[PATCH 1/2] cpukit/libdl: Correctly account for section alignments
chrisj at rtems.org chrisj at rtems.org
Mon Aug 28 04:04:20 UTC 2023
- Add the section alignment to the size as the allocator may not
  provide correctly aligned memory
- Only include symbols in the section when locating symbols. The
  powerpc was incorrectly adding SDATA BSS symbols to the BSS offset
  overrunning the section
Closes #4950
 cpukit/libdl/rtl-obj.c             | 31 ++++++++++++------------------
 testsuites/libtests/dl07/dl-load.c |  1 +
 2 files changed, 13 insertions(+), 19 deletions(-)
diff --git a/cpukit/libdl/rtl-obj.c b/cpukit/libdl/rtl-obj.c
index a35fbf9e8d..c99e9f703f 100644
--- a/cpukit/libdl/rtl-obj.c
+++ b/cpukit/libdl/rtl-obj.c
@@ -1032,6 +1032,7 @@ rtems_rtl_obj_sections_locate (uint32_t            mask,
           base_offset = rtems_rtl_obj_align (base_offset, sect->alignment);
           sect->base = base + base_offset;
+          base_offset += sect->size;
         if (rtems_rtl_trace (RTEMS_RTL_TRACE_LOAD_SECT))
@@ -1040,9 +1041,6 @@ rtems_rtl_obj_sections_locate (uint32_t            mask,
                   order, sect->name, sect->base, sect->size,
                   sect->flags, sect->alignment, sect->link);
-        if (sect->base)
-          base_offset += sect->size;
         ++order;
         node = rtems_chain_first (sections);
@@ -1064,23 +1062,18 @@ rtems_rtl_obj_set_sizes (rtems_rtl_obj* obj)
   size_t data_size;
   size_t bss_size;
-  text_size  = rtems_rtl_obj_text_size (obj);
+   * The allocator may not align memory to the required boundary. Add
+   * the alignment size to the size allocated.
+  text_size  = rtems_rtl_obj_text_size (obj) + rtems_rtl_obj_text_alignment (obj);
   tramp_size = rtems_rtl_obj_tramp_size (obj);
   if (tramp_size != 0)
-    text_size += rtems_rtl_obj_tramp_alignment (obj);
-    tramp_size += rtems_rtl_obj_const_alignment (obj);
-  else
-    text_size += rtems_rtl_obj_const_alignment (obj);
-  const_size = rtems_rtl_obj_const_size (obj) + rtems_rtl_obj_eh_alignment (obj);
-  eh_size    = rtems_rtl_obj_eh_size (obj) + rtems_rtl_obj_data_alignment (obj);
-  data_size  = rtems_rtl_obj_data_size (obj) + rtems_rtl_obj_bss_alignment (obj);
-  bss_size   = rtems_rtl_obj_bss_size (obj);
+    tramp_size += rtems_rtl_obj_tramp_alignment (obj);
+  const_size = rtems_rtl_obj_const_size (obj) + rtems_rtl_obj_const_alignment (obj);
+  eh_size    = rtems_rtl_obj_eh_size (obj) + rtems_rtl_obj_eh_alignment (obj);
+  data_size  = rtems_rtl_obj_data_size (obj) + rtems_rtl_obj_data_alignment (obj);
+  bss_size   = rtems_rtl_obj_bss_size (obj) + rtems_rtl_obj_bss_alignment (obj);
    * Set the sizes held in the object data. We need this for a fast reference.
@@ -1098,7 +1091,7 @@ rtems_rtl_obj_set_sizes (rtems_rtl_obj* obj)
 static void
 rtems_rtl_obj_print_sizes (rtems_rtl_obj* obj, const char* label)
-if (rtems_rtl_trace (RTEMS_RTL_TRACE_LOAD_SECT))
+  if (rtems_rtl_trace (RTEMS_RTL_TRACE_LOAD_SECT))
     printf ("rtl: %s sect: text  - b:%p s:%zi a:%" PRIu32 "\n",
             label, obj->text_base, obj->text_size, rtems_rtl_obj_text_alignment (obj));
diff --git a/testsuites/libtests/dl07/dl-load.c b/testsuites/libtests/dl07/dl-load.c
index 58e3e06f78..2946120ca6 100644
--- a/testsuites/libtests/dl07/dl-load.c
+++ b/testsuites/libtests/dl07/dl-load.c
@@ -32,6 +32,7 @@
                       RTEMS_RTL_TRACE_WARNING | \
                       RTEMS_RTL_TRACE_LOAD | \
                       RTEMS_RTL_TRACE_UNLOAD | \
+                      RTEMS_RTL_TRACE_LOAD_SECT | \
                       RTEMS_RTL_TRACE_SYMBOL | \
                       RTEMS_RTL_TRACE_RELOC | \
                       RTEMS_RTL_TRACE_ALLOCATOR | \
2.37.1
