[PATCH] arm: Add cache support for ARM926EJ-S
Wed Aug 9 08:02:41 UTC 2023
The ARM926EJ-S is an ARMv5T architecture processor and lacks some
features of ARMv6 processors such as the ARM1176JZF-S.
 bsps/arm/shared/cache/cache-cp15.c            | 26 +++++++++++++++++++
 .../score/cpu/arm/include/libcpu/arm-cp15.h   | 26 ++++++++++++++++---
 2 files changed, 48 insertions(+), 4 deletions(-)
diff --git a/bsps/arm/shared/cache/cache-cp15.c b/bsps/arm/shared/cache/cache-cp15.c
index 1f7132596c..d78ec4feb4 100644
--- a/bsps/arm/shared/cache/cache-cp15.c
+++ b/bsps/arm/shared/cache/cache-cp15.c
@@ -200,6 +200,7 @@ static inline void _CPU_cache_disable_instruction(void)
   rtems_interrupt_local_enable(level);
+#if __ARM_ARCH >= 6
 static inline size_t arm_cp15_get_cache_size(
   uint32_t level,
   uint32_t which
@@ -238,5 +239,30 @@ static inline size_t _CPU_cache_get_instruction_cache_size(uint32_t level)
   return arm_cp15_get_cache_size(level, ARM_CP15_CACHE_CSS_ID_INSTRUCTION);
+#else
+static inline size_t _CPU_cache_get_data_cache_size(uint32_t level)
+  uint32_t cache_type;
+  if (level > 0) {
+    return 0;
+  cache_type = arm_cp15_get_cache_type();
+  return 1U << (((cache_type >> (12 + 6)) & 0xf) + 9);
+static inline size_t _CPU_cache_get_instruction_cache_size(uint32_t level)
+  if (level > 0) {
+    return 0;
+  return 1U << (((cache_type >> (0 + 6)) & 0xf) + 9);
+#endif
 #include "../../shared/cache/cacheimpl.h"
diff --git a/cpukit/score/cpu/arm/include/libcpu/arm-cp15.h b/cpukit/score/cpu/arm/include/libcpu/arm-cp15.h
index 333cd7c8a0..c239eaccc8 100644
--- a/cpukit/score/cpu/arm/include/libcpu/arm-cp15.h
+++ b/cpukit/score/cpu/arm/include/libcpu/arm-cp15.h
@@ -1309,15 +1309,17 @@ arm_cp15_data_cache_test_and_clean(void)
-/*	In DDI0301H_arm1176jzfs_r0p7_trm
- * 	'MCR p15, 0, <Rd>, c7, c14, 0' means
- * 	Clean and Invalidate Entire Data Cache
 ARM_CP15_TEXT_SECTION static inline void
 arm_cp15_data_cache_clean_and_invalidate(void)
   ARM_SWITCH_REGISTERS;
+   * In DDI0301H_arm1176jzfs_r0p7_trm
+   * 'MCR p15, 0, <Rd>, c7, c14, 0' means
+   * Clean and Invalidate Entire Data Cache
   uint32_t sbz = 0;
   __asm__ volatile (
@@ -1328,6 +1330,22 @@ arm_cp15_data_cache_clean_and_invalidate(void)
     : [sbz] "r" (sbz)
     : "memory"
+#else
+   * Assume this is an ARM926EJ-S.  Use the test, clean, and invalidate DCache
+   * operation.
+  __asm__ volatile (
+    ARM_SWITCH_TO_ARM
+    "1:\n"
+    "mrc p15, 0, r15, c7, c14, 3\n"
+    "bne 1b\n"
+    ARM_SWITCH_BACK
+    : ARM_SWITCH_OUTPUT
+    : "memory"
+#endif
2.35.3
