[RSB PATCH] 6: Merge the MacOS M silicon patch from gcc-12 to gcc-13
Cedric Berger cedric at precidata.com
Fri Dec 15 15:04:47 UTC 2023
Hello Heinz,
On 15.12.2023 10:44, Heinz Junkes wrote:
> HI,
> I can follow Cedric's reasoning. Even if I was the initiator of this discussion.
> I use RTEMS in my lectures/exercises, among other things, and have always been able to give the students
> freedom which laptops with which OS they wanted to use. And there are many of them with used
> older laptops. Intel Macs, for example.
> But you can also use a VM with Linux on all these systems.
> It might then be okay to communicate openly that there will be no more support for Macs in the future.
Just to be clear: I'm not advocating dropping Mac support, just dropping
the support for the old intel-based ones (the ones with issues right now).
Mac with M1/M2/M3 work fine with the latest tooling.
Cedric
