[PATCH] bsps/arm/stm32f4: Enable USART RX interrupts
Jacob Killelea jkillelea344 at gmail.com
Thu Dec 14 00:49:18 UTC 2023
Hi all,
A quick bump, is anyone able to take a look at this?
Best,
Jacob
On Thu, Dec 7, 2023, 9:00 PM Jacob Killelea <jkillelea344 at gmail.com> wrote:
> From: Jacob Killelea <jkillelea344 at gmail.com>
> Hi all, this is my first email patch submission and my first contribution
> to RTEMS, so please give any feedback you have!
> This patch enables interrupt driven data reception on USART ports on
> STM32F4 series chips. This feature is gated behind the config flag
> BSP_CONSOLE_USE_INTERRUPTS. If this flag is not set to True, the older
> polling implementation will be used. I tested this feature on STM32F401CE
> (blackpill) and STM32 Nucleo F411RE boards, with both capable of keeping
> up with a 115200 baud continous data stream. With the older polling
> implementation, both would drop bytes at 9600 baud. In addition, I
> updated the implementation of usart_set_attributes to support changing
> the baud rate of the USART port based on the input speed.
>  bsps/arm/stm32f4/console/usart.c    | 81 ++++++++++++++++++++++++-----
>  spec/build/bsps/arm/stm32f4/grp.yml |  2 +
>  2 files changed, 69 insertions(+), 14 deletions(-)
> diff --git a/bsps/arm/stm32f4/console/usart.c
> b/bsps/arm/stm32f4/console/usart.c
> index 37566ef9d7..129249dc29 100644
> --- a/bsps/arm/stm32f4/console/usart.c
> +++ b/bsps/arm/stm32f4/console/usart.c
> @@ -14,6 +14,8 @@
>  #include <bsp/irq.h>
>  #include <bsp/usart.h>
>  #include <bsp/stm32f4.h>
> +#include <termios.h>
> +#include <string.h>
>  static volatile stm32f4_usart *usart_get_regs(const console_tbl *ct)
> @@ -27,6 +29,24 @@ static rtems_vector_number usart_get_irq_number(const
> console_tbl *ct)
>  #endif
> +#ifdef BSP_CONSOLE_USE_INTERRUPTS
> + * Read characters in an interrupt
> +static void stm32f4_usart_interrupt(void *arg)
> +  rtems_termios_tty *tty = (rtems_termios_tty *) arg;
> +  const console_tbl *ct = Console_Port_Tbl [tty->minor];
> +  volatile stm32f4_usart *usart = usart_get_regs(ct);
> +  while ((usart->sr & STM32F4_USART_SR_RXNE) == STM32F4_USART_SR_RXNE)
> +    char data = STM32F4_USART_DR_GET(usart->dr);
> +    rtems_termios_enqueue_raw_characters(tty, &data, sizeof(data));
> +#endif
>  static const stm32f4_rcc_index usart_rcc_index [] = {
>    STM32F4_RCC_USART1,
>    STM32F4_RCC_USART2,
> @@ -128,29 +148,50 @@ static void usart_initialize(int minor)
>    usart->cr2 = 0;
>    usart->cr3 = 0;
>    usart->bbr = usart_get_bbr(usart, pclk, baud);
> -  usart->cr1 = STM32F4_USART_CR1_UE
> -    | STM32F4_USART_CR1_TE
> -    | STM32F4_USART_CR1_RE;
> +  usart->cr1 = STM32F4_USART_CR1_UE // UART enable
> +    | STM32F4_USART_CR1_RXNEIE // RX interrupt
> +#endif
> +    | STM32F4_USART_CR1_TE  // TX enable
> +    | STM32F4_USART_CR1_RE; // RX enable
>  static int usart_first_open(int major, int minor, void *arg)
> +  rtems_status_code sc = RTEMS_SUCCESSFUL;
>    rtems_libio_open_close_args_t *oc = (rtems_libio_open_close_args_t *)
> arg;
> -  struct rtems_termios_tty *tty = (struct rtems_termios_tty *)
> oc->iop->data1;
> +  rtems_termios_tty *tty = (struct rtems_termios_tty *) oc->iop->data1;
>    const console_tbl *ct = Console_Port_Tbl [minor];
>    console_data *cd = &Console_Port_Data [minor];
>    cd->termios_data = tty;
>    rtems_termios_set_initial_baud(tty, ct->ulClock);
> -  return 0;
> +  sc = rtems_interrupt_handler_install(ct->ulIntVector,
> +      ct->sDeviceName,
> +      RTEMS_INTERRUPT_UNIQUE,
> +      stm32f4_usart_interrupt,
> +      tty);
> +#endif
> +  return sc;
>  static int usart_last_close(int major, int minor, void *arg)
> -  return 0;
> +  rtems_libio_open_close_args_t *oc = (rtems_libio_open_close_args_t *)
> arg;
> +  const console_tbl *ct = Console_Port_Tbl [minor];
> +  sc = rtems_interrupt_handler_remove(ct->ulIntVector,
> stm32f4_usart_interrupt, tty);
> +#endif
> +  return sc;
> +#ifndef BSP_CONSOLE_USE_INTERRUPTS
>  static int usart_read_polled(int minor)
> @@ -162,6 +203,7 @@ static int usart_read_polled(int minor)
>      return -1;
> +#endif
>  static void usart_write_polled(int minor, char c)
> @@ -175,11 +217,7 @@ static void usart_write_polled(int minor, char c)
>    usart->dr = STM32F4_USART_DR(c);
> -static ssize_t usart_write_support_polled(
> -  int minor,
> -  const char *s,
> -  size_t n
> +static ssize_t usart_write_support_polled(int minor, const char *s,
> size_t n)
>    ssize_t i = 0;
> @@ -190,19 +228,34 @@ static ssize_t usart_write_support_polled(
>    return n;
> + * Configure settings from a termios call to tcsetattr()
>  static int usart_set_attributes(int minor, const struct termios *term)
> -  return -1;
> +  console_tbl *ct = Console_Port_Tbl[minor];
> +  uint32_t pclk = usart_get_pclk(ct);
> +  uint32_t baud = term->c_ispeed;
> +  ct->ulClock = baud;
> +  usart->bbr = usart_get_bbr(usart, pclk, baud);
> +  return 0;
> -const console_fns stm32f4_usart_fns = {
> +const console_fns stm32f4_usart_fns =
>    .deviceProbe = libchip_serial_default_probe,
>    .deviceFirstOpen = usart_first_open,
>    .deviceLastClose = usart_last_close,
> +  .deviceRead = NULL,
> +#else
>    .deviceRead = usart_read_polled,
> +#endif
>    .deviceWrite = usart_write_support_polled,
>    .deviceInitialize = usart_initialize,
>    .deviceWritePolled = usart_write_polled,
>    .deviceSetAttributes = usart_set_attributes,
> -  .deviceOutputUsesInterrupts = false
> +  .deviceOutputUsesInterrupts = false,
> diff --git a/spec/build/bsps/arm/stm32f4/grp.yml
> b/spec/build/bsps/arm/stm32f4/grp.yml
> index 2257fdf015..27e2197e46 100644
> --- a/spec/build/bsps/arm/stm32f4/grp.yml
> +++ b/spec/build/bsps/arm/stm32f4/grp.yml
> @@ -50,6 +50,8 @@ links:
>    uid: optsysclk
>  - role: build-dependency
>    uid: optusartbaud
> +- role: build-dependency
> +  uid: ../../optconsoleirq
>    uid: ../../linkcmds
> 2.34.1
URL: <http://lists.rtems.org/pipermail/devel/attachments/20231213/a5f82041/attachment.htm>
