(libdl) Fwd: New Defects reported by Coverity Scan for RTEMS
Tue Aug 22 00:02:24 UTC 2023
flag it as a false positive.
g7 is a global register that is reserved for system / compiler use in
the sparc ABI
On Mon, Aug 21, 2023 at 2:17 PM Joel Sherrill <joel at rtems.org> wrote:
> Moving it back to devel at .
> It appears to be from this bit of magic in the same file which implements it using a direct reference to register g7.
> #elif defined(__sparc__)
> #include <stdint.h>
> # define __get_tls() ({ void** __val; register uintptr_t g7 __asm__( "g7" ); __val = (void**) g7; __val; })
> I honestly don't know how to tell Coverity or GCC that this is reading a register we trust.
> On Mon, Aug 21, 2023 at 2:58 PM Chris Johns <chrisj at rtems.org> wrote:
>> Hi
>> It is code from somewhere else so sorry I have no idea.
>> Chris
>> On 21 Aug 2023, at 11:33 pm, Joel Sherrill <joel at rtems.org> wrote:
>> Unitialized variable issue from Coverity in libdl
>> ---------- Forwarded message ---------
>> From: <scan-admin at coverity.com>
>> Date: Mon, Aug 21, 2023 at 12:33 AM
>> Subject: New Defects reported by Coverity Scan for RTEMS
>> To: <build at rtems.org>
>> Hi,
>> Please find the latest report on new defect(s) introduced to RTEMS found with Coverity Scan.
>> 1 new defect(s) introduced to RTEMS found with Coverity Scan.
>> New defect(s) Reported-by: Coverity Scan
>> Showing 1 of 1 defect(s)
>> ** CID 1541150:  Memory - illegal accesses  (UNINIT)
>> /cpukit/libdl/rtl-tls.c: 111 in rtems_rtl_tls_get_base()
>> ________________________________________________________________________________________________________
>> *** CID 1541150:  Memory - illegal accesses  (UNINIT)
>> 105     #endif
>> 106
>> 107     #if defined(__get_tls)
>> 108
>> 109     void* rtems_rtl_tls_get_base (void)
>> 110     {
>> >>>     Using uninitialized value "g7".
>> 111       return (void*) __get_tls();
>> 112     }
>> 113
>> To view the defects in Coverity Scan visit, https://u15810271.ct.sendgrid.net/ls/click?upn=HRESupC-2F2Czv4BOaCWWCy7my0P0qcxCbhZ31OYv50ypUUzi-2FdSNmuyRB7BEFT8xQ4-2B8hpujh0hTgQljRGId4Dg-3D-3Deeiw_EU3W9teASMK00lBXX9WT4lsogDrkCcNZLvg-2FVxwAXMqJ0gdhGGumG7Gy0Tn5Dw3PQUbh2-2BNMdpxfdtJmNYuHO3QG97iSLio7uY7m4yyhwWxZmfc2p4Yk5m-2B2JQ7-2FNr1n2P8EvOyfDnsHe5-2FCDlZpmVnHhGqVY9mLjZbQG-2FJIE3w3MlGbiKwQw8j63a169WP32Wpts1j8m1uekKxkyIv1KA-3D-3D
>> build mailing list
>> build at rtems.org
>> http://lists.rtems.org/mailman/listinfo/build
> devel mailing list
> devel at rtems.org
