[PATCH rtems-lwip] xemacps: Improve pbuf handling
Kinsey Moore kinsey.moore at oarcorp.com
Sat Dec 9 02:48:05 UTC 2023
This fixes two related issues:
* Pbufs in the RX list weren't cleared out appropriately and this could
  cause multiple frees along with premature pbuf/memp reuse in
  circumstances where the system was running out of pbufs and receive
  overruns were occurring.
* This patch adds locking around pbuf list manipulation to prevent race
  conditions where the list might be in an inconsistent state.
 .../ports/xilinx/netif/xemacpsif_dma.c        | 74 +++++++++++++++++++
 1 file changed, 74 insertions(+)
diff --git a/embeddedsw/ThirdParty/sw_services/lwip211/src/contrib/ports/xilinx/netif/xemacpsif_dma.c b/embeddedsw/ThirdParty/sw_services/lwip211/src/contrib/ports/xilinx/netif/xemacpsif_dma.c
index 2da3566..1d2439a 100644
--- a/embeddedsw/ThirdParty/sw_services/lwip211/src/contrib/ports/xilinx/netif/xemacpsif_dma.c
+++ b/embeddedsw/ThirdParty/sw_services/lwip211/src/contrib/ports/xilinx/netif/xemacpsif_dma.c
@@ -264,6 +264,10 @@ void process_sent_bds(xemacpsif_s *xemacpsif, XEmacPs_BdRing *txring)
 				*temp = 0x80000000;
 			dsb();
+#ifdef __rtems__
+			SYS_ARCH_DECL_PROTECT(lev);
+			SYS_ARCH_PROTECT(lev);
+#endif
 			p = (struct pbuf *)tx_pbufs_storage[index + bdindex];
 			if (p != NULL) {
 				pbuf_free(p);
@@ -272,6 +276,9 @@ void process_sent_bds(xemacpsif_s *xemacpsif, XEmacPs_BdRing *txring)
 			notifyinfo[tx_task_notifier_index + bdindex] = 0;
 #endif
 			tx_pbufs_storage[index + bdindex] = 0;
+#ifdef __rtems__
+			SYS_ARCH_UNPROTECT(lev);
+#endif
 			curbdpntr = XEmacPs_BdRingNext(txring, curbdpntr);
 			n_pbufs_freed--;
 			dsb();
@@ -346,8 +353,15 @@ XStatus emacps_sgsend(xemacpsif_s *xemacpsif, struct pbuf *p)
 	for(q = p, txbd = txbdset; q != NULL; q = q->next) {
 		bdindex = XEMACPS_BD_TO_INDEX(txring, txbd);
+#ifdef __rtems__
+#endif
 		if (tx_pbufs_storage[index + bdindex] != 0) {
 			LWIP_DEBUGF(NETIF_DEBUG, ("PBUFS not available\r\n"));
+#ifdef __rtems__
+#endif
 			return XST_FAILURE;
@@ -373,6 +387,9 @@ XStatus emacps_sgsend(xemacpsif_s *xemacpsif, struct pbuf *p)
 		tx_pbufs_storage[index + bdindex] = (UINTPTR)q;
 		pbuf_ref(q);
+#ifdef __rtems__
+#endif
 		last_txbd = txbd;
 		XEmacPs_BdClearLast(txbd);
 		txbd = XEmacPs_BdRingNext(txring, txbd);
@@ -488,7 +505,14 @@ void setup_rx_bds(xemacpsif_s *xemacpsif, XEmacPs_BdRing *rxring)
 			XEmacPs_BdWrite(rxbd, XEMACPS_BD_ADDR_OFFSET, (UINTPTR)p->payload);
+#ifdef __rtems__
+#endif
 		rx_pbufs_storage[index + bdindex] = (UINTPTR)p;
+#ifdef __rtems__
+#endif
@@ -536,8 +560,26 @@ void emacps_recv_handler(void *arg)
 		for (k = 0, curbdptr=rxbdset; k < bd_processed; k++) {
 			bdindex = XEMACPS_BD_TO_INDEX(rxring, curbdptr);
+#ifdef __rtems__
+#endif
 			p = (struct pbuf *)rx_pbufs_storage[index + bdindex];
+#ifdef __rtems__
+			/* Clear this since ownership is being passed elsewhere */
+			rx_pbufs_storage[index + bdindex] = 0;
+			 * Nulled descriptors are left flagged so the hardware
+			 * doesn't try to use them. They will still show up here.
+			if (p == NULL) {
+				continue;
+#endif
 			 * Adjust the buffer size to the actual number of bytes received.
@@ -768,7 +810,14 @@ XStatus init_dma(struct xemac_s *xemac)
 #endif
 		XEmacPs_BdSetAddressRx(rxbd, (UINTPTR)p->payload);
+#ifdef __rtems__
+#endif
+#ifdef __rtems__
+#endif
 	XEmacPs_SetQueuePtr(&(xemacpsif->emacps), xemacpsif->emacps.RxBdRing.BaseBdAddr, 0, XEMACPS_RECV);
 	if (gigeversion > 2) {
@@ -865,16 +914,34 @@ void free_txrx_pbufs(xemacpsif_s *xemacpsif)
 	index1 = get_base_index_txpbufsstorage (xemacpsif);
 	for (index = index1; index < (index1 + XLWIP_CONFIG_N_TX_DESC); index++) {
+#ifdef __rtems__
+#endif
 		if (tx_pbufs_storage[index] != 0) {
 			p = (struct pbuf *)tx_pbufs_storage[index];
 			pbuf_free(p);
 			tx_pbufs_storage[index] = 0;
+#ifdef __rtems__
+#endif
 	index1 = get_base_index_rxpbufsstorage(xemacpsif);
 	for (index = index1; index < (index1 + XLWIP_CONFIG_N_RX_DESC); index++) {
+#ifdef __rtems__
+#endif
 		p = (struct pbuf *)rx_pbufs_storage[index];
+#ifdef __rtems__
+		rx_pbufs_storage[index] = 0;
+		if (p == NULL) {
+			continue;
+#endif
 		pbuf_free(p);
@@ -888,11 +955,18 @@ void free_onlytx_pbufs(xemacpsif_s *xemacpsif)
+#ifdef __rtems__
+#endif
 			pbuf_free(p);
+#ifdef __rtems__
+#endif
2.39.2
