[PATCH] cpukit/score/aarch64: Use correct MAIR index
Kinsey Moore kinsey.moore at oarcorp.com
Sun Aug 13 22:18:08 UTC 2023
The MAIR index currently assigned (1) for uncached memory segments is
not configured properly for this purpose. Instead, this switches
uncached memory segment flags to MAIR index 2 which is properly
configured for uncached inner and outer shareable domains.
 cpukit/score/cpu/aarch64/include/libcpu/mmu-vmsav8-64.h | 4 ++--
 1 file changed, 2 insertions(+), 2 deletions(-)
diff --git a/cpukit/score/cpu/aarch64/include/libcpu/mmu-vmsav8-64.h b/cpukit/score/cpu/aarch64/include/libcpu/mmu-vmsav8-64.h
index 0d65004f88..ca9b60e6d1 100644
--- a/cpukit/score/cpu/aarch64/include/libcpu/mmu-vmsav8-64.h
+++ b/cpukit/score/cpu/aarch64/include/libcpu/mmu-vmsav8-64.h
@@ -70,7 +70,7 @@ extern "C" {
 #define AARCH64_MMU_CODE_RW_CACHED AARCH64_MMU_DATA_RW_CACHED
 #define AARCH64_MMU_DATA_RO \
-  ( AARCH64_MMU_FLAGS_BASE | MMU_DESC_MAIR_ATTR( 1 ) | MMU_DESC_WRITE_DISABLE )
+  ( AARCH64_MMU_FLAGS_BASE | MMU_DESC_MAIR_ATTR( 2 ) | MMU_DESC_WRITE_DISABLE )
 #define AARCH64_MMU_CODE AARCH64_MMU_DATA_RO
 #define AARCH64_MMU_CODE_RW AARCH64_MMU_DATA_RW
@@ -78,7 +78,7 @@ extern "C" {
 #define AARCH64_MMU_DATA_RW_CACHED \
   ( AARCH64_MMU_FLAGS_BASE | MMU_DESC_MAIR_ATTR( 3 ) )
 #define AARCH64_MMU_DATA_RW \
-  ( AARCH64_MMU_FLAGS_BASE | MMU_DESC_MAIR_ATTR( 1 ) )
+  ( AARCH64_MMU_FLAGS_BASE | MMU_DESC_MAIR_ATTR( 2 ) )
 #define AARCH64_MMU_DEVICE ( AARCH64_MMU_FLAGS_BASE | MMU_DESC_MAIR_ATTR( 0 ) )
 rtems_status_code aarch64_mmu_map(
2.39.2
