[PATCH rtems v3 1/1] Add the Regulator Interface and test
Fri Aug 11 14:05:13 UTC 2023
Thanks. If you do turn up something once it is merged, there is always the
option to fix it. :)
Chris said I addressed his bigger concerns. Deletion and statistics.
On Fri, Aug 11, 2023 at 12:32 AM Sebastian Huber <
> On 11.08.23 00:14, Joel Sherrill wrote:
> > I should have asked if you want another round of patches or just go
> > ahead and merge. This set of changes was pretty minor.
> This is fine, I had only some cosmetic things.
> embedded brains GmbH
> Herr Sebastian HUBER
> Dornierstr. 4
> 82178 Puchheim
> Germany
> email: sebastian.huber at embedded-brains.de
> phone: +49-89-18 94 741 - 16
> fax:   +49-89-18 94 741 - 08
> Registergericht: Amtsgericht München
> Registernummer: HRB 157899
> Vertretungsberechtigte Geschäftsführer: Peter Rasmussen, Thomas Dörfler
> Unsere Datenschutzerklärung finden Sie hier:
> https://embedded-brains.de/datenschutzerklaerung/
URL: <http://lists.rtems.org/pipermail/devel/attachments/20230811/0fe8b048/attachment.htm>
