[rtems-tools PATCH] rtemstoolkit: Fix shell execution
Tue Aug 29 19:44:19 UTC 2023
A bit more feedback. I got this failure on CentOS 7 building sparc-rtems6
tools.
+ cd rtems-tools-3ea0c249346fda427bf0d3c169aa3e7c2a521df8
+ ./waf distclean configure --prefix=/home/joel/rtems-work/tools/6
'distclean' finished successfully (0.001s)
Setting top to                           :
/home/joel/rtems-work/rtems-source-builder/rtems/build/rtems-tools-3ea0c249346fda427bf0d3c169aa3e7c2a521df8-1/rtems-tools-3ea0c249346fda427bf0d3c169aa3e7c2a521df8
Setting out to                           :
/home/joel/rtems-work/rtems-source-builder/rtems/build/rtems-tools-3ea0c249346fda427bf0d3c169aa3e7c2a521df8-1/rtems-tools-3ea0c249346fda427bf0d3c169aa3e7c2a521df8/build
invalid version file: 'module' object has no attribute 'join'
(complete log in
/home/joel/rtems-work/rtems-source-builder/rtems/build/rtems-tools-3ea0c249346fda427bf0d3c169aa3e7c2a521df8-1/rtems-tools-3ea0c249346fda427bf0d3c169aa3e7c2a521df8/build/config.log)
shell cmd failed: /bin/sh -ex
 /home/joel/rtems-work/rtems-source-builder/rtems/build/rtems-tools-3ea0c249346fda427bf0d3c169aa3e7c2a521df8-1/do-build
error: building rtems-tools-3ea0c249346fda427bf0d3c169aa3e7c2a521df8-1
I tried the same target on Rocky 9 and did not get this error.
I loaded the software collection for Python 3.6 on CentOS 7 and got this:
Setting top to                           :
Setting out to                           :
invalid version file: module 'shlex' has no attribute 'join'
Not sure what the common factor on all this is.
--joel
On Tue, Aug 29, 2023 at 8:23 AM Joel Sherrill <joel at rtems.org> wrote:
> On Tue, Aug 29, 2023 at 5:48 AM Frank Kühndel <
> frank.kuehndel at embedded-brains.de> wrote:
>> Hello Chris,
>> On 8/29/23 12:45, Chris Johns wrote:
>> >> On 29 Aug 2023, at 6:24 pm, Frank Kühndel<
>> >> Hello Chris,
>> >> our continuous integration server found an issues with this patch
>> >> ("module 'shlex' has no attribute 'join'"):
>> > Frank, thanks for the post and the insight. I saw the build break in
>> Joel’s build but I could not see the reason. This will help.
>> > I will look into this tomorrow. Sorry for the breakage.
>> No problem at all. I am happy I could help.
> FYI I see some overnight CentOS 7 failures for rtems6 tools also. This
> looks like the same issue:
> https://lists.rtems.org/pipermail/build/2023-August/048307.html
> --joel
>> Have a good night
>> Frank
>> embedded brains GmbH & Co. KG
>> Herr Frank KÜHNDEL
>> Dornierstr. 4
>> 82178 Puchheim
>> Germany
>> email: frank.kuehndel at embedded-brains.de
>> phone:  +49-89-18 94 741 - 23
>> mobile: +49-176-15 22 06 - 11
>> Registergericht: Amtsgericht München
>> Registernummer: HRA 117265
>> Vertretungsberechtigte Geschäftsführer: Peter Rasmussen, Thomas Dörfler
>> Unsere Datenschutzerklärung finden Sie hier:
>> https://embedded-brains.de/datenschutzerklaerung/
>> devel mailing list
>> devel at rtems.org
URL: <http://lists.rtems.org/pipermail/devel/attachments/20230829/857de018/attachment.htm>
