[PATCH 0/2 v3] Refactor the aarch64/raspberryp4b BSP
Utkarsh Verma utkarsh at bitbanged.com
Thu Aug 10 06:15:14 UTC 2023
A gentle reminder for this. Please let me know which changes are required
so that I can send the next set of patches as well.
On Wed, Aug 9, 2023 at 9:20 AM Utkarsh Verma <utkarsh at bitbanged.com> wrote:
> Changes can also be seen on my fork:
> https://github.com/UtkarshVerma/rtems/tree/refactor
> On Wed, Aug 9, 2023 at 9:18 AM Utkarsh Verma <utkarsh at bitbanged.com>
> wrote:
>> This patch series refactors the BSP and build spec for Raspberry Pi 4B
>> with the following goals in mind:
>> - IWYU(include what you use) includes
>> - Modularity in BSP and the build spec
>> - Strict MMU mapping
>> This is my first code contribution to RTEMS, therefore suggestions of
>> any kind would be highly appreciated.
>> Regards,
>> Utkarsh
>> Utkarsh Verma (2):
>>   bsps/aarch64/raspberrypi: Refactor the BSP
>>   build: Modularize the aarch64/raspberrypi spec
>>  bsps/aarch64/raspberrypi/console/console.c    |  39 +-
>>  bsps/aarch64/raspberrypi/include/bsp.h        |  37 +-
>>  .../aarch64/raspberrypi/include/bsp/bcm2711.h |  96 ++++
>>  bsps/aarch64/raspberrypi/include/bsp/irq.h    | 102 ++--
>>  .../raspberrypi/include/bsp/raspberrypi.h     | 471 ------------------
>>  .../include/bsp/start/bspstartmmu.h           |  45 ++
>>  bsps/aarch64/raspberrypi/include/tm27.h       |   5 +-
>>  bsps/aarch64/raspberrypi/start/bspstart.c     |  16 +-
>>  .../aarch64/raspberrypi/start/bspstarthooks.c |  26 +-
>>  bsps/aarch64/raspberrypi/start/bspstartmmu.c  |  66 +--
>>  spec/build/bsps/aarch64/raspberrypi/abi.yml   |  39 +-
>>  spec/build/bsps/aarch64/raspberrypi/bsp4b.yml |  23 +
>>  .../aarch64/raspberrypi/bspraspberrypi4.yml   |  72 ---
>>  spec/build/bsps/aarch64/raspberrypi/grp.yml   |  25 +
>>  spec/build/bsps/aarch64/raspberrypi/grp4b.yml |  26 +
>>  .../{linkercmds.yml => linkcmds.yml}          |  27 +-
>>  spec/build/bsps/aarch64/raspberrypi/obj.yml   |  40 ++
>>  .../bsps/aarch64/raspberrypi/objcache.yml     |  23 +
>>  .../bsps/aarch64/raspberrypi/objclock.yml     |  24 +
>>  .../bsps/aarch64/raspberrypi/objconsole.yml   |  20 +
>>  .../build/bsps/aarch64/raspberrypi/objirq.yml |  27 +
>>  .../bsps/aarch64/raspberrypi/objstart.yml     |  35 ++
>>  22 files changed, 553 insertions(+), 731 deletions(-)
>>  create mode 100644 bsps/aarch64/raspberrypi/include/bsp/bcm2711.h
>>  delete mode 100644 bsps/aarch64/raspberrypi/include/bsp/raspberrypi.h
>>  create mode 100644
>> bsps/aarch64/raspberrypi/include/bsp/start/bspstartmmu.h
>>  create mode 100644 spec/build/bsps/aarch64/raspberrypi/bsp4b.yml
>>  delete mode 100644
>> spec/build/bsps/aarch64/raspberrypi/bspraspberrypi4.yml
>>  create mode 100644 spec/build/bsps/aarch64/raspberrypi/grp.yml
>>  create mode 100644 spec/build/bsps/aarch64/raspberrypi/grp4b.yml
>>  rename spec/build/bsps/aarch64/raspberrypi/{linkercmds.yml =>
>> linkcmds.yml} (88%)
>>  create mode 100644 spec/build/bsps/aarch64/raspberrypi/obj.yml
>>  create mode 100644 spec/build/bsps/aarch64/raspberrypi/objcache.yml
>>  create mode 100644 spec/build/bsps/aarch64/raspberrypi/objclock.yml
>>  create mode 100644 spec/build/bsps/aarch64/raspberrypi/objconsole.yml
>>  create mode 100644 spec/build/bsps/aarch64/raspberrypi/objirq.yml
>>  create mode 100644 spec/build/bsps/aarch64/raspberrypi/objstart.yml
>> 2.41.0
URL: <http://lists.rtems.org/pipermail/devel/attachments/20230810/f207eed2/attachment.htm>
