[PATCH 2/9] cpukit/jffs2: Protect the inode cache
Wed Dec 13 14:35:28 UTC 2023
On 13.12.23 15:27, Kinsey Moore wrote:
> On Wed, Dec 13, 2023 at 12:26 AM Sebastian Huber
> <sebastian.huber at embedded-brains.de
> <mailto:sebastian.huber at embedded-brains.de>> wrote:
>     On 09.12.23 03:31, Kinsey Moore wrote:
>      > The inode cache can be altered and queried by multiple threads of
>      > execution, even before the introduction of delayed write support for
>      > NAND. This provides a new lock to prevent simultaneous
>     modification of
>      > the cache.
>     Under which condition is the inode cache accessed without the file
>     system instance lock for normal operations (no delayed works stuff)?
>     Your new code still has no test cases and the configuration option is
>     not documented (http://devel.rtems.org/ticket/4961
>     <http://devel.rtems.org/ticket/4961>).
>     I am still in favour of an alternative locking approach:
>     1. The delayed work support uses a mutex D and a condition variable C
>     used with D.
>     2. Add a queue for the delayed work to the fs information and a node to
>     register the info in the delayed work support.
>     3. The first delayed work request of a JFFS2 instance registers the fs
>     information in the delayed work support and uses C to signal the
>     work to
>     the delayed work task.
>     4. Further requests just get enqueued and signaled using D and C.
>     5. When a instance is unmounted, drain the delayed work queue using
>     D and C.
>     The delayed work uses the fs info mutex to protect the work. You need
>     also reference count for the fs info to control the work and the drain
>     during unmount.
> Using the FS information lock at the level of delayed work callback
> isn't workable with the current API exposed/consumed by the JFFS2
> library as this information is not exposed to the thread calling the
> delayed work without modification of the JFFS2 library itself or abusing
> macros to pull in information that isn't actually provided to them (and
> would require that local variable naming be extremely consistent across
> usages of this abusive macro).All that is available is the callback
> function pointer and an opaque void pointer argument.
I don't understand the problem. If you need JFFS2 specific details, why
don't you implement this part to the JFFS2 area?
> Other
> implementations that use this library achieve safe locking without the
> FS information lock.
What is "this library"?
Before you started with adding some locks here and some locks there, the
complete JFFS2 state was protected by a single instance lock. This is
not great in terms of SMP performance, however, it is very simple and it
works. I don't know why you can't get the instance lock, do the delayed
work, and then release the instance lock.
embedded brains GmbH & Co. KG
Herr Sebastian HUBER
Dornierstr. 4
82178 Puchheim
Germany
phone: +49-89-18 94 741 - 16
fax:   +49-89-18 94 741 - 08
Registernummer: HRB 157899
