: []
>>> +includes: []
>>> +install: []
>>> +ldflags: []
>>> +use-after: []
>>> +use-before: []
>>> +links:
>>> +    uid: abi
>>> +    uid: obj
>>> +    uid: optclockpl011freq
>>> +    uid: optconsolebaud
>>> +    uid: ../grp
>>> +    uid: ../start
>>> +    uid: ../optmmupages
>>> +    uid: ../optgtusevirt
>>> +    uid: ../optgtuseps
>>> +    uid: ../../optcachedata
>>> +    uid: ../../optcacheinst
>>> +    uid: ../../opto2
>>> +    uid: ../../bspopts
>>> +    uid: ../../obj
>>> +    uid: ../../objirq
>>> diff --git a/spec/build/bsps/aarch64/raspberrypi/grp4b.yml
>>> b/spec/build/bsps/aarch64/raspberrypi/grp4b.yml
>>> index 0000000000..8a4b8c0370
>>> --- /dev/null
>>> +++ b/spec/build/bsps/aarch64/raspberrypi/grp4b.yml
>>> @@ -0,0 +1,26 @@
>>> +copyrights:
>>> +type: build
>>> +enabled-by: true
>>> +build-type: group
>>> +cflags: []
>>> +cppflags: []
>>> +cxxflags: []
>>> +includes: []
>>> +install:
>>> +  - destination: ${BSP_INCLUDEDIR}/bsp
>>> +    source:
>>> +      - bsps/aarch64/raspberrypi/include/bsp/bcm2711.h
>>> +ldflags: []
>>> +use-after: []
>>> +use-before: []
>>> +links:
>>> +    uid: grp
>>> diff --git a/spec/build/bsps/aarch64/raspberrypi/linkercmds.yml
>>> b/spec/build/bsps/aarch64/raspberrypi/linkcmds.yml
>>> similarity index 90%
>>> rename from spec/build/bsps/aarch64/raspberrypi/linkercmds.yml
>>> rename to spec/build/bsps/aarch64/raspberrypi/linkcmds.yml
>>> index 701f9f935c..6988d54422 100644
>>> --- a/spec/build/bsps/aarch64/raspberrypi/linkercmds.yml
>>> +++ b/spec/build/bsps/aarch64/raspberrypi/linkcmds.yml
>>> @@ -1,10 +1,19 @@
>>> +copyrights:
>>> +type: build
>>> +enabled-by: true
>>>  build-type: config-file
>>>  content: |
>>> @@ -29,8 +38,8 @@ content: |
>>>    MEMORY {
>>> -  RAM_MMU  : ORIGIN = 0x0, LENGTH = (0x1000 *
>>> ${AARCH64_MMU_TRANSLATION_TABLE_PAGES})
>>> -  RAM      : ORIGIN = 0x80000, LENGTH = 1024M
>>> +    RAM_MMU  : ORIGIN = 0x0, LENGTH = (CONSTANT(COMMONPAGESIZE) *
>>> +    RAM      : ORIGIN = 0x80000, LENGTH = 1024M
>>>    REGION_ALIAS ("REGION_START",          RAM);
>>> @@ -51,11 +60,11 @@ content: |
>>>    REGION_ALIAS ("REGION_NOCACHE",        RAM);
>>>    REGION_ALIAS ("REGION_NOCACHE_LOAD",   RAM);
>>> -  bsp_stack_abt_size = DEFINED (bsp_stack_abt_size) ?
>>> bsp_stack_abt_size : 1024;
>>> +  bsp_stack_abt_size = DEFINED (bsp_stack_abt_size) ?
>>> bsp_stack_abt_size : 1K;
>>>    bsp_section_rwbarrier_align = DEFINED (bsp_section_rwbarrier_align) ?
>>> bsp_section_rwbarrier_align : 1M;
>>> -  bsp_stack_exception_size = DEFINED (bsp_stack_exception_size) ?
>>> bsp_stack_exception_size : 1024;
>>> +  bsp_stack_exception_size = DEFINED (bsp_stack_exception_size) ?
>>> bsp_stack_exception_size : 1K;
>>> @@ -67,10 +76,8 @@ content: |
>>>    OUTPUT_ARCH (aarch64)
>>>    INCLUDE linkcmds.base
>>> -copyrights:
>>> -enabled-by: true
>>>  install-path: ${BSP_LIBDIR}
>>> -links: []
>>>  target: linkcmds
>>> -type: build
>>> +links: []
>>> diff --git a/spec/build/bsps/aarch64/raspberrypi/obj.yml
>>> b/spec/build/bsps/aarch64/raspberrypi/obj.yml
>>> index 0000000000..6a57210d36
>>> --- /dev/null
>>> +++ b/spec/build/bsps/aarch64/raspberrypi/obj.yml
>>> @@ -0,0 +1,50 @@
>>> +copyrights:
>>> +type: build
>>> +enabled-by: true
>>> +build-type: objects
>>> +cflags: []
>>> +cppflags: []
>>> +cxxflags: []
>>> +includes: []
>>> +install:
>>> +    source:
>>> +      - bsps/aarch64/raspberrypi/include/bsp.h
>>> +      - bsps/aarch64/raspberrypi/include/tm27.h
>>> +    source:
>>> +      - bsps/aarch64/raspberrypi/include/bsp/irq.h
>>> +source:
>>> +  - bsps/aarch64/shared/cache/cache.c
>>> +  - bsps/aarch64/shared/clock/arm-generic-timer-aarch64.c
>>> +  - bsps/aarch64/shared/mmu/vmsav8-64.c
>>> +  - bsps/aarch64/raspberrypi/console/console.c
>>> +  - bsps/aarch64/raspberrypi/start/bspstart.c
>>> +  - bsps/aarch64/raspberrypi/start/bspstarthooks.c
>>> +  - bsps/aarch64/raspberrypi/start/bspstartmmu.c
>>> +  - bsps/shared/dev/clock/arm-generic-timer.c
>>> +  - bsps/shared/dev/irq/arm-gicv2.c
>>> +  - bsps/shared/dev/irq/arm-gicv2-get-attributes.c
>>> +  - bsps/shared/dev/serial/console-termios-init.c
>>> +  - bsps/shared/dev/serial/console-termios.c
>>> +  - bsps/shared/dev/getentropy/getentropy-cpucounter.c
>>> +  - bsps/shared/dev/btimer/btimer-cpucounter.c
>>> +  - bsps/shared/irq/irq-default-handler.c
>>> +  - bsps/shared/start/bspfatal-default.c
>>> +  - bsps/shared/start/bspreset-arm-psci.c
>>> +  - bsps/shared/start/gettargethash-default.c
>>> +  - bsps/shared/start/sbrk.c
>>> +  - bsps/shared/start/wkspaceinitone.c
>>> +  - bsps/shared/start/mallocinitmulti.c
>>> +  - bsps/shared/start/bspgetworkarea-default.c
>>> +links:
>>> +    uid: objconsolepl011
>>> diff --git a/spec/build/bsps/aarch64/raspberrypi/objconsolepl011.yml
>>> b/spec/build/bsps/aarch64/raspberrypi/objconsolepl011.yml
>>> index 0000000000..0c5135cdc5
>>> --- /dev/null
>>> +++ b/spec/build/bsps/aarch64/raspberrypi/objconsolepl011.yml
>>> @@ -0,0 +1,24 @@
>>> +copyrights:
>>> +type: build
>>> +enabled-by: true
>>> +cflags: []
>>> +cppflags: []
>>> +cxxflags: []
>>> +includes: []
>>> +install:
>>> +  - destination: ${BSP_INCLUDEDIR}/dev/serial
>>> +    source:
>>> +      - bsps/include/dev/serial/arm-pl011.h
>>> +      - bsps/include/dev/serial/arm-pl011-regs.h
>>> +source:
>>> +  - bsps/shared/dev/serial/arm-pl011.c
>>> +links: []
>>> diff --git a/spec/build/bsps/aarch64/raspberrypi/optclockpl011freq.yml
>>> b/spec/build/bsps/aarch64/raspberrypi/optclockpl011freq.yml
>>> index 0000000000..e6432c7010
>>> --- /dev/null
>>> +++ b/spec/build/bsps/aarch64/raspberrypi/optclockpl011freq.yml
>>> @@ -0,0 +1,23 @@
>>> +copyrights:
>>> +type: build
>>> +enabled-by: true
>>> +build-type: option
>>> +name: BSP_PL011_CLOCK_FREQ
>>> +description: PL011 UART clock frequency in Hz
>>> +actions:
>>> +  - get-integer: null
>>> +  - define: null
>>> +default:
>>> +  - enabled-by:
>>> +    value: 48000000
>>> +format: '{}'
>>> +links: []
>>> diff --git a/spec/build/bsps/aarch64/raspberrypi/optconsolebaud.yml
>>> b/spec/build/bsps/aarch64/raspberrypi/optconsolebaud.yml
>>> index 0000000000..bff49ad71a
>>> --- /dev/null
>>> +++ b/spec/build/bsps/aarch64/raspberrypi/optconsolebaud.yml
>>> @@ -0,0 +1,23 @@
>>> +copyrights:
>>> +type: build
>>> +enabled-by: true
>>> +build-type: option
>>> +name: BSP_CONSOLE_BAUD
>>> +description: Default baudrate for the console device.
>>> +actions:
>>> +  - define: null
>>> +default:
>>> +  - enabled-by:
>>> +    value: 115200
>>> +format: '{}'
>>> +links: []
>>> 2.41.0
>>> devel mailing list
>>> devel at rtems.org
>>> http://lists.rtems.org/mailman/listinfo/devel
> devel mailing list
> devel at rtems.org
URL: <http://lists.rtems.org/pipermail/devel/attachments/20230807/456c9208/attachment-0001.htm>
