[PATCH rtems 2/3] bsps/arm/imxrt1166: Enable USB
Christian Mauderer christian.mauderer at embedded-brains.de
Fri Aug 11 05:37:33 UTC 2023
Enable the USB modules in the FDT.
 bsps/arm/imxrt/dts/imxrt1166-cm7-saltshaker.c | 115 +++++++++++-------
 .../imxrt/dts/imxrt1166-cm7-saltshaker.dts    |   8 ++
 bsps/arm/imxrt/include/imxrt/imxrt1166.dtsi   |   8 ++
 3 files changed, 85 insertions(+), 46 deletions(-)
diff --git a/bsps/arm/imxrt/dts/imxrt1166-cm7-saltshaker.c b/bsps/arm/imxrt/dts/imxrt1166-cm7-saltshaker.c
index f533172bbc..78e7feda09 100644
--- a/bsps/arm/imxrt/dts/imxrt1166-cm7-saltshaker.c
+++ b/bsps/arm/imxrt/dts/imxrt1166-cm7-saltshaker.c
@@ -7,10 +7,10 @@
 #include <sys/types.h>
 const unsigned char imxrt_dtb[] __attribute__(( __aligned__(8) )) = {
-  0xd0, 0x0d, 0xfe, 0xed, 0x00, 0x00, 0x6f, 0xdf, 0x00, 0x00, 0x00, 0x38,
-  0x00, 0x00, 0x69, 0xa0, 0x00, 0x00, 0x00, 0x28, 0x00, 0x00, 0x00, 0x11,
-  0x00, 0x00, 0x00, 0x10, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x05, 0xff,
-  0x00, 0x00, 0x69, 0x68, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
+  0xd0, 0x0d, 0xfe, 0xed, 0x00, 0x00, 0x70, 0xf2, 0x00, 0x00, 0x00, 0x38,
+  0x00, 0x00, 0x6a, 0xa8, 0x00, 0x00, 0x00, 0x28, 0x00, 0x00, 0x00, 0x11,
+  0x00, 0x00, 0x00, 0x10, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x06, 0x0a,
+  0x00, 0x00, 0x6a, 0x70, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
   0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x01,
   0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x03, 0x00, 0x00, 0x00, 0x04,
   0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x01, 0x00, 0x00, 0x00, 0x03,
@@ -1239,7 +1239,7 @@ const unsigned char imxrt_dtb[] __attribute__(( __aligned__(8) )) = {
   0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x0a, 0x00, 0x00, 0x02, 0x50,
   0x00, 0x00, 0x04, 0x94, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
   0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x0a, 0x00, 0x00, 0x00, 0x03,
-  0x00, 0x00, 0x00, 0x04, 0x00, 0x00, 0x04, 0xab, 0x00, 0x00, 0x00, 0x0d,
+  0x00, 0x00, 0x00, 0x04, 0x00, 0x00, 0x04, 0xab, 0x00, 0x00, 0x00, 0x0f,
   0x00, 0x00, 0x00, 0x02, 0x00, 0x00, 0x00, 0x01, 0x6c, 0x65, 0x64, 0x67,
   0x72, 0x70, 0x00, 0x00, 0x00, 0x00, 0x00, 0x03, 0x00, 0x00, 0x00, 0x48,
   0x00, 0x00, 0x05, 0x0c, 0x00, 0x00, 0x01, 0x4c, 0x00, 0x00, 0x03, 0x90,
@@ -1249,7 +1249,7 @@ const unsigned char imxrt_dtb[] __attribute__(( __aligned__(8) )) = {
   0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x01, 0x58, 0x00, 0x00, 0x03, 0x9c,
   0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x0a, 0x00, 0x00, 0x00, 0x00,
-  0x00, 0x00, 0x04, 0xab, 0x00, 0x00, 0x00, 0x11, 0x00, 0x00, 0x00, 0x02,
+  0x00, 0x00, 0x04, 0xab, 0x00, 0x00, 0x00, 0x13, 0x00, 0x00, 0x00, 0x02,
   0x00, 0x00, 0x00, 0x02, 0x00, 0x00, 0x00, 0x01, 0x74, 0x69, 0x6d, 0x65,
   0x72, 0x40, 0x34, 0x30, 0x30, 0x65, 0x63, 0x30, 0x30, 0x30, 0x00, 0x00,
   0x00, 0x00, 0x00, 0x03, 0x00, 0x00, 0x00, 0x08, 0x00, 0x00, 0x04, 0xa7,
@@ -1745,22 +1745,44 @@ const unsigned char imxrt_dtb[] __attribute__(( __aligned__(8) )) = {
   0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x03, 0x00, 0x00, 0x00, 0x08,
   0x00, 0x00, 0x04, 0xa7, 0x40, 0x42, 0xc0, 0x00, 0x00, 0x00, 0x40, 0x00,
   0x00, 0x00, 0x00, 0x03, 0x00, 0x00, 0x00, 0x04, 0x00, 0x00, 0x04, 0xd2,
-  0x00, 0x00, 0x00, 0x87, 0x00, 0x00, 0x00, 0x02, 0x00, 0x00, 0x00, 0x01,
-  0x75, 0x73, 0x62, 0x40, 0x34, 0x30, 0x34, 0x33, 0x30, 0x30, 0x30, 0x30,
-  0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x03, 0x00, 0x00, 0x00, 0x08,
-  0x00, 0x00, 0x04, 0xa7, 0x40, 0x43, 0x00, 0x00, 0x00, 0x00, 0x40, 0x00,
-  0x00, 0x00, 0x00, 0x03, 0x00, 0x00, 0x00, 0x04, 0x00, 0x00, 0x04, 0xd2,
-  0x00, 0x00, 0x00, 0x88, 0x00, 0x00, 0x00, 0x02, 0x00, 0x00, 0x00, 0x01,
-  0x75, 0x73, 0x62, 0x70, 0x68, 0x79, 0x40, 0x34, 0x30, 0x34, 0x33, 0x34,
-  0x30, 0x30, 0x30, 0x00, 0x00, 0x00, 0x00, 0x03, 0x00, 0x00, 0x00, 0x08,
-  0x00, 0x00, 0x04, 0xa7, 0x40, 0x43, 0x40, 0x00, 0x00, 0x00, 0x40, 0x00,
-  0x00, 0x00, 0x00, 0x5a, 0x00, 0x00, 0x00, 0x02, 0x00, 0x00, 0x00, 0x01,
-  0x75, 0x73, 0x62, 0x70, 0x68, 0x79, 0x40, 0x34, 0x30, 0x34, 0x33, 0x38,
-  0x00, 0x00, 0x04, 0xa7, 0x40, 0x43, 0x80, 0x00, 0x00, 0x00, 0x40, 0x00,
-  0x00, 0x00, 0x00, 0x5b, 0x00, 0x00, 0x00, 0x02, 0x00, 0x00, 0x00, 0x01,
+  0x00, 0x00, 0x00, 0x87, 0x00, 0x00, 0x00, 0x03, 0x00, 0x00, 0x00, 0x20,
+  0x00, 0x00, 0x04, 0x76, 0x66, 0x73, 0x6c, 0x2c, 0x69, 0x6d, 0x78, 0x72,
+  0x74, 0x31, 0x31, 0x36, 0x36, 0x2d, 0x75, 0x73, 0x62, 0x00, 0x66, 0x73,
+  0x6c, 0x2c, 0x69, 0x6d, 0x78, 0x32, 0x37, 0x2d, 0x75, 0x73, 0x62, 0x00,
+  0x00, 0x00, 0x00, 0x03, 0x00, 0x00, 0x00, 0x04, 0x00, 0x00, 0x05, 0xa9,
+  0x00, 0x00, 0x00, 0x0d, 0x00, 0x00, 0x00, 0x03, 0x00, 0x00, 0x00, 0x05,
+  0x00, 0x00, 0x04, 0xb3, 0x6f, 0x6b, 0x61, 0x79, 0x00, 0x00, 0x00, 0x00,
+  0x00, 0x00, 0x00, 0x02, 0x00, 0x00, 0x00, 0x01, 0x75, 0x73, 0x62, 0x40,
+  0x34, 0x30, 0x34, 0x33, 0x30, 0x30, 0x30, 0x30, 0x00, 0x00, 0x00, 0x00,
+  0x00, 0x00, 0x00, 0x03, 0x00, 0x00, 0x00, 0x08, 0x00, 0x00, 0x04, 0xa7,
+  0x40, 0x43, 0x00, 0x00, 0x00, 0x00, 0x40, 0x00, 0x00, 0x00, 0x00, 0x03,
+  0x00, 0x00, 0x00, 0x04, 0x00, 0x00, 0x04, 0xd2, 0x00, 0x00, 0x00, 0x88,
+  0x00, 0x00, 0x00, 0x03, 0x00, 0x00, 0x00, 0x20, 0x00, 0x00, 0x04, 0x76,
+  0x66, 0x73, 0x6c, 0x2c, 0x69, 0x6d, 0x78, 0x72, 0x74, 0x31, 0x31, 0x36,
+  0x36, 0x2d, 0x75, 0x73, 0x62, 0x00, 0x66, 0x73, 0x6c, 0x2c, 0x69, 0x6d,
+  0x78, 0x32, 0x37, 0x2d, 0x75, 0x73, 0x62, 0x00, 0x00, 0x00, 0x00, 0x03,
+  0x00, 0x00, 0x00, 0x04, 0x00, 0x00, 0x05, 0xa9, 0x00, 0x00, 0x00, 0x0e,
+  0x00, 0x00, 0x00, 0x03, 0x00, 0x00, 0x00, 0x05, 0x00, 0x00, 0x04, 0xb3,
+  0x6f, 0x6b, 0x61, 0x79, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x02,
+  0x00, 0x00, 0x00, 0x01, 0x75, 0x73, 0x62, 0x70, 0x68, 0x79, 0x40, 0x34,
+  0x30, 0x34, 0x33, 0x34, 0x30, 0x30, 0x30, 0x00, 0x00, 0x00, 0x00, 0x03,
+  0x00, 0x00, 0x00, 0x08, 0x00, 0x00, 0x04, 0xa7, 0x40, 0x43, 0x40, 0x00,
+  0x00, 0x00, 0x40, 0x00, 0x00, 0x00, 0x00, 0x03, 0x00, 0x00, 0x00, 0x04,
+  0x00, 0x00, 0x04, 0xd2, 0x00, 0x00, 0x00, 0x5a, 0x00, 0x00, 0x00, 0x03,
+  0x00, 0x00, 0x00, 0x15, 0x00, 0x00, 0x04, 0x76, 0x66, 0x73, 0x6c, 0x2c,
+  0x69, 0x6d, 0x78, 0x72, 0x74, 0x31, 0x31, 0x36, 0x36, 0x2d, 0x75, 0x73,
+  0x62, 0x70, 0x68, 0x79, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x03,
+  0x00, 0x00, 0x00, 0x04, 0x00, 0x00, 0x04, 0xab, 0x00, 0x00, 0x00, 0x0e,
+  0x00, 0x00, 0x00, 0x02, 0x00, 0x00, 0x00, 0x01, 0x75, 0x73, 0x62, 0x70,
+  0x68, 0x79, 0x40, 0x34, 0x30, 0x34, 0x33, 0x38, 0x30, 0x30, 0x30, 0x00,
+  0x40, 0x43, 0x80, 0x00, 0x00, 0x00, 0x40, 0x00, 0x00, 0x00, 0x00, 0x03,
+  0x00, 0x00, 0x00, 0x04, 0x00, 0x00, 0x04, 0xd2, 0x00, 0x00, 0x00, 0x5b,
+  0x00, 0x00, 0x00, 0x03, 0x00, 0x00, 0x00, 0x15, 0x00, 0x00, 0x04, 0x76,
+  0x36, 0x2d, 0x75, 0x73, 0x62, 0x70, 0x68, 0x79, 0x00, 0x00, 0x00, 0x00,
+  0x00, 0x00, 0x00, 0x03, 0x00, 0x00, 0x00, 0x04, 0x00, 0x00, 0x04, 0xab,
+  0x00, 0x00, 0x00, 0x0d, 0x00, 0x00, 0x00, 0x02, 0x00, 0x00, 0x00, 0x01,
   0x63, 0x61, 0x61, 0x6d, 0x40, 0x34, 0x30, 0x34, 0x34, 0x30, 0x30, 0x30,
   0x30, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x03, 0x00, 0x00, 0x00, 0x08,
   0x00, 0x00, 0x04, 0xa7, 0x40, 0x44, 0x00, 0x00, 0x00, 0x10, 0x00, 0x00,
@@ -1814,7 +1836,7 @@ const unsigned char imxrt_dtb[] __attribute__(( __aligned__(8) )) = {
   0x40, 0x81, 0x80, 0x00, 0x00, 0x00, 0x40, 0x00, 0x00, 0x00, 0x00, 0x03,
   0x00, 0x00, 0x00, 0x08, 0x00, 0x00, 0x04, 0xd2, 0x00, 0x00, 0x00, 0x5f,
   0x00, 0x00, 0x00, 0x60, 0x00, 0x00, 0x00, 0x03, 0x00, 0x00, 0x00, 0x04,
-  0x00, 0x00, 0x05, 0x02, 0x00, 0x00, 0x00, 0x0d, 0x00, 0x00, 0x00, 0x02,
+  0x00, 0x00, 0x05, 0x02, 0x00, 0x00, 0x00, 0x0f, 0x00, 0x00, 0x00, 0x02,
   0x00, 0x00, 0x00, 0x02, 0x00, 0x00, 0x00, 0x01, 0x61, 0x69, 0x70, 0x73,
   0x2d, 0x62, 0x75, 0x73, 0x40, 0x34, 0x30, 0x63, 0x30, 0x30, 0x30, 0x30,
   0x30, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x03, 0x00, 0x00, 0x00, 0x18,
@@ -1850,7 +1872,7 @@ const unsigned char imxrt_dtb[] __attribute__(( __aligned__(8) )) = {
   0x40, 0x00, 0x00, 0x11, 0x00, 0x00, 0x00, 0x20, 0x00, 0x00, 0x00, 0x60,
   0x00, 0x00, 0x00, 0x88, 0x00, 0x00, 0x00, 0x06, 0x00, 0x00, 0x00, 0x01,
   0x40, 0x00, 0x00, 0x11, 0x00, 0x00, 0x00, 0x03, 0x00, 0x00, 0x00, 0x04,
-  0x00, 0x00, 0x04, 0xab, 0x00, 0x00, 0x00, 0x0f, 0x00, 0x00, 0x00, 0x02,
+  0x00, 0x00, 0x04, 0xab, 0x00, 0x00, 0x00, 0x11, 0x00, 0x00, 0x00, 0x02,
   0x00, 0x00, 0x00, 0x01, 0x6c, 0x70, 0x69, 0x32, 0x63, 0x36, 0x67, 0x72,
   0x70, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x03, 0x00, 0x00, 0x00, 0x30,
   0x00, 0x00, 0x05, 0x0c, 0x00, 0x00, 0x00, 0x1c, 0x00, 0x00, 0x00, 0x5c,
@@ -1858,7 +1880,7 @@ const unsigned char imxrt_dtb[] __attribute__(( __aligned__(8) )) = {
   0x40, 0x00, 0x00, 0x11, 0x00, 0x00, 0x00, 0x18, 0x00, 0x00, 0x00, 0x58,
   0x00, 0x00, 0x00, 0x90, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
-  0x00, 0x00, 0x04, 0xab, 0x00, 0x00, 0x00, 0x10, 0x00, 0x00, 0x00, 0x02,
+  0x00, 0x00, 0x04, 0xab, 0x00, 0x00, 0x00, 0x12, 0x00, 0x00, 0x00, 0x02,
   0x00, 0x00, 0x00, 0x01, 0x6c, 0x70, 0x75, 0x61, 0x72, 0x74, 0x31, 0x32,
   0x67, 0x72, 0x70, 0x00, 0x00, 0x00, 0x00, 0x03, 0x00, 0x00, 0x00, 0x60,
   0x00, 0x00, 0x05, 0x0c, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x40,
@@ -1870,7 +1892,7 @@ const unsigned char imxrt_dtb[] __attribute__(( __aligned__(8) )) = {
   0x00, 0x00, 0x00, 0x0d, 0x00, 0x00, 0x00, 0x14, 0x00, 0x00, 0x00, 0x54,
   0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x03, 0x00, 0x00, 0x00, 0x00,
   0x00, 0x00, 0x00, 0x0d, 0x00, 0x00, 0x00, 0x03, 0x00, 0x00, 0x00, 0x04,
-  0x00, 0x00, 0x04, 0xab, 0x00, 0x00, 0x00, 0x0e, 0x00, 0x00, 0x00, 0x02,
+  0x00, 0x00, 0x04, 0xab, 0x00, 0x00, 0x00, 0x10, 0x00, 0x00, 0x00, 0x02,
   0x00, 0x00, 0x00, 0x02, 0x00, 0x00, 0x00, 0x01, 0x69, 0x6f, 0x6d, 0x75,
   0x78, 0x63, 0x5f, 0x6c, 0x70, 0x73, 0x72, 0x5f, 0x67, 0x70, 0x72, 0x40,
   0x34, 0x30, 0x63, 0x30, 0x63, 0x30, 0x30, 0x30, 0x00, 0x00, 0x00, 0x00,
@@ -1931,7 +1953,7 @@ const unsigned char imxrt_dtb[] __attribute__(( __aligned__(8) )) = {
   0x00, 0x00, 0x00, 0x02, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x1e,
   0x00, 0x00, 0x00, 0x02, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x1f,
   0x00, 0x00, 0x00, 0x03, 0x00, 0x00, 0x00, 0x04, 0x00, 0x00, 0x05, 0x02,
-  0x00, 0x00, 0x00, 0x0e, 0x00, 0x00, 0x00, 0x02, 0x00, 0x00, 0x00, 0x01,
+  0x00, 0x00, 0x00, 0x10, 0x00, 0x00, 0x00, 0x02, 0x00, 0x00, 0x00, 0x01,
   0x73, 0x70, 0x69, 0x40, 0x34, 0x30, 0x63, 0x32, 0x63, 0x30, 0x30, 0x30,
@@ -1985,7 +2007,7 @@ const unsigned char imxrt_dtb[] __attribute__(( __aligned__(8) )) = {
   0x2f, 0x69, 0x32, 0x63, 0x35, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x03,
   0x00, 0x00, 0x00, 0x0c, 0x00, 0x00, 0x04, 0xfd, 0x00, 0x00, 0x00, 0x02,
   0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x34, 0x00, 0x00, 0x00, 0x03,
-  0x00, 0x00, 0x00, 0x04, 0x00, 0x00, 0x05, 0x02, 0x00, 0x00, 0x00, 0x0f,
+  0x00, 0x00, 0x00, 0x04, 0x00, 0x00, 0x05, 0x02, 0x00, 0x00, 0x00, 0x11,
   0x00, 0x00, 0x00, 0x02, 0x00, 0x00, 0x00, 0x01, 0x69, 0x32, 0x63, 0x40,
   0x34, 0x30, 0x63, 0x33, 0x38, 0x30, 0x30, 0x30, 0x00, 0x00, 0x00, 0x00,
   0x00, 0x00, 0x00, 0x03, 0x00, 0x00, 0x00, 0x04, 0x00, 0x00, 0x00, 0x00,
@@ -2003,7 +2025,7 @@ const unsigned char imxrt_dtb[] __attribute__(( __aligned__(8) )) = {
   0x00, 0x00, 0x00, 0x03, 0x00, 0x00, 0x00, 0x0c, 0x00, 0x00, 0x04, 0xfd,
   0x00, 0x00, 0x00, 0x02, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x35,
-  0x00, 0x00, 0x00, 0x10, 0x00, 0x00, 0x00, 0x02, 0x00, 0x00, 0x00, 0x01,
+  0x00, 0x00, 0x00, 0x12, 0x00, 0x00, 0x00, 0x02, 0x00, 0x00, 0x00, 0x01,
   0x63, 0x61, 0x6e, 0x40, 0x34, 0x30, 0x63, 0x33, 0x63, 0x30, 0x30, 0x30,
   0x00, 0x00, 0x04, 0xa7, 0x40, 0xc3, 0xc0, 0x00, 0x00, 0x00, 0x40, 0x00,
@@ -2069,7 +2091,7 @@ const unsigned char imxrt_dtb[] __attribute__(( __aligned__(8) )) = {
   0x00, 0x00, 0x00, 0x03, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x05, 0x15,
   0x00, 0x00, 0x00, 0x03, 0x00, 0x00, 0x00, 0x04, 0x00, 0x00, 0x05, 0x25,
   0x00, 0x00, 0x00, 0x02, 0x00, 0x00, 0x00, 0x03, 0x00, 0x00, 0x00, 0x04,
-  0x00, 0x00, 0x04, 0xab, 0x00, 0x00, 0x00, 0x12, 0x00, 0x00, 0x00, 0x02,
+  0x00, 0x00, 0x04, 0xab, 0x00, 0x00, 0x00, 0x14, 0x00, 0x00, 0x00, 0x02,
   0x00, 0x00, 0x00, 0x01, 0x67, 0x70, 0x69, 0x6f, 0x40, 0x34, 0x30, 0x63,
   0x36, 0x63, 0x30, 0x30, 0x30, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x03,
   0x00, 0x00, 0x00, 0x2e, 0x00, 0x00, 0x04, 0x76, 0x66, 0x73, 0x6c, 0x2c,
@@ -2233,7 +2255,7 @@ const unsigned char imxrt_dtb[] __attribute__(( __aligned__(8) )) = {
   0x72, 0x6f, 0x6c, 0x6c, 0x65, 0x72, 0x00, 0x00, 0x00, 0x00, 0x00, 0x03,
   0x00, 0x00, 0x00, 0x0a, 0x00, 0x00, 0x04, 0x76, 0x67, 0x70, 0x69, 0x6f,
   0x2d, 0x6c, 0x65, 0x64, 0x73, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x03,
-  0x00, 0x00, 0x00, 0x04, 0x00, 0x00, 0x05, 0x02, 0x00, 0x00, 0x00, 0x11,
+  0x00, 0x00, 0x00, 0x04, 0x00, 0x00, 0x05, 0x02, 0x00, 0x00, 0x00, 0x13,
   0x6f, 0x6b, 0x61, 0x79, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x01,
   0x6c, 0x65, 0x64, 0x2d, 0x30, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x03,
@@ -2250,14 +2272,14 @@ const unsigned char imxrt_dtb[] __attribute__(( __aligned__(8) )) = {
   0x63, 0x61, 0x72, 0x64, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x03,
   0x00, 0x00, 0x00, 0x10, 0x00, 0x00, 0x04, 0x76, 0x72, 0x65, 0x67, 0x75,
   0x6c, 0x61, 0x74, 0x6f, 0x72, 0x2d, 0x66, 0x69, 0x78, 0x65, 0x64, 0x00,
-  0x00, 0x00, 0x00, 0x03, 0x00, 0x00, 0x00, 0x0e, 0x00, 0x00, 0x05, 0xa9,
+  0x00, 0x00, 0x00, 0x03, 0x00, 0x00, 0x00, 0x0e, 0x00, 0x00, 0x05, 0xb4,
   0x75, 0x73, 0x64, 0x68, 0x63, 0x31, 0x2d, 0x73, 0x75, 0x70, 0x70, 0x6c,
   0x79, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x03, 0x00, 0x00, 0x00, 0x04,
-  0x00, 0x00, 0x05, 0xb8, 0x00, 0x32, 0x5a, 0xa0, 0x00, 0x00, 0x00, 0x03,
-  0x00, 0x00, 0x00, 0x04, 0x00, 0x00, 0x05, 0xd0, 0x00, 0x32, 0x5a, 0xa0,
-  0x00, 0x00, 0x00, 0x03, 0x00, 0x00, 0x00, 0x0c, 0x00, 0x00, 0x05, 0xe8,
-  0x00, 0x00, 0x00, 0x12, 0x00, 0x00, 0x00, 0x02, 0x00, 0x00, 0x00, 0x00,
-  0x00, 0x00, 0x00, 0x03, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x05, 0xed,
+  0x00, 0x00, 0x05, 0xc3, 0x00, 0x32, 0x5a, 0xa0, 0x00, 0x00, 0x00, 0x03,
+  0x00, 0x00, 0x00, 0x04, 0x00, 0x00, 0x05, 0xdb, 0x00, 0x32, 0x5a, 0xa0,
+  0x00, 0x00, 0x00, 0x03, 0x00, 0x00, 0x00, 0x0c, 0x00, 0x00, 0x05, 0xf3,
+  0x00, 0x00, 0x00, 0x14, 0x00, 0x00, 0x00, 0x02, 0x00, 0x00, 0x00, 0x00,
+  0x00, 0x00, 0x00, 0x03, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x05, 0xf8,
   0x00, 0x00, 0x00, 0x0b, 0x00, 0x00, 0x00, 0x02, 0x00, 0x00, 0x00, 0x02,
   0x00, 0x00, 0x00, 0x09, 0x23, 0x61, 0x64, 0x64, 0x72, 0x65, 0x73, 0x73,
@@ -2381,19 +2403,20 @@ const unsigned char imxrt_dtb[] __attribute__(( __aligned__(8) )) = {
   0x6d, 0x2d, 0x72, 0x78, 0x2d, 0x71, 0x75, 0x65, 0x75, 0x65, 0x73, 0x00,
   0x70, 0x68, 0x79, 0x2d, 0x6d, 0x6f, 0x64, 0x65, 0x00, 0x70, 0x68, 0x79,
   0x2d, 0x72, 0x65, 0x73, 0x65, 0x74, 0x2d, 0x67, 0x70, 0x69, 0x6f, 0x73,
-  0x00, 0x72, 0x65, 0x67, 0x75, 0x6c, 0x61, 0x74, 0x6f, 0x72, 0x2d, 0x6e,
-  0x61, 0x6d, 0x65, 0x00, 0x72, 0x65, 0x67, 0x75, 0x6c, 0x61, 0x74, 0x6f,
-  0x72, 0x2d, 0x6d, 0x69, 0x6e, 0x2d, 0x6d, 0x69, 0x63, 0x72, 0x6f, 0x76,
-  0x6f, 0x6c, 0x74, 0x00, 0x72, 0x65, 0x67, 0x75, 0x6c, 0x61, 0x74, 0x6f,
-  0x72, 0x2d, 0x6d, 0x61, 0x78, 0x2d, 0x6d, 0x69, 0x63, 0x72, 0x6f, 0x76,
-  0x6f, 0x6c, 0x74, 0x00, 0x67, 0x70, 0x69, 0x6f, 0x00, 0x72, 0x65, 0x67,
-  0x75, 0x6c, 0x61, 0x74, 0x6f, 0x72, 0x2d, 0x62, 0x6f, 0x6f, 0x74, 0x2d,
-  0x6f, 0x6e, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
+  0x00, 0x66, 0x73, 0x6c, 0x2c, 0x75, 0x73, 0x62, 0x70, 0x68, 0x79, 0x00,
+  0x72, 0x65, 0x67, 0x75, 0x6c, 0x61, 0x74, 0x6f, 0x72, 0x2d, 0x6e, 0x61,
+  0x6d, 0x65, 0x00, 0x72, 0x65, 0x67, 0x75, 0x6c, 0x61, 0x74, 0x6f, 0x72,
+  0x2d, 0x6d, 0x69, 0x6e, 0x2d, 0x6d, 0x69, 0x63, 0x72, 0x6f, 0x76, 0x6f,
+  0x6c, 0x74, 0x00, 0x72, 0x65, 0x67, 0x75, 0x6c, 0x61, 0x74, 0x6f, 0x72,
+  0x2d, 0x6d, 0x61, 0x78, 0x2d, 0x6d, 0x69, 0x63, 0x72, 0x6f, 0x76, 0x6f,
+  0x6c, 0x74, 0x00, 0x67, 0x70, 0x69, 0x6f, 0x00, 0x72, 0x65, 0x67, 0x75,
+  0x6c, 0x61, 0x74, 0x6f, 0x72, 0x2d, 0x62, 0x6f, 0x6f, 0x74, 0x2d, 0x6f,
+  0x6e, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
   0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
+  0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
 const size_t imxrt_dtb_size = sizeof(imxrt_dtb);
diff --git a/bsps/arm/imxrt/dts/imxrt1166-cm7-saltshaker.dts b/bsps/arm/imxrt/dts/imxrt1166-cm7-saltshaker.dts
index 81740ce499..c961abcd37 100644
--- a/bsps/arm/imxrt/dts/imxrt1166-cm7-saltshaker.dts
+++ b/bsps/arm/imxrt/dts/imxrt1166-cm7-saltshaker.dts
@@ -127,6 +127,14 @@
 	pinctrl-0 = <&pinctrl_video_mux>;
+&usbotg1 {
+	status = "okay";
+&usbotg2 {
+	status = "okay";
 &iomuxc {
 	pinctrl_lpuart8: lpuart8grp {
 		fsl,pins = <
diff --git a/bsps/arm/imxrt/include/imxrt/imxrt1166.dtsi b/bsps/arm/imxrt/include/imxrt/imxrt1166.dtsi
index 8f7083e2c4..5f88b6fbb0 100644
--- a/bsps/arm/imxrt/include/imxrt/imxrt1166.dtsi
+++ b/bsps/arm/imxrt/include/imxrt/imxrt1166.dtsi
@@ -856,21 +856,29 @@
 			usbotg2: usb at 4042c000 {
 				reg = <0x4042c000 0x4000>;
 				interrupts = <135>;
+				compatible = "fsl,imxrt1166-usb", "fsl,imx27-usb";
+				fsl,usbphy = <&usbphy2>;
+				status = "disabled";
 			usbotg1: usb at 40430000 {
 				reg = <0x40430000 0x4000>;
 				interrupts = <136>;
+				fsl,usbphy = <&usbphy1>;
 			usbphy1: usbphy at 40434000 {
 				reg = <0x40434000 0x4000>;
 				interrupts = <90>;
+				compatible = "fsl,imxrt1166-usbphy";
 			usbphy2: usbphy at 40438000 {
 				reg = <0x40438000 0x4000>;
 				interrupts = <91>;
 			caam: caam at 40440000 {
2.35.3
