[PATCH] build: Add target to build scripts
Thu Aug 10 09:02:02 UTC 2023
Document that the build scripts in the testsuites produce a test program.
 spec/build/testsuites/libtests/dl01.yml     | 1 +
 spec/build/testsuites/libtests/dl02.yml     | 1 +
 spec/build/testsuites/libtests/dl04.yml     | 1 +
 spec/build/testsuites/libtests/dl05.yml     | 1 +
 spec/build/testsuites/libtests/dl06.yml     | 1 +
 spec/build/testsuites/libtests/dl07.yml     | 1 +
 spec/build/testsuites/libtests/dl08.yml     | 1 +
 spec/build/testsuites/libtests/dl09.yml     | 1 +
 spec/build/testsuites/libtests/dl10.yml     | 1 +
 spec/build/testsuites/libtests/dl11.yml     | 1 +
 spec/build/testsuites/libtests/tar01.yml    | 1 +
 spec/build/testsuites/libtests/tar02.yml    | 1 +
 spec/build/testsuites/psxtests/psxftw01.yml | 1 +
 13 files changed, 13 insertions(+)
diff --git a/spec/build/testsuites/libtests/dl01.yml b/spec/build/testsuites/libtests/dl01.yml
index 3cc04a6611..c1126ca8e2 100644
--- a/spec/build/testsuites/libtests/dl01.yml
+++ b/spec/build/testsuites/libtests/dl01.yml
@@ -33,6 +33,7 @@ links: []
 prepare-build: null
 prepare-configure: null
 stlib: []
+target: testsuites/libtests/dl01.exe
 type: build
 use-after: []
 use-before: []
diff --git a/spec/build/testsuites/libtests/dl02.yml b/spec/build/testsuites/libtests/dl02.yml
index 9fd81dc7c8..34df43c762 100644
--- a/spec/build/testsuites/libtests/dl02.yml
+++ b/spec/build/testsuites/libtests/dl02.yml
@@ -34,6 +34,7 @@ links: []
 prepare-build: null
 stlib: []
+target: testsuites/libtests/dl02.exe
 type: build
 use-after: []
 use-before: []
diff --git a/spec/build/testsuites/libtests/dl04.yml b/spec/build/testsuites/libtests/dl04.yml
index 7dd41e3338..55ff91e6fe 100644
--- a/spec/build/testsuites/libtests/dl04.yml
+++ b/spec/build/testsuites/libtests/dl04.yml
 prepare-build: null
 stlib: []
+target: testsuites/libtests/dl04.exe
 type: build
 use-after: []
 use-before: []
diff --git a/spec/build/testsuites/libtests/dl05.yml b/spec/build/testsuites/libtests/dl05.yml
index 80f72131d0..f654218eba 100644
--- a/spec/build/testsuites/libtests/dl05.yml
+++ b/spec/build/testsuites/libtests/dl05.yml
@@ -35,6 +35,7 @@ links: []
 prepare-build: null
 stlib: []
+target: testsuites/libtests/dl05.exe
 type: build
 use-after: []
 use-before: []
diff --git a/spec/build/testsuites/libtests/dl06.yml b/spec/build/testsuites/libtests/dl06.yml
index 0fc5af1478..601147f3c4 100644
--- a/spec/build/testsuites/libtests/dl06.yml
+++ b/spec/build/testsuites/libtests/dl06.yml
@@ -44,6 +44,7 @@ links: []
 prepare-build: null
 stlib: []
+target: testsuites/libtests/dl06.exe
 type: build
 use-after: []
 use-before: []
diff --git a/spec/build/testsuites/libtests/dl07.yml b/spec/build/testsuites/libtests/dl07.yml
index 82dd3ccdde..01a85252f2 100644
--- a/spec/build/testsuites/libtests/dl07.yml
+++ b/spec/build/testsuites/libtests/dl07.yml
@@ -37,6 +37,7 @@ links: []
 prepare-build: null
 stlib: []
+target: testsuites/libtests/dl07.exe
 type: build
 use-after: []
 use-before: []
diff --git a/spec/build/testsuites/libtests/dl08.yml b/spec/build/testsuites/libtests/dl08.yml
index d3982f2357..cc1acf0dc3 100644
--- a/spec/build/testsuites/libtests/dl08.yml
+++ b/spec/build/testsuites/libtests/dl08.yml
@@ -42,6 +42,7 @@ links: []
 prepare-build: null
 stlib: []
+target: testsuites/libtests/dl08.exe
 type: build
 use-after: []
 use-before: []
diff --git a/spec/build/testsuites/libtests/dl09.yml b/spec/build/testsuites/libtests/dl09.yml
index 11066d2c0d..f492daaff2 100644
--- a/spec/build/testsuites/libtests/dl09.yml
+++ b/spec/build/testsuites/libtests/dl09.yml
 prepare-build: null
 stlib: []
+target: testsuites/libtests/dl09.exe
 type: build
 use-after: []
 use-before: []
diff --git a/spec/build/testsuites/libtests/dl10.yml b/spec/build/testsuites/libtests/dl10.yml
index 880abeff9b..fd13dfc790 100644
--- a/spec/build/testsuites/libtests/dl10.yml
+++ b/spec/build/testsuites/libtests/dl10.yml
 prepare-build: null
 stlib: []
+target: testsuites/libtests/dl10.exe
 type: build
 use-after: []
 use-before: []
diff --git a/spec/build/testsuites/libtests/dl11.yml b/spec/build/testsuites/libtests/dl11.yml
index 6eaaeaeecc..29021a3fb5 100644
--- a/spec/build/testsuites/libtests/dl11.yml
+++ b/spec/build/testsuites/libtests/dl11.yml
 prepare-build: null
 stlib: []
+target: testsuites/libtests/dl11.exe
 type: build
 use-after: []
 use-before: []
diff --git a/spec/build/testsuites/libtests/tar01.yml b/spec/build/testsuites/libtests/tar01.yml
index c2fb7767e2..5afd851155 100644
--- a/spec/build/testsuites/libtests/tar01.yml
+++ b/spec/build/testsuites/libtests/tar01.yml
@@ -29,6 +29,7 @@ links: []
 prepare-build: null
 stlib: []
+target: testsuites/libtests/tar01.exe
 type: build
 use-after:
 - z
diff --git a/spec/build/testsuites/libtests/tar02.yml b/spec/build/testsuites/libtests/tar02.yml
index 382920342b..5594299e53 100644
--- a/spec/build/testsuites/libtests/tar02.yml
+++ b/spec/build/testsuites/libtests/tar02.yml
@@ -23,6 +23,7 @@ links: []
 prepare-build: null
 stlib: []
+target: testsuites/libtests/tar02.exe
 type: build
 use-after:
 - z
diff --git a/spec/build/testsuites/psxtests/psxftw01.yml b/spec/build/testsuites/psxtests/psxftw01.yml
index c8b2a4fb59..0f285d3352 100644
--- a/spec/build/testsuites/psxtests/psxftw01.yml
+++ b/spec/build/testsuites/psxtests/psxftw01.yml
@@ -28,6 +28,7 @@ links: []
 prepare-build: null
 stlib: []
+target: testsuites/libtests/psxftw01.exe
 type: build
 use-after:
 - z
2.35.3
