libdl support for base image TLS variables
Wed Aug 16 20:34:10 UTC 2023
On Mon, Aug 14, 2023 at 10:05 PM <chrisj at rtems.org> wrote:
> These patches add support to rtems.git and rtems-tools.git to
> provide access to TLS variables in the base from loaded code.
> The changes contain the ground work to resolving #4920 which is
> a blocker for the release of 6.
> This change is required due to the regression in libdl due to the
> change in newlib to use TLS variables for reneterant data.
> The rtems.git patch can be applied before the rtems-tools.git
> patch. If the tools are updated and the libdl code is not present
> the tests fail with linker errors. If the tools change is
> not present the test will link but it will continue to fail.
> The currently supported archs that build are:
>  - aarch64
>  - arm
>  - powerpc
>  - sparc
> The follow are to be completed and do not build:
>  - bfin
>  - i386
>  - lm32
>  - m68k
>  - mips
>  - moxie
>  - riscv
>  - v850
> We need to add support for these architectures if they support TLS.
We are deprecating v850. It might be worth considering whether some of
these other architectures should also be deprecated, especially if no
one is able/willing to add TLS for them.
> Chris
> devel mailing list
> devel at rtems.org
