[PATCH] libmisc/shell: Work around tmux bug in row and column
Wed Dec 13 06:42:53 UTC 2023
On 13.12.23 03:47, chrisj at rtems.org wrote:
> +        const int timeout = 150;
> +        bool row_cols_swapped = false;
>           memset(&buf[0], 0, sizeof(buf));
> +         *https://github.com/tmux/tmux/issues/3457
> +         * Tmux has a bug where the lines and cols are swapped. There is a lag
> +         * in the time it takes to get the fix into code so see if tmux is
> +         * running and which version and work around the bug.
> +         * CSI > Ps q
> +         *    Ps = 0   =>   DCS > | text ST
> +        fputs("\033[>0q", stdout);
> +        fflush(stdout);
> +        if (rtems_shell_term_wait_for(fd, "\033P>|", timeout)) {
> +          int len = rtems_shell_term_buffer_until(fd, buf, sizeof(buf), "\033\\", timeout);
> +          if (len > 0) {
> +            if (memcmp(buf, "tmux ", 5) == 0) {
> +              static const char* bad_versions[] = {
> +                "3.2", "3.2a", "3.3", "3.3a"
> +              #define bad_versions_num (sizeof(bad_versions) / sizeof(bad_versions[0]))
> +              size_t i;
> +              for (i = 0; i < bad_versions_num; ++i) {
> +                if (strcmp(bad_versions[i], buf + 5) == 0) {
> +                  row_cols_swapped = true;
> +                  break;
I think the above new code block could be moved to a helper function
which returns the value of row_cols_swapped.
embedded brains GmbH & Co. KG
Herr Sebastian HUBER
Dornierstr. 4
82178 Puchheim
Germany
phone: +49-89-18 94 741 - 16
fax:   +49-89-18 94 741 - 08
Registernummer: HRB 157899
