[rtems-release PATCH] Update with RTEMS 6 changes
chrisj at rtems.org chrisj at rtems.org
Thu Dec 14 06:35:12 UTC 2023
 rtems-release-4.10-conf                             |  2 ++
 rtems-release-4.11-conf                             |  2 ++
 rtems-release-5-conf                                |  2 ++
 rtems-release-defaults                              |  2 ++
 rtems-release-kernel                                | 13 +++----------
 rtems-release-notes                                 |  2 +-
 .../rtems-release-notes-coverpage.html.in           |  2 +-
 rtems-release-package-lists                         |  4 +++-
 8 files changed, 16 insertions(+), 13 deletions(-)
diff --git a/rtems-release-4.10-conf b/rtems-release-4.10-conf
index 1e29f78..cb71d43 100755
--- a/rtems-release-4.10-conf
+++ b/rtems-release-4.10-conf
@@ -34,6 +34,8 @@
 rtems_waf=no
 rtems_libbsd=no
+rtems_net_legacy=no
+rtems_net_services=no
 rtems_docs=no
 rtems_release_notes=no
 rtems_readme_release_notes=
diff --git a/rtems-release-4.11-conf b/rtems-release-4.11-conf
index 9fe957a..aceebc8 100755
--- a/rtems-release-4.11-conf
+++ b/rtems-release-4.11-conf
@@ -33,3 +33,5 @@
 # The script is the overridded configuration for 4.11.
 rtems_waf=no
diff --git a/rtems-release-5-conf b/rtems-release-5-conf
index c42ad55..6da7d27 100755
--- a/rtems-release-5-conf
+++ b/rtems-release-5-conf
@@ -33,3 +33,5 @@
 # The script is the overridded configuration for 5.
 rtems_waf=no
diff --git a/rtems-release-defaults b/rtems-release-defaults
index b558a45..4b6abba 100755
--- a/rtems-release-defaults
+++ b/rtems-release-defaults
@@ -72,6 +72,8 @@ comp_tar=J
 rtems_waf=yes
 rtems_examples=yes
 rtems_libbsd=yes
+rtems_net_legacy=yes
+rtems_net_services=yes
 rtems_docs=yes
 rtems_docs_required=yes
 rtems_docs_build=sphinx
diff --git a/rtems-release-kernel b/rtems-release-kernel
index 09c7ac2..e25129c 100755
--- a/rtems-release-kernel
+++ b/rtems-release-kernel
@@ -106,16 +106,9 @@ cd ${prefix}
   # Waf build system. Update RTEMS version and collect the BSPs
   echo "] RTEMS Build System: waf"
-  f="spec/build/cpukit/optvermaj.yml"
-  echo "] Update ${f}"
-  sed -i "s/- get-string-command-line:.*/- get-string-command-line: '${version}'/" ${f}
-  f="spec/build/cpukit/optvermin.yml"
-  minor=$(echo ${revision} | sed 's/-.*//')
-  sed -i "s/- set-value:.*/- set-value: '${minor}'/" ${f}
-  f="spec/build/cpukit/optverrev.yml"
-  sed -i "s/- set-value:.*/- set-value: '0'/" ${f}
+  f="VERSION"
+  echo "] Creating ${f}: ${release}"
+  echo "RTEMS_VERSION = ${release}" > ${f}
  else
   # Autoconf build system. Bootstrap RTEMS
diff --git a/rtems-release-notes b/rtems-release-notes
index c1d280d..659a706 100755
--- a/rtems-release-notes
+++ b/rtems-release-notes
@@ -68,7 +68,7 @@ title="RTEMS Release Notes builder"
 ws_pwd=${PWD}
-echo "] Creating release notes"
+echo "] Creating release notes for ${release}"
 echo "] Generate release notes markdown"
diff --git a/rtems-release-notes-coverpage/rtems-release-notes-coverpage.html.in b/rtems-release-notes-coverpage/rtems-release-notes-coverpage.html.in
index 422e8bd..4f9350a 100644
--- a/rtems-release-notes-coverpage/rtems-release-notes-coverpage.html.in
+++ b/rtems-release-notes-coverpage/rtems-release-notes-coverpage.html.in
@@ -46,7 +46,7 @@
    </div>
    <footer class="footer">
      <div class="container">
-       Copyright @TEAR@ RTEMS Project
+       Copyright @YEAR@ RTEMS Project
      </div>
    </footer>
  </body>
diff --git a/rtems-release-package-lists b/rtems-release-package-lists
index c73ad60..55bfedb 100755
--- a/rtems-release-package-lists
+++ b/rtems-release-package-lists
@@ -45,7 +45,9 @@ fi
 # RTEMS 6 and later
 if [ ${version} -ge 6 ]; then
-  rtems_packages="${rtems_packages} rtems_waf rtems-net-legacy rtems-lwip"
+  rtems_packages="${rtems_packages} rtems_waf"
+  rtems_packages="${rtems_packages} rtems-net-legacy rtems-lwip"
+  rtems_packages="${rtems_packages} rtems-net-services"
 fi
2.37.1
