[PATCH 2/5] testsuites/libtests: Remove floats from libdl tests
Alex White alex.white at oarcorp.com
Mon Aug 28 04:12:30 UTC 2023
On Sun, Aug 27, 2023 at 8:38 PM Chris Johns <chrisj at rtems.org> wrote:
> The floats need to stay to make sure there are no issues with this type. I see
> the tests with floats as valid.
> Is the only missing function `__extendsfdf2`?
Yes, that is the only missing function. If I change the floats to doubles, the
need for `__extendsfdf2` goes away and the tests pass. Is that an acceptable
solution?
Alex
