[PATCH RTEMS] spec: Add -mstrict-align to mvme2100 default build
Wed Aug 9 14:21:52 UTC 2023
I'm ok with this if there is a known case of an alignment exception that
causes this.
We didn't want to force it into every PowerPC BSP.
Do you have a case that failed and was resolved by adding this?
On Wed, Aug 9, 2023 at 7:36 AM Uchenna Ezeobi <uchenna.ezeobi3 at gmail.com>
wrote:
> Update #3767
>  spec/build/bsps/powerpc/motorola_powerpc/abi.yml | 4 ++++
>  1 file changed, 4 insertions(+)
> diff --git a/spec/build/bsps/powerpc/motorola_powerpc/abi.yml
> b/spec/build/bsps/powerpc/motorola_powerpc/abi.yml
> index 6734e9babf..2438c30f1d 100644
> --- a/spec/build/bsps/powerpc/motorola_powerpc/abi.yml
> +++ b/spec/build/bsps/powerpc/motorola_powerpc/abi.yml
> @@ -17,6 +17,10 @@ default:
>    - -mcpu=powerpc
>    - -mmultiple
>    - -mstrict-align
> +- enabled-by: [powerpc/mvme2100]
> +  value:
> +  - -mcpu=603e
> +  - -mstrict-align
>  - enabled-by: [powerpc/mvme2307, powerpc/mvme2700]
>    value:
>    - -mcpu=604
> 2.39.3
> devel mailing list
> devel at rtems.org
URL: <http://lists.rtems.org/pipermail/devel/attachments/20230809/378371ec/attachment.htm>
