[tools] tester: Use shorter SHA512 encoding
Thu Aug 10 13:52:17 UTC 2023
Encode the SHA512 digest in base64urlsafe instead of a hex string to
reduce the report size.
 tester/rt/test.py | 3 ++-
 1 file changed, 2 insertions(+), 1 deletion(-)
diff --git a/tester/rt/test.py b/tester/rt/test.py
index 2b5ad85..0e22002 100644
--- a/tester/rt/test.py
+++ b/tester/rt/test.py
@@ -329,13 +329,14 @@ def generate_yaml_report(args, reports, start_time, end_time,
 def get_hash512(exe):
     """ returns SHA512 hash string of a given binary file passed as argument """
+    import base64
     import hashlib
     hash = hashlib.sha512()
     with open(exe, "rb") as f:
         for byte_block in iter(lambda: f.read(4096), b""):
             hash.update(byte_block)
-    return hash.hexdigest()
+    return base64.urlsafe_b64encode(hash.digest()).decode("ascii")
 report_formatters = {
2.35.3
