[PATCH rtems-tools] tester/report: Apply test excludes to fatal-error
Kinsey Moore kinsey.moore at oarcorp.com
Fri Aug 18 13:51:57 UTC 2023
On Thu, Aug 17, 2023 at 7:25 PM Chris Johns <chrisj at rtems.org> wrote:
> On 17/8/2023 10:43 pm, Kinsey Moore wrote:
> > On Wed, Aug 16, 2023 at 9:47 PM Chris Johns <chrisj at rtems.org
> > <mailto:chrisj at rtems.org>> wrote:
> >     On 17/8/2023 7:36 am, Kinsey Moore wrote:
> >     > Before the fatal-error test result type was introduced,
> minimum.exe was
> >     > classified as an invalid test since it lacked a proper test header
> and
> >     > trailer. This applies the test exclusions to all test states to
> avoid
> >     > this happening again in the future.
> >     I do not think this right. What state are you seeing?
> > The minimum test fails with a fatal error:
> >     "*** FATAL ***",
> >     "fatal source: 0 (INTERNAL_ERROR_CORE)",
> >     "fatal code: 5 (INTERNAL_ERROR_THREAD_EXITTED)",
> >     "RTEMS version: 6.0.0.c76c98c344d803fa80361884c4cc79f0b3607ec8",
> >     "RTEMS tools: 12.3.1 20230626 (RTEMS 6, RSB
> > 8e568b2ca3489d6bfa48e1d29618ea9b48a5b408, Newlib 4c7d0df)",
> >     "executing thread ID: 0x09010001",
> > As far as I'm aware, this is a normal exit for minimum since it does
> nothing
> > which includes not properly exiting the test by allowing Init() to
> return.
> >     While we cannot determine the pass state because there is no end
> message we can
> >     determine if the test has timed out or is too long and they should
> be a fail.
> > This is not timing out or taking too long as per the above. I could move
> the
> > check to cover just the invalid/fatal-error checks instead of all of
> them if you
> > prefer.
> This looks to me like an issue in minimum and it looks to me like minimal
> has
> some other issue. What is printing out the message? If there is code in
> minimal
> to print this error then why not print a normal test start and end banner?
> My understanding is minimal has not means to output anything.
It seems to be intentional:
static void *Init( uintptr_t ignored )
  /* initialize application */
  /* Real application would call idle loop functionality */
  /* but in this case, just return and fall into a fatal error */
  return NULL;
Even if no console is requested (not even simple console), BSP_output_char
is still available.
Kinsey
URL: <http://lists.rtems.org/pipermail/devel/attachments/20230818/9449b716/attachment.htm>
