[PATCH 2/2] testsuites/fstests: Add JFFS2 NAND support tests
Kinsey Moore kinsey.moore at oarcorp.com
Fri Dec 15 20:05:09 UTC 2023
This adds a second set of JFFS2 tests running on top of a simulated NAND
backend to ensure that interactions with delayed writes operate as
expected.
 spec/build/testsuites/fstests/grp.yml         |  18 ++
 .../testsuites/fstests/jffs2nandfserror.yml   |  22 ++
 .../testsuites/fstests/jffs2nandfslink.yml    |  22 ++
 .../fstests/jffs2nandfspatheval.yml           |  22 ++
 .../fstests/jffs2nandfspermission.yml         |  22 ++
 .../testsuites/fstests/jffs2nandfsrdwr.yml    |  22 ++
 .../fstests/jffs2nandfsscandir01.yml          |  22 ++
 .../testsuites/fstests/jffs2nandfssymlink.yml |  22 ++
 .../testsuites/fstests/jffs2nandfstime.yml    |  22 ++
 .../build/testsuites/fstests/libjffs2nand.yml |  18 ++
 .../fstests/jffs2_nand_support/fs_config.h    |  33 +++
 .../fstests/jffs2_nand_support/fs_support.c   | 257 ++++++++++++++++++
 12 files changed, 502 insertions(+)
 create mode 100644 spec/build/testsuites/fstests/jffs2nandfserror.yml
 create mode 100644 spec/build/testsuites/fstests/jffs2nandfslink.yml
 create mode 100644 spec/build/testsuites/fstests/jffs2nandfspatheval.yml
 create mode 100644 spec/build/testsuites/fstests/jffs2nandfspermission.yml
 create mode 100644 spec/build/testsuites/fstests/jffs2nandfsrdwr.yml
 create mode 100644 spec/build/testsuites/fstests/jffs2nandfsscandir01.yml
 create mode 100644 spec/build/testsuites/fstests/jffs2nandfssymlink.yml
 create mode 100644 spec/build/testsuites/fstests/jffs2nandfstime.yml
 create mode 100644 spec/build/testsuites/fstests/libjffs2nand.yml
 create mode 100644 testsuites/fstests/jffs2_nand_support/fs_config.h
 create mode 100644 testsuites/fstests/jffs2_nand_support/fs_support.c
diff --git a/spec/build/testsuites/fstests/grp.yml b/spec/build/testsuites/fstests/grp.yml
index 9f089fc68a..6c4d1a6fc9 100644
--- a/spec/build/testsuites/fstests/grp.yml
+++ b/spec/build/testsuites/fstests/grp.yml
@@ -21,6 +21,8 @@ links:
   uid: libimfs
 - role: build-dependency
   uid: libjffs2
+- role: build-dependency
+  uid: libjffs2nand
   uid: libmimfs
@@ -89,6 +91,22 @@ links:
   uid: jffs2fssymlink
   uid: jffs2fstime
+  uid: jffs2nandfserror
+  uid: jffs2nandfslink
+  uid: jffs2nandfspatheval
+  uid: jffs2nandfspermission
+  uid: jffs2nandfsrdwr
+  uid: jffs2nandfsscandir01
+  uid: jffs2nandfssymlink
+  uid: jffs2nandfstime
   uid: mdosfsfserror
diff --git a/spec/build/testsuites/fstests/jffs2nandfserror.yml b/spec/build/testsuites/fstests/jffs2nandfserror.yml
new file mode 100644
index 0000000000..cf7844fb23
--- /dev/null
+++ b/spec/build/testsuites/fstests/jffs2nandfserror.yml
@@ -0,0 +1,22 @@
+SPDX-License-Identifier: CC-BY-SA-4.0 OR BSD-2-Clause
+build-type: test-program
+cflags: []
+copyrights:
+- Copyright (C) 2023 On-Line Applications Research (OAR)
+cppflags: []
+cxxflags: []
+enabled-by: true
+features: c cprogram
+includes:
+- testsuites/fstests/jffs2_nand_support
+ldflags: []
+links: []
+source:
+- testsuites/fstests/fserror/test.c
+stlib: []
+target: testsuites/fstests/jffs2nand_fserror.exe
+type: build
+use-after: []
+use-before:
+- testjffs2nand
+- jffs2
diff --git a/spec/build/testsuites/fstests/jffs2nandfslink.yml b/spec/build/testsuites/fstests/jffs2nandfslink.yml
index 0000000000..10cbfbfd86
--- /dev/null
+++ b/spec/build/testsuites/fstests/jffs2nandfslink.yml
@@ -0,0 +1,22 @@
+cflags: []
+copyrights:
+cppflags: []
+cxxflags: []
+enabled-by: true
+includes:
+ldflags: []
+links: []
+source:
+- testsuites/fstests/fslink/test.c
+stlib: []
+target: testsuites/fstests/jffs2nand_fslink.exe
+type: build
+use-after: []
+use-before:
+- testjffs2nand
+- jffs2
diff --git a/spec/build/testsuites/fstests/jffs2nandfspatheval.yml b/spec/build/testsuites/fstests/jffs2nandfspatheval.yml
index 0000000000..07aaa737bb
--- /dev/null
+++ b/spec/build/testsuites/fstests/jffs2nandfspatheval.yml
@@ -0,0 +1,22 @@
+cflags: []
+copyrights:
+cppflags: []
+cxxflags: []
+enabled-by: true
+includes:
+ldflags: []
+links: []
+source:
+- testsuites/fstests/fspatheval/test.c
+stlib: []
+target: testsuites/fstests/jffs2nand_fspatheval.exe
+type: build
+use-after: []
+use-before:
+- testjffs2nand
+- jffs2
diff --git a/spec/build/testsuites/fstests/jffs2nandfspermission.yml b/spec/build/testsuites/fstests/jffs2nandfspermission.yml
index 0000000000..4ecdab9385
--- /dev/null
+++ b/spec/build/testsuites/fstests/jffs2nandfspermission.yml
@@ -0,0 +1,22 @@
+cflags: []
+copyrights:
+cppflags: []
+cxxflags: []
+enabled-by: true
+includes:
+ldflags: []
+links: []
+source:
+- testsuites/fstests/fspermission/test.c
+stlib: []
+target: testsuites/fstests/jffs2nand_fspermission.exe
+type: build
+use-after: []
+use-before:
+- testjffs2nand
+- jffs2
diff --git a/spec/build/testsuites/fstests/jffs2nandfsrdwr.yml b/spec/build/testsuites/fstests/jffs2nandfsrdwr.yml
index 0000000000..605c168a1a
--- /dev/null
+++ b/spec/build/testsuites/fstests/jffs2nandfsrdwr.yml
@@ -0,0 +1,22 @@
+cflags: []
+copyrights:
+cppflags: []
+cxxflags: []
+enabled-by: true
+includes:
+ldflags: []
+links: []
+source:
+- testsuites/fstests/fsrdwr/init.c
+stlib: []
+target: testsuites/fstests/jffs2nand_fsrdwr.exe
+type: build
+use-after: []
+use-before:
+- testjffs2nand
+- jffs2
diff --git a/spec/build/testsuites/fstests/jffs2nandfsscandir01.yml b/spec/build/testsuites/fstests/jffs2nandfsscandir01.yml
index 0000000000..56f693ce0f
--- /dev/null
+++ b/spec/build/testsuites/fstests/jffs2nandfsscandir01.yml
@@ -0,0 +1,22 @@
+cflags: []
+copyrights:
+cppflags: []
+cxxflags: []
+enabled-by: true
+includes:
+ldflags: []
+links: []
+source:
+- testsuites/fstests/fsscandir01/init.c
+stlib: []
+target: testsuites/fstests/jffs2nand_fsscandir01.exe
+type: build
+use-after: []
+use-before:
+- testjffs2nand
+- jffs2
diff --git a/spec/build/testsuites/fstests/jffs2nandfssymlink.yml b/spec/build/testsuites/fstests/jffs2nandfssymlink.yml
index 0000000000..e522d49330
--- /dev/null
+++ b/spec/build/testsuites/fstests/jffs2nandfssymlink.yml
@@ -0,0 +1,22 @@
+cflags: []
+copyrights:
+cppflags: []
+cxxflags: []
+enabled-by: true
+includes:
+ldflags: []
+links: []
+source:
+- testsuites/fstests/fssymlink/test.c
+stlib: []
+target: testsuites/fstests/jffs2nand_fssymlink.exe
+type: build
+use-after: []
+use-before:
+- testjffs2nand
+- jffs2
diff --git a/spec/build/testsuites/fstests/jffs2nandfstime.yml b/spec/build/testsuites/fstests/jffs2nandfstime.yml
index 0000000000..799757fdbe
--- /dev/null
+++ b/spec/build/testsuites/fstests/jffs2nandfstime.yml
@@ -0,0 +1,22 @@
+cflags: []
+copyrights:
+cppflags: []
+cxxflags: []
+enabled-by: true
+includes:
+ldflags: []
+links: []
+source:
+- testsuites/fstests/fstime/test.c
+stlib: []
+target: testsuites/fstests/jffs2nand_fstime.exe
+type: build
+use-after: []
+use-before:
+- testjffs2nand
+- jffs2
diff --git a/spec/build/testsuites/fstests/libjffs2nand.yml b/spec/build/testsuites/fstests/libjffs2nand.yml
index 0000000000..03750653d3
--- /dev/null
+++ b/spec/build/testsuites/fstests/libjffs2nand.yml
@@ -0,0 +1,18 @@
+build-type: library
+cflags: []
+copyrights:
+cppflags: []
+cxxflags: []
+enabled-by: true
+includes:
+install: []
+install-path: null
+links: []
+source:
+- testsuites/fstests/jffs2_nand_support/fs_support.c
+- testsuites/fstests/support/fstest_support.c
+target: testjffs2nand
+type: build
diff --git a/testsuites/fstests/jffs2_nand_support/fs_config.h b/testsuites/fstests/jffs2_nand_support/fs_config.h
index 0000000000..548f5203e6
--- /dev/null
+++ b/testsuites/fstests/jffs2_nand_support/fs_config.h
@@ -0,0 +1,33 @@
+ * Copyright (C) 2023 On-Line Applications Research (OAR)
+ * are met:
+#ifndef __JFFS2_SUPPORT_h
+#define __JFFS2_SUPPORT_h
+#define FILESYSTEM "JFFS2"
+#endif
diff --git a/testsuites/fstests/jffs2_nand_support/fs_support.c b/testsuites/fstests/jffs2_nand_support/fs_support.c
index 0000000000..9e7c965735
--- /dev/null
+++ b/testsuites/fstests/jffs2_nand_support/fs_support.c
@@ -0,0 +1,257 @@
+ * are met:
+#ifdef HAVE_CONFIG_H
+#include "config.h"
+#endif
+#include <tmacros.h>
+#include <sys/stat.h>
+#include <sys/types.h>
+#include <string.h>
+#include <rtems/jffs2.h>
+#include <rtems/libio.h>
+#include <rtems/libcsupport.h>
+#include "fstest.h"
+#include "fstest_support.h"
+#define FLASH_PAGE_SIZE (1024UL)
+/* Out of Band/Spare area size is per-page */
+#define FLASH_PAGE_OOB_SIZE (32UL)
+#define PAGES_PER_BLOCK (16UL)
+#define BLOCKS_PER_DEVICE (8UL)
+#define FLASH_OOB_SIZE (BLOCKS_PER_DEVICE * PAGES_PER_BLOCK * FLASH_PAGE_OOB_SIZE)
+#define FLASH_BLOCK_SIZE (PAGES_PER_BLOCK * FLASH_PAGE_SIZE)
+#define FLASH_SIZE (BLOCKS_PER_DEVICE * FLASH_BLOCK_SIZE)
+typedef struct {
+  rtems_jffs2_flash_control super;
+  unsigned char area[FLASH_SIZE];
+  unsigned char oob[FLASH_OOB_SIZE];
+} flash_control;
+static flash_control *get_flash_control(rtems_jffs2_flash_control *super)
+  return (flash_control *) super;
+static int flash_read(
+  rtems_jffs2_flash_control *super,
+  uint32_t offset,
+  unsigned char *buffer,
+  size_t size_of_buffer
+  flash_control *self = get_flash_control(super);
+  unsigned char *chunk = &self->area[offset];
+  memcpy(buffer, chunk, size_of_buffer);
+  return 0;
+static int flash_write(
+  uint32_t offset,
+  const unsigned char *buffer,
+  size_t i;
+  for (i = 0; i < size_of_buffer; ++i) {
+    chunk[i] &= buffer[i];
+  return 0;
+static int flash_erase(
+  uint32_t offset
+  uint32_t page_index = offset / FLASH_PAGE_SIZE;
+  uint32_t oob_offset = page_index * FLASH_PAGE_OOB_SIZE;
+  unsigned char *oobchunk = &self->oob[oob_offset];
+  memset(chunk, 0xff, FLASH_BLOCK_SIZE);
+  memset(oobchunk, 0xff, PAGES_PER_BLOCK * FLASH_PAGE_OOB_SIZE);
+  return 0;
+static int flash_read_oob(
+  uint32_t offset,
+  uint8_t *buffer,
+  uint32_t size_of_buffer
+  unsigned char *chunk = &self->oob[oob_offset];
+  return 0;
+static int flash_write_oob(
+  uint32_t offset,
+  uint8_t *buffer,
+  size_t i;
+  return 0;
+static int flash_block_is_bad(
+  uint32_t orig_offset,
+  bool *bad
+  *bad = false;
+  return 0;
+static int flash_block_mark_bad(
+  return 0;
+static uint32_t flash_get_oob_size(
+  return FLASH_PAGE_OOB_SIZE;
+static flash_control flash_instance = {
+  .super = {
+    .block_size = FLASH_BLOCK_SIZE,
+    .flash_size = FLASH_SIZE,
+    .read = flash_read,
+    .write = flash_write,
+    .erase = flash_erase,
+    .block_is_bad = flash_block_is_bad,
+    .block_mark_bad = flash_block_mark_bad,
+    .oob_read = flash_read_oob,
+    .oob_write = flash_write_oob,
+    .get_oob_size = flash_get_oob_size,
+    .write_size = FLASH_PAGE_SIZE
+static rtems_jffs2_compressor_control compressor_instance = {
+  .compress = rtems_jffs2_compressor_rtime_compress,
+  .decompress = rtems_jffs2_compressor_rtime_decompress
+static const rtems_jffs2_mount_data mount_data = {
+  .flash_control = &flash_instance.super,
+  .compressor_control = &compressor_instance
+static void erase_all(void)
+  memset(&flash_instance.area[0], 0xff, FLASH_SIZE);
+  memset(&flash_instance.oob[0], 0xff, FLASH_OOB_SIZE);
+static rtems_resource_snapshot before_mount;
+void test_initialize_filesystem(void)
+  int rv;
+  erase_all();
+  rv = mkdir(BASE_FOR_TEST, S_IRWXU | S_IRWXG | S_IRWXO);
+  rtems_test_assert(rv == 0);
+  rtems_resource_snapshot_take(&before_mount);
+  rv = mount(
+    NULL,
+    BASE_FOR_TEST,
+    RTEMS_FILESYSTEM_TYPE_JFFS2,
+    RTEMS_FILESYSTEM_READ_WRITE,
+    &mount_data
+void test_shutdown_filesystem(void)
+  int rv = unmount(BASE_FOR_TEST);
+  rtems_test_assert(rtems_resource_snapshot_check(&before_mount));
+#define CONFIGURE_APPLICATION_NEEDS_CLOCK_DRIVER
+#define CONFIGURE_APPLICATION_NEEDS_SIMPLE_CONSOLE_DRIVER
+#define CONFIGURE_FILESYSTEM_JFFS2
+#define CONFIGURE_MAXIMUM_FILE_DESCRIPTORS 40
+#define CONFIGURE_MAXIMUM_TASKS 2
+#define CONFIGURE_INIT_TASK_STACK_SIZE (32 * 1024)
+#define CONFIGURE_INIT_TASK_ATTRIBUTES RTEMS_FLOATING_POINT
+#define CONFIGURE_INITIAL_EXTENSIONS RTEMS_TEST_INITIAL_EXTENSION
+#define CONFIGURE_RTEMS_INIT_TASKS_TABLE
+#include <rtems/confdefs.h>
2.39.2
