[rtems-tools]rtems-ld issue?
Thu Aug 31 04:00:35 UTC 2023
On 31/8/2023 1:51 pm, zhengxiaojun wrote:
> 在 2023/8/31 6:05, Chris Johns 写道:
>> On 31/8/2023 12:48 am, zhengxiaojun wrote:
>>> Hi,
>>>     I use the latest rtems-tools to generate RAP file, I found the object file
>>> become too small(elf,2184bytes==>rap,736bytes) and the file loaded failed, error
>>> message like this "load app.out error:offset past end of file: offset=736
>>> size=736 error."
>> What arch and BSP?
> ARM, imx6ull
>>>     I reverted the rtl-rap.cpp commit( 0ad4aaafc20afcb5aacb7a82b0b3a8150b638975
>>> linker/rap: Ignore relocation records with no section), the rap file can be
>>> loaded.
>> I think the commit has the wrong ticket id, it should be 4069 ...
>> https://devel.rtems.org/ticket/4069
>> My guess is the length includes the relocs that have been dropped because they
>> do not have a symbol section. A reloc without a symbol section cannot be located
>> because you do not know the section to locate it against.
>> Are you able to review the rtems-ld code for the issue?
> I am trying to find something, but I do not know elf/rap format well. I found
> when ignore synsect==0, the GLOBAL symbol will be ignore too.
> Should the GLOBAL symbol be dealt with?
> Here is part of ELF:
> Symbol table (.symtab)
> [  Nr ] Value    Size     Type    Bind      Sect Name
> [    0] 00000000 00000000 NOTYPE  LOCAL        0
> [    1] 00000000 00000000 NOTYPE  LOCAL        4 $d
> [    2] 00000001 0000011e FUNC    LOCAL        1 task_test
> [    3] 00000000 00000000 NOTYPE  LOCAL        1 $t
> [    4] 00000000 00000000 NOTYPE  LOCAL        3 $d
> [    5] 00000000 00000000 NOTYPE  LOCAL        4 .LC0
> [    6] 00000030 00000000 NOTYPE  LOCAL        4 .LC3
> [    7] 00000000 00000000 NOTYPE  LOCAL        3 .LANCHOR0
> [    8] 0000000c 00000000 NOTYPE  LOCAL        4 .LC1
> [    9] 00000038 00000000 NOTYPE  LOCAL        4 .LC4
> [   10] 00000000 00000000 NOTYPE  GLOBAL       0 putchar
> [   11] 00000000 00000000 NOTYPE  GLOBAL       0 printf
> [   12] 00000000 00000000 NOTYPE  GLOBAL       0 rtems_task_wake_after
> [   13] 00000000 00000000 NOTYPE  GLOBAL       0 puts
> [   14] 00000000 00000000 NOTYPE  GLOBAL       0 tcflush
> [   15] 00000121 00000054 FUNC    GLOBAL       1 appmain
> [   16] 00000000 00000000 NOTYPE  GLOBAL       0 rtems_task_start
> [   17] 00000000 00000000 NOTYPE  GLOBAL       0 cfsetispeed
> [   18] 00000000 00000000 NOTYPE  GLOBAL       0 write
> [   19] 00000000 00000000 NOTYPE  GLOBAL       0 cfsetospeed
> [   20] 00000000 00000000 NOTYPE  GLOBAL       0 read
> [   21] 00000000 00000000 NOTYPE  GLOBAL       0 tcgetattr
> [   22] 00000000 00000000 NOTYPE  GLOBAL       0 open
> [   23] 00000000 00000000 NOTYPE  GLOBAL       0 tcsetattr
> [   24] 00000000 00000000 NOTYPE  GLOBAL       0 rtems_task_create
Looking at this the change does not seem right. I cannot remember why it was
added. It may require building the supported archs without the patch to see what
happens, specifically RISCV.
