Xilinx MPSoC, CAN, CAN-FD
emanuel stiebler emu at e-bbes.com
Sun Dec 3 17:54:41 UTC 2023
On 2023-09-19 09:36, Kinsey Moore wrote:
> On Tue, Sep 19, 2023 at 7:25 AM emanuel stiebler <emu at e-bbes.com
> <mailto:emu at e-bbes.com>> wrote:
>     Anybody using CAN on the xilinx MPSoC? Does CON-FD work too?
> Hi Emanuel,
> Those drivers haven't been ported in from the embeddedsw repository yet
> since I haven't had a need for them. If you want to try porting them
> into RTEMS, the framework for them is already in place and used by the
> QSPI and static memory controller (NAND) drivers so it shouldn't be all
> that complicated. If you decide you want to attempt this, please also be
> aware of the recent HAL discussion on this list.
Just checked again in the DataSheet of the Xilinx MPSoC, and it doesn't
support CAN FD (Flexible DataRate) , only CAN :(
