[RSB PATCH] rtems/tools: Execute use of shlex.join fix for python < 3.8
chrisj at rtems.org chrisj at rtems.org
Wed Aug 30 23:28:36 UTC 2023
Updates #4951
 rtems/config/tools/rtems-tools-6.cfg | 4 ++--
 1 file changed, 2 insertions(+), 2 deletions(-)
diff --git a/rtems/config/tools/rtems-tools-6.cfg b/rtems/config/tools/rtems-tools-6.cfg
index b360f7e..9632d5b 100644
--- a/rtems/config/tools/rtems-tools-6.cfg
+++ b/rtems/config/tools/rtems-tools-6.cfg
@@ -10,14 +10,14 @@
  %define rtems_tools_source rtems-tools-%{rtems_tools_version}
  %define rtems_tools_ext xz
 %else
- %define rtems_tools_version 3ea0c249346fda427bf0d3c169aa3e7c2a521df8
+ %define rtems_tools_version eda9325e583f761c53ee3db83124cc77cb4fefb5
  %define rtems_tools_ext bz2
 %endif
 %source set rtems-tools https://git.rtems.org/rtems-tools/snapshot/%{rtems_tools_source}.tar.%{rtems_tools_ext}
 %hash   sha512 rtems-tools-%{rtems_tools_version}.tar.bz2 \
-       +wrMxGHJp5cd/hpgoGwTH65IvwZQsAWOb8JNmDZKdFqUbhUuUYq1zK1p5NJnvCUkHudxgDmghAe/5kaFE5DJ4w==
+       kdrwOv0iUKYjWud2g/9aSnduIniNWnQKry04zwKEiwlKdg1KnMhGu4b0mpQD2PnsYxGha/ksPEnHLPnahQTarg==
 # Optionally enable/disable building the RTEMS Tools via the command line.
2.37.1
