[RSB PATCH] rtems/tools: Pick up the rtems-syms and rtems-test sis changes
chrisj at rtems.org chrisj at rtems.org
Mon Aug 21 02:49:39 UTC 2023
Updates #4920
 rtems/config/tools/rtems-tools-6.cfg | 4 ++--
 1 file changed, 2 insertions(+), 2 deletions(-)
diff --git a/rtems/config/tools/rtems-tools-6.cfg b/rtems/config/tools/rtems-tools-6.cfg
index b786a47..6eed755 100644
--- a/rtems/config/tools/rtems-tools-6.cfg
+++ b/rtems/config/tools/rtems-tools-6.cfg
@@ -10,14 +10,14 @@
  %define rtems_tools_source rtems-tools-%{rtems_tools_version}
  %define rtems_tools_ext xz
 %else
- %define rtems_tools_version eaf14a654b528b44de14f9da9919555e54324e0d
+ %define rtems_tools_version 349bbd96543365e830e5ef5e851765e4b742a8a4
  %define rtems_tools_ext bz2
 %endif
 %source set rtems-tools https://git.rtems.org/rtems-tools/snapshot/%{rtems_tools_source}.tar.%{rtems_tools_ext}
 %hash   sha512 rtems-tools-%{rtems_tools_version}.tar.bz2 \
-       bcjVLITKdjQLKlalfUptMKLAmvDT0FidARukQHP4rK/8SWpYckPAc8BMMRhS3RX+Ga6NDuxD1Ss/bRlxG6qsdg==
+       qb5EC4gWfahYLPliYk+mNRsgzaDuouqiRq6GURb8v0Pk4J6Uo6IiKrB6dPvqVPO+wh9Omb1xCs+86W/+fj8sZg==
 # Optionally enable/disable building the RTEMS Tools via the command line.
2.37.1
