[PATCH rtems-libbsd 2/2] rtemsbsd/sys/arm: Add imxrt1166 USBPHY driver
Christian Mauderer christian.mauderer at embedded-brains.de
Fri Aug 11 05:37:36 UTC 2023
Adds a driver for the i.MXRT1166 USB PHY and enable USB for the
imxrt11xx BSPs.
 libbsd.py                                     |   6 +
 rtemsbsd/include/bsp/nexus-devices.h          |   8 +
 .../sys/arm/freescale/imx/imxrt1166_usbphy.c  | 227 ++++++++++++++++++
 3 files changed, 241 insertions(+)
 create mode 100644 rtemsbsd/sys/arm/freescale/imx/imxrt1166_usbphy.c
diff --git a/libbsd.py b/libbsd.py
index e3840f37..db390df0 100644
--- a/libbsd.py
+++ b/libbsd.py
@@ -5334,6 +5334,12 @@ class imx(builder.Module):
             mm.generator['source']()
+        self.addRTEMSKernelSourceFiles(
+                'sys/arm/freescale/imx/imxrt1166_usbphy.c',
+            mm.generator['source']()
 class regulator(builder.Module):
     def __init__(self, manager):
diff --git a/rtemsbsd/include/bsp/nexus-devices.h b/rtemsbsd/include/bsp/nexus-devices.h
index d98e6f76..37008cc6 100644
--- a/rtemsbsd/include/bsp/nexus-devices.h
+++ b/rtemsbsd/include/bsp/nexus-devices.h
@@ -173,6 +173,14 @@ SYSINIT_DRIVER_REFERENCE(simplebus, ofwbus);
 SYSINIT_DRIVER_REFERENCE(ffec, simplebus);
 SYSINIT_DRIVER_REFERENCE(ksz8091rnb, miibus);
+#if IMXRT_IS_MIMXRT11xx
+SYSINIT_DRIVER_REFERENCE(ehci, simplebus);
+SYSINIT_DRIVER_REFERENCE(imxrt1166_usbphy, simplebus);
+SYSINIT_DRIVER_REFERENCE(usbus, ehci);
+RTEMS_BSD_DRIVER_USB;
+RTEMS_BSD_DRIVER_USB_MASS;
+#endif /* IMXRT_IS_IMXRT11xx */
 #elif defined(LIBBSP_ARM_LPC24XX_BSP_H)
 RTEMS_BSD_DEFINE_NEXUS_DEVICE(ohci, 0, 0, NULL);
diff --git a/rtemsbsd/sys/arm/freescale/imx/imxrt1166_usbphy.c b/rtemsbsd/sys/arm/freescale/imx/imxrt1166_usbphy.c
new file mode 100644
index 00000000..b8e3a188
--- /dev/null
+++ b/rtemsbsd/sys/arm/freescale/imx/imxrt1166_usbphy.c
@@ -0,0 +1,227 @@
+#include <machine/rtems-bsd-kernel-space.h>
+ * Copyright (c) 2013 Ian Lepore <ian at freebsd.org>
+ * Copyright (C) 2023 embedded brains GmbH & Co. KG
+ * All rights reserved.
+ * are met:
+ * THIS SOFTWARE IS PROVIDED BY THE AUTHOR AND CONTRIBUTORS ``AS IS'' AND
+ * ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
+ * ARE DISCLAIMED.  IN NO EVENT SHALL THE AUTHOR OR CONTRIBUTORS BE LIABLE
+ * FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL
+ * DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS
+ * OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION)
+ * HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT
+ * LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY
+ * OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF
+ * SUCH DAMAGE.
+#include <bsp.h>
+#if defined(LIBBSP_ARM_IMXRT_BSP_H)
+#include <sys/cdefs.h>
+__FBSDID("$FreeBSD$");
+ * USBPHY driver for Freescale i.MXRT1166. Most likely works with the whole
+ * i.MXRT11xx family.
+ * Based on USBPHY driver for i.MX6.
+#include <rtems/bsd/local/opt_bus.h>
+#include <sys/param.h>
+#include <sys/systm.h>
+#include <sys/kernel.h>
+#include <sys/module.h>
+#include <sys/bus.h>
+#include <sys/rman.h>
+#include <dev/ofw/ofw_bus.h>
+#include <dev/ofw/ofw_bus_subr.h>
+#include <machine/bus.h>
+#include <dev/extres/regulator/regulator.h>
+#include <fsl_device_registers.h>
+#include <fsl_clock.h>
+struct imxrt1166_usbphy_softc {
+	device_t	dev;
+	struct resource	*mem_res;
+	regulator_t	supply_vbus;
+	USBPHY_Type	*regs;
+static struct ofw_compat_data compat_data[] = {
+	{"fsl,imxrt1166-usbphy",	true},
+	{NULL,				false}
+static int
+imxrt1166_usbphy_detach(device_t dev)
+	struct imxrt1166_usbphy_softc *sc;
+	sc = device_get_softc(dev);
+	if (sc->mem_res != NULL)
+		bus_release_resource(dev, SYS_RES_MEMORY, 0, sc->mem_res);
+	return (0);
+#define BUS_SPACE_PHYSADDR(res, offs) \
+	((u_int)(rman_get_start(res)+(offs)))
+static int
+enable_vbus_supply(device_t dev, struct imxrt1166_usbphy_softc *sc)
+	int rv;
+	phandle_t node;
+	node = ofw_bus_get_node(dev);
+	if (OF_hasprop(node, "vbus-supply")) {
+		rv = regulator_get_by_ofw_property(sc->dev, node, "vbus-supply",
+		    &sc->supply_vbus);
+		if (rv != 0) {
+			device_printf(sc->dev,
+			   "Cannot get \"vbus\" regulator\n");
+			return ENXIO;
+		rv = regulator_enable(sc->supply_vbus);
+		if (rv != 0) {
+			    "Cannot enable  \"vbus\" regulator\n");
+			return ENXIO;
+	return 0;
+static int
+imxrt1166_usbphy_attach(device_t dev)
+	int err, rid;
+	uint32_t usbClockFreq;
+#endif
+	err = 0;
+	/* Allocate bus_space resources. */
+	rid = 0;
+	sc->mem_res = bus_alloc_resource_any(dev, SYS_RES_MEMORY, &rid,
+	    RF_ACTIVE);
+	if (sc->mem_res == NULL) {
+		device_printf(dev, "Cannot allocate memory resources\n");
+		err = ENXIO;
+		goto out;
+	/* Enable VBUS Supply if a regulator is given */
+	err = enable_vbus_supply(dev, sc);
+	if (err != 0) {
+		goto out;
+	sc->regs = (USBPHY_Type *)BUS_SPACE_PHYSADDR(sc->mem_res, 0);
+	/* Enable register clock */
+	CLOCK_EnableClock(kCLOCK_Usb);
+	usbClockFreq = CLOCK_GetFreq(kCLOCK_Osc24M);
+	 * Set the software reset bit. It will be implicitly cleared when
+	 * setting up the clock in the next steps.
+	sc->regs->CTRL_SET = USBPHY_CTRL_SFTRST_MASK;
+	 * Enable PLLs.
+	 * FIXME: Hacky way to find out the module.
+	if (sc->regs == USBPHY1) {
+		CLOCK_EnableUsbhs0PhyPllClock(kCLOCK_Usbphy480M, usbClockFreq);
+		CLOCK_EnableUsbhs0Clock(kCLOCK_Usb480M, usbClockFreq);
+	} else {
+		CLOCK_EnableUsbhs1PhyPllClock(kCLOCK_Usbphy480M, usbClockFreq);
+		CLOCK_EnableUsbhs1Clock(kCLOCK_Usb480M, usbClockFreq);
+#else
+	/* Not implemented */
+#endif
+	err = 0;
+out:
+	if (err != 0)
+		imxrt1166_usbphy_detach(dev);
+	return (err);
+static int
+imxrt1166_usbphy_probe(device_t dev)
+	if (!ofw_bus_status_okay(dev))
+		return (ENXIO);
+	if (!ofw_bus_search_compatible(dev, compat_data)->ocd_data)
+		return (ENXIO);
+	device_set_desc(dev, "Freescale i.MXRT1166 USB PHY");
+	return (BUS_PROBE_DEFAULT);
+static device_method_t imxrt1166_usbphy_methods[] = {
+	/* Device interface */
+	DEVMETHOD(device_probe,  imxrt1166_usbphy_probe),
+	DEVMETHOD(device_attach, imxrt1166_usbphy_attach),
+	DEVMETHOD(device_detach, imxrt1166_usbphy_detach),
+	DEVMETHOD_END
+static driver_t imxrt1166_usbphy_driver = {
+	"imxrt1166_usbphy",
+	imxrt1166_usbphy_methods,
+	sizeof(struct imxrt1166_usbphy_softc)
+static devclass_t imxrt1166_usbphy_devclass;
+ * This driver needs to start before the ehci driver, but later than the usual
+ * "special" drivers like clocks and cpu.  Ehci starts at DEFAULT so SUPPORTDEV
+ * is where this driver fits most.
+EARLY_DRIVER_MODULE(imxrt1166_usbphy, simplebus, imxrt1166_usbphy_driver,
+    imxrt1166_usbphy_devclass, 0, 0,
+    BUS_PASS_SUPPORTDEV + BUS_PASS_ORDER_MIDDLE);
+#endif /* LIBBSP_ARM_IMXRT_BSP_H */
2.35.3
