[PATCH 1/2] libtest: Set test printer in rtems_test_run()
Wed Dec 13 20:37:31 UTC 2023
OK to both, thanks
On 14/12/2023 3:30 am, Sebastian Huber wrote:
> Route the test output through T_vprintf().
>  cpukit/libtest/testrun.c | 14 +++++++++++---
>  1 file changed, 11 insertions(+), 3 deletions(-)
> diff --git a/cpukit/libtest/testrun.c b/cpukit/libtest/testrun.c
> index 0d392e4581..1fc8c82824 100644
> --- a/cpukit/libtest/testrun.c
> +++ b/cpukit/libtest/testrun.c
> @@ -3,13 +3,13 @@
>   * @file
> - * @ingroup RTEMSAPI
> + * @ingroup RTEMSTest
> - * @brief Implementation of rtems_test_run_default().
> + * @brief This source file provides the implementation of rtems_test_run().
> - * Copyright (C) 2020 embedded brains GmbH & Co. KG
> + * Copyright (C) 2020, 2023 embedded brains GmbH & Co. KG
>   * Redistribution and use in source and binary forms, with or without
>   * modification, are permitted provided that the following conditions
> @@ -38,6 +38,7 @@
>  #endif
>  #include <rtems/test-info.h>
> +#include <rtems/test-printer.h>
>  #include <rtems/test.h>
>  #include <stdlib.h>
> @@ -73,6 +74,12 @@ static const T_config config = {
>    .actions = actions
> +static int printer(void *context, const char *fmt, va_list ap)
> +  (void) context;
> +  return T_vprintf(fmt, ap);
>  void rtems_test_run(
>    rtems_task_argument    arg,
>    const RTEMS_TEST_STATE state
> @@ -80,6 +87,7 @@ void rtems_test_run(
>    (void) arg;
> +  rtems_test_printer.printer = printer;
>    rtems_test_begin( rtems_test_name, state );
>    T_register();
