[PATCH 2/9] cpukit/jffs2: Protect the inode cache
Kinsey Moore kinsey.moore at oarcorp.com
Wed Dec 13 20:29:31 UTC 2023
On Wed, Dec 13, 2023 at 1:32 PM Sebastian Huber <
> On 13.12.23 19:41, Kinsey Moore wrote:
> > On Wed, Dec 13, 2023 at 8:35 AM Sebastian Huber
> > <sebastian.huber at embedded-brains.de
> > <mailto:sebastian.huber at embedded-brains.de>> wrote:
> >     On 13.12.23 15:27, Kinsey Moore wrote:
> >      > On Wed, Dec 13, 2023 at 12:26 AM Sebastian Huber
> >     <mailto:sebastian.huber at embedded-brains.de>>> wrote:
> >      >     On 09.12.23 03:31, Kinsey Moore wrote:
> >      >      > The inode cache can be altered and queried by multiple
> >     threads of
> >      >      > execution, even before the introduction of delayed write
> >     support for
> >      >      > NAND. This provides a new lock to prevent simultaneous
> >      >     modification of
> >      >      > the cache.
> >      >     Under which condition is the inode cache accessed without the
> >     file
> >      >     system instance lock for normal operations (no delayed works
> >     stuff)?
> >      >     Your new code still has no test cases and the configuration
> >     option is
> >      >     not documented (http://devel.rtems.org/ticket/4961
> >     <http://devel.rtems.org/ticket/4961>
> >     <http://devel.rtems.org/ticket/4961>>).
> >      >     I am still in favour of an alternative locking approach:
> >      >     1. The delayed work support uses a mutex D and a condition
> >     variable C
> >      >     used with D.
> >      >     2. Add a queue for the delayed work to the fs information and
> >     a node to
> >      >     register the info in the delayed work support.
> >      >     3. The first delayed work request of a JFFS2 instance
> >     registers the fs
> >      >     information in the delayed work support and uses C to signal
> the
> >      >     work to
> >      >     the delayed work task.
> >      >     4. Further requests just get enqueued and signaled using D
> and C.
> >      >     5. When a instance is unmounted, drain the delayed work queue
> >     using
> >      >     D and C.
> >      >     The delayed work uses the fs info mutex to protect the work.
> >     You need
> >      >     also reference count for the fs info to control the work and
> >     the drain
> >      >     during unmount.
> >      > Using the FS information lock at the level of delayed work
> callback
> >      > isn't workable with the current API exposed/consumed by the JFFS2
> >      > library as this information is not exposed to the thread calling
> the
> >      > delayed work without modification of the JFFS2 library itself or
> >     abusing
> >      > macros to pull in information that isn't actually provided to
> >     them (and
> >      > would require that local variable naming be extremely consistent
> >     across
> >      > usages of this abusive macro).All that is available is the
> callback
> >      > function pointer and an opaque void pointer argument.
> >     I don't understand the problem. If you need JFFS2 specific details,
> why
> >     don't you implement this part to the JFFS2 area?
> > I could, but I prefer to minimize changes to external code where
> > possible. It's not strictly necessary in this case, so I'm avoiding it.
> >      > Other
> >      > implementations that use this library achieve safe locking
> >     without the
> >      > FS information lock.
> >     What is "this library"?
> > The JFFS2 library.
> >     Before you started with adding some locks here and some locks there,
> >     the
> >     complete JFFS2 state was protected by a single instance lock. This is
> >     not great in terms of SMP performance, however, it is very simple
> >     and it
> >     works. I don't know why you can't get the instance lock, do the
> delayed
> >     work, and then release the instance lock.
> > The lock is not available to the delayed work caller without modifying
> > the JFFS2 code and, while I'm sure it would work fine from a data
> > integrity perspective, it was not intended to operate that way. If I
> > were going to go this direction to reduce complexity, it might make more
> > sense to disable delayed write support and force all writes to be
> > immediate such that it behaves like NOR. The downside to reduced locking
> > granularity or delayed write removal would be additional wear on the
> > NAND flash.
> In which place in the code do you have problems to get the fs info
> block? I am absolutely not in favour of having the internal locking
> enabled for JFFS2. We use this file system on lower end controllers.
> The call to submit delayed work does not provide the FS info as a
parameter:
void jffs2_queue_delayed_work(struct delayed_work *work, int delay_ms);
This is wrapped as:
#define queue_delayed_work(workqueue, delayed_work, delay_ms) ...
The initialization call for delayed work does not have direct access to the
FS info, either:
#define INIT_DELAYED_WORK(delayed_work, delayed_workqueue_callback) ...
> Independent of this, for NAND I would use YAFFS2.
Unfortunately, YAFFS2 is licensed GPL2 and not suitable for inclusion in an
RTEMS application without commercial licensing, dynamic loading via libdl,
or writing an implementation of that file system from scratch. I would
agree that JFFS2 isn't ideal for modern NAND given the 4GB file system
limit.
Kinsey
URL: <http://lists.rtems.org/pipermail/devel/attachments/20231213/fae987e4/attachment.htm>
